Installation & Licensing
AutoCAD Installation Error
4 REPLIES 4
Ritchie
1877 Views, 4 Replies
I have tried on several occasions to download and install AutoCAD 2013 but without sucess.
I have downloaded using both Firefox and IE but both have the same result.
The file I have selected for download is 'AutoCAD English 2013 Win 32' (filesize 2.66GB) and I am using the browser download because the Download Manager doesn't work (probably blocked by our Proxy Server).
The file seems to download ok and then it comes to the installation procedure. At the very end of the install I receive an error message which happens every time and can be seen in the attachment.
Any help would be greatly appreciated.
Knoxy
4 REPLIES 4
TravisNave
in reply to: Ritchie
http://forums.autodesk.com/t5/Test/How-to-take-a-screen-capture-and-upload-it/m-p/3467392
Please attach your installation log file.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Ritchie
in reply to: TravisNave
I have done a search of the C: drive but cannot find the Installation Log File.
I haven't got as far as the install, just to the extraction stage, which is where I get the error which is seen in the 'Failed Install' attachment.
TravisNave
Problems downloading the Autodesk software and/or CRC errors may be avoided by using another web browser, or using the alternate browser download method.
For more detailed information on this process, please see the following blog post tip here:
http://upandready.typepad.com/up_and_ready/2011/08/downloading-software-browser-download-vs-download...
You might also consider downloading the trial version and activating it.
Autodesk Forums:
britta.t
i got the same problem, unfortunately...
Smiley Frustrated
autocad14 on windows8
thanks in advance!!
britta
Administrator Productivity
