Installation & Licensing
AutoCAD LT 2006 multiple user pack question
2 REPLIES 2
261 Views, 2 Replies
I have a 5 Mulit User pack for AutoCAD LT 2006.
The question I have is once I have install 5 users with a MSI I created from this user pack, Do I have to monitor the License returns, re-installs, etc or is there a utility to do it.
Do I have to make sure the license is removed from an old machine before it is re-imaged, or trashed.
Any help would be welcome
Derrick Hauser
Tri Ocean Engineering Ltd
Calgary Alberta, Canada
2 REPLIES 2
TravisNave
It is best if you use the PLU to remove the license before you reimage it. That way you can retain your licenses.
Otherwise, it is usually no big deal if you have to reactivate the software for this reason.
Autodesk Forums:
Thanks Travis for the feed back
Administrator Productivity
