My company bought a five seat license (1 DVD) for AutoCAD InventorLT Suite 2012. It was in stalled on the first computer a the home office without difficulty. It was then bought to my location where I attempted to install it on a new HP TouchSmart610 (an all-in-one unit). The first attempt it CLAIMED to have installed AutoCAD LT and Inventor LT and to have failed on tools. I did not check at that time and installed on an HP Pavillion P7-1254 with no difficulty.
I then checked to see if the programs would run. Fine on the Pavillion but no go on the All-In-One. Windows explorer showed NO INSTALLATION at all. I made repeated efforts to install to no avail. Does anyone have a solution.
Solved by TravisNave. Go to Solution.
You need to post your installation log file, not a screen capture of the failure.
Here it is. Hopefully you will find it more usefull than I did.
Thanks for any assistance.
Yes very.
Install Microsoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1603
Your product is failing to install because the prerequiste program required by the installer is newer than the version being installed. Please uninstall the prerequisite program causing the issue and run your installer again.
For more information about this process, please see my KB link here:
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
Good Luck!
That let it install but now I have another problem (probably of my own making). When the suite would not install earlier I tried individual installs. I downloaded the c++ redistributable and installed it and went deeper in the CD looking for setup programs for Inventor and AutoCAD. I found one for AutoCAD and tried to install from it. It halfway installed. My curent problem is that when I start AutoCAD it wants to install again and will not accept the same Product Key as used before. I tried uninstalling AutoCAD and reinstalling. It lets me reinstall but when I try to run the program it wants to install again and refuses the product key. I have tried uninstalling the entire suite and deleting the autodesk folder and any associated files I could find before reinstalling the suite. No luck.
Any ideas?
Thanks for all the help.
Yeah, you can't really install from the .msi direct. You need to install from the setup GUI. That's why you get odd results on launch.
For more information on the Autodesk KB Support article concerning the clean uninstall of Autdoesk products, see this link:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617
Thanks for the link. I'm sorry I took so long to reply and thank you. I cleaned EVERY reference to AutoCAD/Autodesk from ANY part of the computer that I could find including ALL segments of the Register. After that all went well. Thanks
