Dear All,
I would like to ask if licensing manager can be installed on a server with nic teaming or not. LMtools reported mac address "fffffff" on a nic teaming and the license file is prompted invalid. However, when i register the license with te teaming nic MAC address. the license is valid and the MAC address is stilled "ffffffff".
**the license register prompted that it reaches limit of the product registration. What can I do?
Elroy
DarrenP
I agree with Darren.
If you cannot unteam them due to some odd policy, then use the GETMAC command at a command prompt to obtain your MAC address. So long as one of the MACs is valid and active, you should be able to get a working license file. You might also be able to set the MAC address on the teamed adapter manually if needed.
And also, I have another issue is that when I register the license server and MAC address with the license key. It prompted that the limit has been reach. Is that anything I can do to erase the worng mac address registered before?
Yes, contact Autodesk Activations and they will get you the LIC file that you need.
You can use the online method to activate your license here:
http://usa.autodesk.com/adsk/servlet/pc/item?id=18424632&siteID=123112
Or you can can call Autodesk Product Registration and Authorization:
http://en.autodesk.ca/adsk/servlet/index?siteID=9719649&id=9830778
1-800-551-1490 > Option 1 (English) > Option 2 > (Network)
Asia / Pacific: 65.6735.5688
Europe / Middle East / Asia: 41.32.723.9595
You will need to provide your serial number and ethernet ID of the new license server.
