hello, i am unable to install autocad in Inventor Autocad lt suit in system.
I have attached errors in sequence, i found during installation.
Customer have 20 computers in plant and have installed same software in 8 systems, all running but this one is not responding to install autocad, from the same suit inventor is installing. please suggest me the solution.
Regards
Are you installing the 32-bit version? Perhaps you need to download a fresh version.
I would recommend that you try downloading your product using the virtual assistant by following the directions here:
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-...
