is there a work around this? Running Autocad LS on Server 2003 box. Installed Autocad 2011 on PC and it works fine as long as you are logged in to the server. If you log off the server, then LMTOOLS stops running. I can log the screen and let it run but dont like to do that.
Solved by TravisNave. Go to Solution.
On the Config Services tab, check both boxes at the bottom and then save the service. Restart the service and you are all set.
