My inventor has been working OK and there has been no changes to my PC hardware and suddenly I get:
"Your license has expired, To use your AutoCAD inventor suite 2010 you must re activete it, what would you like to do?"
"Activate - Select this option to submit an activation request or to enter an activation code" Which I select
The I get a screen that shows my serial number with a request code and gives me the option "Get an activation code"
once selected the screen changes and I get error 1 "The serial number you entered is not valid"
Can somebody tell me what I need to do to resolve this problem.
Thanks.
Solved by camilo.lemos. Go to Solution.
Hi @d_raistrick ,
Please, send me your serial number via Private Message (click on my camilo.lemos profile name and then on Send This User a Private Message) and I'll look into this for you.
For direct activation and licensing assistance, you can also contact our License Assistance team by clicking on this link and then following the prompts:
Select “Activation & Registration” or “License Management”
Select appropriate subtopics from the pull-down menus.
Select “I Still Need Help” if you need personal assistance.
You will be able to contact the License Assistance Team either via Chat or e-mail.
Thank you!
