AutoCAD Installation Error; "Aborted.(Error: 9)"
Message 1 of 100
I'm having trouble installing AutoCAD 2014 ...
After proceeding with the download, the loading task bar fails when it reaches 98% with the report, "Aborted. (Error 9)."
This is the first time I've had trouble downloading anything from Autodesk. If anyone has advice, I would greatly appreciate any correspondence. Thanks!
Replies (99)
Message 2 of 100
ukdxb012
Is this the error of which you speak... http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Error-R...
Did you download the product via the Autodesk Virtual Agent... http://autodesk.creativevirtual15.com/autodesk/bot.html?isJSEnabled=1&businessArea=Root.Front%20Desk... if not it might be worth redownloading the file.
Duncan Brannan
UK/EMEIA CAD Operations Manager
Twitter | LinkedIn
Message 3 of 100
Please tell me how to solve this error caused problem which restrained me from downloading the AutoCAD 2015. Thank
Message 4 of 100
I have the same problem upon installation. I cant find the solution. please help
Message 5 of 100
camilo.lemos
Hi @Anonymous and @Anonymous and welcome both to the Autodesk Community!
Have you tried the solutions posted by @ukdxb012 on the post just above yours?
If so you have and it didn't resolve the issue, could you give us more details on where/how the activation went wrong after trying those solutions?
Thank you!
Camilo Lemos
Message 6 of 100
Hi
its showing error 9 when i try to install autocad 2014. what is this error?
Message 7 of 100
Hi, I face this problem (shown in the picuter) during the installation. Could you give me a solution regarding this??Problem.png
Message 8 of 100
matthew.d
Hi @Anonymous and @Anonymous,
Welcome to the community, both of you!
Here is more information on error 9 in AutoCAD. Have you tried the above solutions posted by @ukdxb012?
Matt DiMichele
Autodesk Product Blogs | @ADSKCommunity Twitter
Likes are greatly appreciated. Everyone enjoys a thumbs up!
Please Accept As Solution if this resolves your issue, to help others benefit and locate it.
Message 9 of 100
hi i steel have the same problem as chongyaokang di but for autocad 2016 and 2015 what should i do to fix this problem
Message 10 of 100
matthew.d
Hi @Anonymous,
Welcome to the community!
Apologies for the issue. Can you make sure that you are signed into your account? Have you also already tried redownloading from the virtual agent with your antivirus software off, as suggested previously?
Matt DiMichele
Message 11 of 100
I have the same problem. I 've downloaded LT installer but when the the Autodesk InstallNow starts it shows me that msg right after it initializes.
Aborted.(Error:9).
I've tried redownloading and also shut down my virus scan, didn't help.
Message 12 of 100
bharch
Use the BROWSER DOWNALOD option, do NOT install your software as part of the download process, your system seems unable to handle it.
Message 13 of 100
Couldn't get LT through browser download. Weird thing is that I have tried a dozen times and nothing, but I did one last try a few mins ago through InstallNow and it worked. Weirdest yet is that all other software gets installed OK using IntallNow, only LT gave me that issue. So I guess it is not my system's issue.
But thanks for the tip! =D
Message 14 of 100
not helping
Message 15 of 100
pendean
Community Legend
Community Legend
If you can't download your Autodesk software from the download link at this page then you have system level issues at play that no one here can fix for you http://autodesk.creativevirtual15.com/autodesk/bot.html?isJSEnabled=1&businessArea=Root.Front%20Desk...
Message 17 of 100
Just run the installer with Administrator right and everything will be fine.
Message 18 of 100
how?
Message 19 of 100
i tried but same thing happens
Message 20 of 100
Same problem as Chongyaokang. Did the following:
1. logged in to download the virtual agent (error happened upon download)
2. re-downloaded the virtual agent and ran it (error happened again)
I tried restarting the computer then ran the program. Restarted computer, re-downloaded the virtual agent, then ran it. Same error on both.
