Installation & Licensing
AutoCAD LT 2010 Command Line Install
1 REPLY 1
mcvpjd3
865 Views, 1 Reply
I'm trying to setup a command line install for the above, this is the command line I;m using:
d:\myfiles\setup.exe /t /qb+ /Language en-US /c ACADLT: ACADSERIALPREFIX=123 ACADSERIALNUMBER=12345678 ADLM_PRODKEY="057B1" ACADFIRSTNAME="Fname" ACADLASTNAME="Surname" ACADORGANIZATION="My Company" INSTALLLEVEL=3 ALLUSERS=1
When this runs I get the small dialog box showing the "Setup Initilization, but I then get the AutoCAD LT main setup window (showing the Install Products/Create Deployments/Install Tools options) and it doesn't install.
Can someone give me a hint as to what I'm doing wrong?
1 REPLY 1
TravisNave
in reply to: mcvpjd3
Try running it on the .MSI file instead of setup.exe.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
