Installation & Licensing
autocad lt 2006 re-install
3 REPLIES 3
345 Views, 3 Replies
i would like to re-install my autocad lt 2006 on my newer computer. i have tried to install but a error comes up telling me there is incompatibilty issues. the computer i am trying to install on is running windows 7  64-bit. i assume that is the issue. i have checked microsofts compatibility web page and it tells me to get a paid upgrade. my question: is that what i am stuck with doing?  any help would be appreciated.
3 REPLIES 3
LyleHardin
2006 was most likely a 32 bit software. You'll either have to upgrade to a modern version of LT or load it onto a 32 bit Windows OS.
That's my guess.  I'm not sure if there is some Windows 32 bit emulation mode you can use or not.
pendean
Visit Microsoft's website for tips on how to run old software in Win7 64bit. Not much else you can do really other than the tip offered above.
TravisNave
Even if you could install it, you'd be hard pressed to activate it.
Release 2006 was 32-bit and was only supported on XP.  Everything is retired at this point.  You can't even get XP Mode anymore, I don't believe.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
