Installation & Licensing
AutoCAD License Transfer Problem
2 REPLIES 2
672 Views, 2 Replies
I am trying to install AutoCAD 2013 onto my new laptop, and whenever I try to activate, it says the license (an educational) is already in use on another computer. This was the case - I couldn't install on my old laptop, and I had to use a work machine. When I got my new laptop last week, the user of the other computer, who had generously lent me use of it until mine arrived, uninstalled without transferring the license. Now, I can't use the license, and Autodesk won't get back to me on the subject (communications stopped on Thursday).
AutoCAD 2013 Windows 64-bit, running on a Windows 7 machine, in case that matters. All hardware specs exceed minimum requirements.
2 REPLIES 2
TravisNave
You might see if the user of the original laptop can run the LTU for you and transfer the license.  Otherwise, Autodesk will have to activate it for you.  Good luck!
Autodesk Forums:
I borrowed the coworker's laptop, reinstalled 2013, and ran the License Transfer Utility successfully. I can now use AutoCAD 2013 Student Edition on my personal laptop, as it should be.
I declare this problem resolved.
Administrator Productivity
