Installation & Licensing
Active Member
outlaw08
Message 1 of 3 (436 Views)
AutoCAD LT 2006 windows 7 question
436 Views, 2 Replies
05-16-2012 01:17 PM
I have installed LT 06 and it works fine as long as the user is an admin on the machine, when I switch the user to a power user it does not launch.
Is there any known solution to this problem? to have it run as a non admin?
TravisNave
Message 2 of 3 (433 Views)
Re: AutoCAD LT 2006 windows 7 question
05-16-2012 01:30 PM in reply to: outlaw08
Only Autodesk products 2010 and newer are supported on Windows 7.  If you have gotten your retired application to work and license properly and an admin, then consider yourself lucky.  The only other option would be to install WindowsXP mode and install AutoCAD in that virtual environment.  Good luck!
Active Member
outlaw08
Message 3 of 3 (431 Views)
05-16-2012 01:31 PM in reply to: TravisNave
I have had no problems with installing it and getting it to work, but did run into a problem with the user not being an admin. Thanks for the info.
is this possible in later AutoCAD LT versions then if it is not on 06?
