I'm running Windows XP SP3. LT 2011 will not fully install. The Autodesk Material Library 2011 and AutoCAD LT 2011 seem to install. There is a green check mark in front of those items but, the whole process stops midway through installing the 2011 Language Pack and returns this message "Error 1606. Could not access network location Setup." This is a typical stand-alone installation process. I certainly need help figuring this one out.
Thanks in advance,
Mike
See these two articles from the knowledgebase :
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=8164400&linkID=9240617
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=9579121&linkID=9240617
Best regards.
