Installation & Licensing
AutoCad Install Failure. Please Help!!
6 REPLIES 6
ymaynie
5072 Views, 6 Replies
Hello, I am trying to install this AutoCad for my class, and I have an assignment due next monday. Like many others, I am having problems downloading this software. I am not sure what I am doing wrong and have tried reinstalling sevferal times. I have seen someone suggest deleting C++ files that are on my computer. I found these files and deleted them accordingly. However, after doing this and reinstalling multiple times, I am still unable to download this program. If someone could help my, I'd sure appreciate it.
To help, I copied and pasted my failure log for AutoCad and Inventor Fusion below. Please help as I have an assignment due by the end of this weekend. If there is anymore information you would like, just tell me.
Thank you in advance.
AutoCad Failure Log:
2013/1/10:18:06:56 Yosef #2 YOSEFSLAPTOP2 === Setup started on YOSEFSLAPTOP2 by Yosef #2 ===
2013/1/10:18:06:56 Yosef #2 YOSEFSLAPTOP2 Launch
2013/1/10:18:06:56 Yosef #2 YOSEFSLAPTOP2 CommandLine /url "http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/AutoCAD_2013_English_Win_32_64bit_wi_en-US..." /SN 900-35927844 /PK 001E1 /student /skipEULA /akamai /auth /sid
2013/1/10:18:08:04 Yosef #2 YOSEFSLAPTOP2 === Setup ended ===
2013/1/10:18:06:57 Yosef #2 YOSEFSLAPTOP2 === Setup started on YOSEFSLAPTOP2 by Yosef #2 ===
2013/1/10:18:06:57 Yosef #2 YOSEFSLAPTOP2 Launch
2013/1/10:18:07:27 Yosef #2 YOSEFSLAPTOP2 Download Play SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/SET...
2013/1/10:18:08:04 Yosef #2 YOSEFSLAPTOP2 Download Complete SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/SET...
2013/1/10:18:08:04 Yosef #2 YOSEFSLAPTOP2 PageOpen LaunchDialog
2013/1/10:18:08:22 Yosef #2 YOSEFSLAPTOP2 PageOpen LicenseDialog
2013/1/10:18:08:22 Yosef #2 YOSEFSLAPTOP2 PageOpen ProductInfoDialog
2013/1/10:18:08:22 Yosef #2 YOSEFSLAPTOP2 PageOpen ProductSelectionDialog2
2013/1/10:18:13:21 Yosef #2 YOSEFSLAPTOP2 PageOpen FullProgressDialog
2013/1/10:18:13:22 Yosef #2 YOSEFSLAPTOP2 Download Play VCREDIST2010SP1X86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/VCR...
2013/1/10:18:13:23 Yosef #2 YOSEFSLAPTOP2 Download Complete VCREDIST2010SP1X86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/VCR...
2013/1/10:18:13:23 Yosef #2 YOSEFSLAPTOP2 Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): C:\Autodesk\WI\AutoCAD 2013\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe /q /norestart /l C:\Users\YOSEF#~1\AppData\Local\Temp\vcredist_x86_2010.log
2013/1/10:18:13:31 Yosef #2 YOSEFSLAPTOP2 Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded
2013/1/10:18:13:31 Yosef #2 YOSEFSLAPTOP2 Download Play VCREDIST2010SP1X64 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/VCR...
2013/1/10:18:13:32 Yosef #2 YOSEFSLAPTOP2 Download Complete VCREDIST2010SP1X64 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/VCR...
2013/1/10:18:13:32 Yosef #2 YOSEFSLAPTOP2 Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): C:\Autodesk\WI\AutoCAD 2013\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe /q /norestart /l C:\Users\YOSEF#~1\AppData\Local\Temp\vcredist_x64_2010.log
2013/1/10:18:13:40 Yosef #2 YOSEFSLAPTOP2 Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Succeeded
2013/1/10:18:13:40 Yosef #2 YOSEFSLAPTOP2 Download Play DIRECTX http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/DIR...
2013/1/10:18:13:45 Yosef #2 YOSEFSLAPTOP2 Download Complete DIRECTX http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/DIR...
2013/1/10:18:13:45 Yosef #2 YOSEFSLAPTOP2 Installing DirectX Runtime: C:\Autodesk\WI\AutoCAD 2013\3rdParty\DirectX\DXSETUP.exe /silent
2013/1/10:18:14:33 Yosef #2 YOSEFSLAPTOP2 Install DirectX Runtime Succeeded
2013/1/10:18:14:33 Yosef #2 YOSEFSLAPTOP2 Installing FaroSDK: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:18:14:49 Yosef #2 YOSEFSLAPTOP2 Install FaroSDK Succeeded
2013/1/10:18:14:49 Yosef #2 YOSEFSLAPTOP2 Download Play CM2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/CM2...
2013/1/10:18:15:10 Yosef #2 YOSEFSLAPTOP2 Download Complete CM2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/CM2...
2013/1/10:18:15:10 Yosef #2 YOSEFSLAPTOP2 Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:18:15:50 Yosef #2 YOSEFSLAPTOP2 Install Autodesk Material Library 2013 Succeeded
2013/1/10:18:15:50 Yosef #2 YOSEFSLAPTOP2 Download Play CMILB2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/CMI...
2013/1/10:18:15:55 Yosef #2 YOSEFSLAPTOP2 Download Error CMILB2013 <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/CMI...
2013/1/10:18:16:16 Yosef #2 YOSEFSLAPTOP2 Download Error CMILB2013 <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/CMI...
2013/1/10:18:17:07 Yosef #2 YOSEFSLAPTOP2 Download Error CMILB2013 <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/CMI...
2013/1/10:18:17:07 Yosef #2 YOSEFSLAPTOP2 Download Paused CMILB2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/CMI...
2013/1/10:18:17:54 Yosef #2 YOSEFSLAPTOP2 Download User Resume CMILB2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/CMI...
2013/1/10:18:18:41 Yosef #2 YOSEFSLAPTOP2 Download Complete CMILB2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/CMI...
2013/1/10:18:18:41 Yosef #2 YOSEFSLAPTOP2 Installing Autodesk Material Library 2013 - Low Resolution: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:18:19:18 Yosef #2 YOSEFSLAPTOP2 Install Autodesk Material Library 2013 - Low Resolution Succeeded
2013/1/10:18:19:18 Yosef #2 YOSEFSLAPTOP2 Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\WI\AutoCAD 2013\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:18:19:26 Yosef #2 YOSEFSLAPTOP2 Install Autodesk Content Service Succeeded
2013/1/10:18:19:26 Yosef #2 YOSEFSLAPTOP2 Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:18:19:37 Yosef #2 YOSEFSLAPTOP2 Install Autodesk Content Service Language Pack Succeeded
2013/1/10:18:19:37 Yosef #2 YOSEFSLAPTOP2 Download Play ACAD http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/ACA...
2013/1/10:18:19:42 Yosef #2 YOSEFSLAPTOP2 Download Error ACAD <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/ACA...
2013/1/10:18:20:03 Yosef #2 YOSEFSLAPTOP2 Download Error ACAD <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/ACA...
2013/1/10:18:23:18 Yosef #2 YOSEFSLAPTOP2 Download Complete ACAD http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/ACA...
2013/1/10:18:23:19 Yosef #2 YOSEFSLAPTOP2 Installing AutoCAD® 2013: TRANSFORMS="C:\Autodesk\WI\AutoCAD 2013\x64\en-us\acad\acad.mst;C:\Users\YOSEF#~1\AppData\Local\Temp\_AIAC87.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:18:28:28 Yosef #2 YOSEFSLAPTOP2 Install AutoCAD® 2013 Succeeded
2013/1/10:18:28:28 Yosef #2 YOSEFSLAPTOP2 Download Play ACAD_en-us http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/ACA...
2013/1/10:18:28:34 Yosef #2 YOSEFSLAPTOP2 Download Error ACAD_en-us <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/ACA...
2013/1/10:18:28:54 Yosef #2 YOSEFSLAPTOP2 Download Error ACAD_en-us <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/ACA...
2013/1/10:18:30:45 Yosef #2 YOSEFSLAPTOP2 Download Complete ACAD_en-us http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/ACA...
2013/1/10:18:30:45 Yosef #2 YOSEFSLAPTOP2 Installing AutoCAD® 2013 Language Pack: TRANSFORMS="C:\Users\YOSEF#~1\AppData\Local\Temp\_AIAC87.tmp\_la7A8D.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us MUIHIDEARP=1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:18:31:19 Yosef #2 YOSEFSLAPTOP2 Install AutoCAD® 2013 Language Pack Succeeded
2013/1/10:18:31:19 Yosef #2 YOSEFSLAPTOP2 Download Skipped ACAD_PSPACK http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/ACA...
2013/1/10:18:31:19 Yosef #2 YOSEFSLAPTOP2 Installing AutoCAD® 2013 Product Specific Pack: INSTALLSHORTCUTS=0 ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:18:31:50 Yosef #2 YOSEFSLAPTOP2 Install AutoCAD® 2013 Product Specific Pack Succeeded
2013/1/10:18:31:50 Yosef #2 YOSEFSLAPTOP2 Installing Autodesk Cloud sync: ADLANGUAGE=en-us ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:18:31:55 Yosef #2 YOSEFSLAPTOP2 Install Autodesk Cloud sync Succeeded
2013/1/10:18:31:56 Yosef #2 YOSEFSLAPTOP2 Download Play VCREDIST2005SP1ATLX86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/VCR...
2013/1/10:18:31:56 Yosef #2 YOSEFSLAPTOP2 Download Complete VCREDIST2005SP1ATLX86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/VCR...
2013/1/10:18:31:56 Yosef #2 YOSEFSLAPTOP2 Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): C:\Autodesk\WI\AutoCAD 2013\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\YOSEF#~1\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/1/10:18:31:58 Yosef #2 YOSEFSLAPTOP2 Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1603
2013/1/10:18:31:58 Yosef #2 YOSEFSLAPTOP2 Rollback Autodesk Cloud sync Failed Failure is ignored, Result=1603
2013/1/10:18:32:08 Yosef #2 YOSEFSLAPTOP2 Rollback AutoCAD® 2013 Product Specific Pack Succeeded
2013/1/10:18:32:22 Yosef #2 YOSEFSLAPTOP2 Rollback AutoCAD® 2013 Language Pack Succeeded
2013/1/10:18:33:25 Yosef #2 YOSEFSLAPTOP2 Rollback AutoCAD® 2013 Succeeded
2013/1/10:18:33:29 Yosef #2 YOSEFSLAPTOP2 Rollback Autodesk Content Service Language Pack Succeeded
2013/1/10:18:33:38 Yosef #2 YOSEFSLAPTOP2 Rollback Autodesk Content Service Succeeded
2013/1/10:18:33:43 Yosef #2 YOSEFSLAPTOP2 Rollback Autodesk Material Library 2013 - Low Resolution Succeeded
2013/1/10:18:34:32 Yosef #2 YOSEFSLAPTOP2 Rollback Autodesk Material Library 2013 Succeeded
2013/1/10:18:34:35 Yosef #2 YOSEFSLAPTOP2 Rollback FaroSDK Succeeded
2013/1/10:18:34:35 Yosef #2 YOSEFSLAPTOP2 Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2013/1/10:18:34:35 Yosef #2 YOSEFSLAPTOP2 Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x64) Failed Installation aborted, Result=1619
2013/1/10:18:34:35 Yosef #2 YOSEFSLAPTOP2 Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1619
2013/1/10:18:34:38 Yosef #2 YOSEFSLAPTOP2 PageOpen InstallCompleteDialog
2013/1/10:18:35:10 Yosef #2 YOSEFSLAPTOP2 === Setup ended ===
2013/1/10:18:44:26 Yosef #2 YOSEFSLAPTOP2 === Setup started on YOSEFSLAPTOP2 by Yosef #2 ===
2013/1/10:18:44:26 Yosef #2 YOSEFSLAPTOP2 Launch
2013/1/10:18:44:26 Yosef #2 YOSEFSLAPTOP2 CommandLine /url "http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/AutoCAD_2013_English_Win_32_64bit_wi_en-US..." /SN 900-35927844 /PK 001E1 /student /skipEULA /akamai /auth /sid
2013/1/10:18:45:03 Yosef #2 YOSEFSLAPTOP2 === Setup ended ===
2013/1/10:18:44:27 Yosef #2 YOSEFSLAPTOP2 === Setup started on YOSEFSLAPTOP2 by Yosef #2 ===
2013/1/10:18:44:27 Yosef #2 YOSEFSLAPTOP2 Launch
2013/1/10:18:44:30 Yosef #2 YOSEFSLAPTOP2 Download Play SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/SET...
2013/1/10:18:45:02 Yosef #2 YOSEFSLAPTOP2 Download Complete SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/SET...
2013/1/10:18:45:03 Yosef #2 YOSEFSLAPTOP2 PageOpen LaunchDialog
2013/1/10:18:46:26 Yosef #2 YOSEFSLAPTOP2 PageOpen LicenseDialog
2013/1/10:18:46:26 Yosef #2 YOSEFSLAPTOP2 PageOpen ProductInfoDialog
2013/1/10:18:46:26 Yosef #2 YOSEFSLAPTOP2 PageOpen ProductSelectionDialog2
2013/1/10:18:47:46 Yosef #2 YOSEFSLAPTOP2 PageOpen FullProgressDialog
2013/1/10:18:47:46 Yosef #2 YOSEFSLAPTOP2 Download Play DIRECTX http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/DIR...
2013/1/10:18:47:50 Yosef #2 YOSEFSLAPTOP2 Download Complete DIRECTX http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/DIR...
2013/1/10:18:47:50 Yosef #2 YOSEFSLAPTOP2 Installing DirectX Runtime: C:\Autodesk\WI\AutoCAD 2013\3rdParty\DirectX\DXSETUP.exe /silent
2013/1/10:18:48:29 Yosef #2 YOSEFSLAPTOP2 Install DirectX Runtime Succeeded
2013/1/10:18:48:29 Yosef #2 YOSEFSLAPTOP2 Installing FaroSDK: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:18:48:40 Yosef #2 YOSEFSLAPTOP2 Install FaroSDK Succeeded
2013/1/10:18:48:40 Yosef #2 YOSEFSLAPTOP2 Download Play CM2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/CM2...
2013/1/10:18:48:57 Yosef #2 YOSEFSLAPTOP2 Download Complete CM2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/CM2...
2013/1/10:18:48:57 Yosef #2 YOSEFSLAPTOP2 Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:18:49:36 Yosef #2 YOSEFSLAPTOP2 Install Autodesk Material Library 2013 Succeeded
2013/1/10:18:49:36 Yosef #2 YOSEFSLAPTOP2 Download Play CMILB2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/CMI...
2013/1/10:18:49:54 Yosef #2 YOSEFSLAPTOP2 Download Complete CMILB2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/CMI...
2013/1/10:18:49:54 Yosef #2 YOSEFSLAPTOP2 Installing Autodesk Material Library 2013 - Low Resolution: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:18:50:36 Yosef #2 YOSEFSLAPTOP2 Install Autodesk Material Library 2013 - Low Resolution Succeeded
2013/1/10:18:50:36 Yosef #2 YOSEFSLAPTOP2 Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\WI\AutoCAD 2013\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:18:50:44 Yosef #2 YOSEFSLAPTOP2 Install Autodesk Content Service Succeeded
2013/1/10:18:50:44 Yosef #2 YOSEFSLAPTOP2 Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:18:50:50 Yosef #2 YOSEFSLAPTOP2 Install Autodesk Content Service Language Pack Succeeded
2013/1/10:18:50:50 Yosef #2 YOSEFSLAPTOP2 Download Play ACAD http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/ACA...
2013/1/10:18:52:15 Yosef #2 YOSEFSLAPTOP2 Download Error ACAD <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/ACA...
2013/1/10:18:54:14 Yosef #2 YOSEFSLAPTOP2 Download Complete ACAD http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/ACA...
2013/1/10:18:54:15 Yosef #2 YOSEFSLAPTOP2 Installing AutoCAD® 2013: TRANSFORMS="C:\Autodesk\WI\AutoCAD 2013\x64\en-us\acad\acad.mst;C:\Users\YOSEF#~1\AppData\Local\Temp\_AI254.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:18:59:52 Yosef #2 YOSEFSLAPTOP2 Install AutoCAD® 2013 Succeeded
2013/1/10:18:59:53 Yosef #2 YOSEFSLAPTOP2 Download Play ACAD_en-us http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/ACA...
2013/1/10:19:00:49 Yosef #2 YOSEFSLAPTOP2 Download Complete ACAD_en-us http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/ACA...
2013/1/10:19:00:50 Yosef #2 YOSEFSLAPTOP2 Installing AutoCAD® 2013 Language Pack: TRANSFORMS="C:\Users\YOSEF#~1\AppData\Local\Temp\_AI254.tmp\_la2FD.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us MUIHIDEARP=1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:19:01:32 Yosef #2 YOSEFSLAPTOP2 Install AutoCAD® 2013 Language Pack Succeeded
2013/1/10:19:01:32 Yosef #2 YOSEFSLAPTOP2 Download Skipped ACAD_PSPACK http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/ACA...
2013/1/10:19:01:32 Yosef #2 YOSEFSLAPTOP2 Installing AutoCAD® 2013 Product Specific Pack: INSTALLSHORTCUTS=0 ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:19:02:08 Yosef #2 YOSEFSLAPTOP2 Install AutoCAD® 2013 Product Specific Pack Succeeded
2013/1/10:19:02:08 Yosef #2 YOSEFSLAPTOP2 Download Play VCREDIST2005SP1ATLX86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/VCR...
2013/1/10:19:02:09 Yosef #2 YOSEFSLAPTOP2 Download Complete VCREDIST2005SP1ATLX86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/VCR...
2013/1/10:19:02:09 Yosef #2 YOSEFSLAPTOP2 Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): C:\Autodesk\WI\AutoCAD 2013\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\YOSEF#~1\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/1/10:19:02:11 Yosef #2 YOSEFSLAPTOP2 Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1603
2013/1/10:19:02:24 Yosef #2 YOSEFSLAPTOP2 Rollback AutoCAD® 2013 Product Specific Pack Succeeded
2013/1/10:19:02:38 Yosef #2 YOSEFSLAPTOP2 Rollback AutoCAD® 2013 Language Pack Succeeded
2013/1/10:19:03:51 Yosef #2 YOSEFSLAPTOP2 Rollback AutoCAD® 2013 Succeeded
2013/1/10:19:03:56 Yosef #2 YOSEFSLAPTOP2 Rollback Autodesk Content Service Language Pack Succeeded
2013/1/10:19:04:05 Yosef #2 YOSEFSLAPTOP2 Rollback Autodesk Content Service Succeeded
2013/1/10:19:04:09 Yosef #2 YOSEFSLAPTOP2 Rollback Autodesk Material Library 2013 - Low Resolution Succeeded
2013/1/10:19:04:58 Yosef #2 YOSEFSLAPTOP2 Rollback Autodesk Material Library 2013 Succeeded
2013/1/10:19:05:01 Yosef #2 YOSEFSLAPTOP2 Rollback FaroSDK Succeeded
2013/1/10:19:05:01 Yosef #2 YOSEFSLAPTOP2 Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2013/1/10:19:05:03 Yosef #2 YOSEFSLAPTOP2 PageOpen InstallCompleteDialog
2013/1/10:20:13:15 Yosef #2 YOSEFSLAPTOP2 === Setup ended ===
2013/1/10:20:14:36 Yosef #2 YOSEFSLAPTOP2 === Setup started on YOSEFSLAPTOP2 by Yosef #2 ===
2013/1/10:20:14:36 Yosef #2 YOSEFSLAPTOP2 Launch
2013/1/10:20:14:36 Yosef #2 YOSEFSLAPTOP2 CommandLine /url "http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/AutoCAD_2013_English_Win_32_64bit_wi_en-US..." /SN 900-35927844 /PK 001E1 /student /skipEULA /akamai /auth /sid
2013/1/10:20:15:22 Yosef #2 YOSEFSLAPTOP2 === Setup ended ===
2013/1/10:20:14:37 Yosef #2 YOSEFSLAPTOP2 === Setup started on YOSEFSLAPTOP2 by Yosef #2 ===
2013/1/10:20:14:37 Yosef #2 YOSEFSLAPTOP2 Launch
2013/1/10:20:14:41 Yosef #2 YOSEFSLAPTOP2 Download Play SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/SET...
2013/1/10:20:15:22 Yosef #2 YOSEFSLAPTOP2 Download Complete SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/SET...
2013/1/10:20:15:22 Yosef #2 YOSEFSLAPTOP2 PageOpen LaunchDialog
2013/1/10:20:17:44 Yosef #2 YOSEFSLAPTOP2 PageOpen LicenseDialog
2013/1/10:20:17:44 Yosef #2 YOSEFSLAPTOP2 PageOpen ProductInfoDialog
2013/1/10:20:17:44 Yosef #2 YOSEFSLAPTOP2 PageOpen ProductSelectionDialog2
2013/1/10:20:17:48 Yosef #2 YOSEFSLAPTOP2 PageOpen FullProgressDialog
2013/1/10:20:17:49 Yosef #2 YOSEFSLAPTOP2 Download Play DIRECTX http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/DIR...
2013/1/10:20:17:55 Yosef #2 YOSEFSLAPTOP2 Download Complete DIRECTX http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/DIR...
2013/1/10:20:17:55 Yosef #2 YOSEFSLAPTOP2 Installing DirectX Runtime: C:\Autodesk\WI\AutoCAD 2013\3rdParty\DirectX\DXSETUP.exe /silent
2013/1/10:20:18:38 Yosef #2 YOSEFSLAPTOP2 Install DirectX Runtime Succeeded
2013/1/10:20:18:38 Yosef #2 YOSEFSLAPTOP2 Installing FaroSDK: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:20:18:52 Yosef #2 YOSEFSLAPTOP2 Install FaroSDK Succeeded
2013/1/10:20:18:52 Yosef #2 YOSEFSLAPTOP2 Download Play CM2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/CM2...
2013/1/10:20:19:13 Yosef #2 YOSEFSLAPTOP2 Download Complete CM2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/CM2...
2013/1/10:20:19:13 Yosef #2 YOSEFSLAPTOP2 Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:20:19:50 Yosef #2 YOSEFSLAPTOP2 Install Autodesk Material Library 2013 Succeeded
2013/1/10:20:19:51 Yosef #2 YOSEFSLAPTOP2 Download Play CMILB2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/CMI...
2013/1/10:20:20:10 Yosef #2 YOSEFSLAPTOP2 Download Complete CMILB2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/CMI...
2013/1/10:20:20:10 Yosef #2 YOSEFSLAPTOP2 Installing Autodesk Material Library 2013 - Low Resolution: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:20:21:06 Yosef #2 YOSEFSLAPTOP2 Install Autodesk Material Library 2013 - Low Resolution Succeeded
2013/1/10:20:21:06 Yosef #2 YOSEFSLAPTOP2 Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\WI\AutoCAD 2013\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:20:21:16 Yosef #2 YOSEFSLAPTOP2 Install Autodesk Content Service Succeeded
2013/1/10:20:21:16 Yosef #2 YOSEFSLAPTOP2 Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:20:21:23 Yosef #2 YOSEFSLAPTOP2 Install Autodesk Content Service Language Pack Succeeded
2013/1/10:20:21:23 Yosef #2 YOSEFSLAPTOP2 Download Play ACAD http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/ACA...
2013/1/10:20:21:57 Yosef #2 YOSEFSLAPTOP2 Download Error ACAD <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/ACA...
2013/1/10:20:23:51 Yosef #2 YOSEFSLAPTOP2 Download Complete ACAD http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/ACA...
2013/1/10:20:23:53 Yosef #2 YOSEFSLAPTOP2 Installing AutoCAD® 2013: TRANSFORMS="C:\Autodesk\WI\AutoCAD 2013\x64\en-us\acad\acad.mst;C:\Users\YOSEF#~1\AppData\Local\Temp\_AI918A.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:20:29:52 Yosef #2 YOSEFSLAPTOP2 Install AutoCAD® 2013 Succeeded
2013/1/10:20:29:52 Yosef #2 YOSEFSLAPTOP2 Download Play ACAD_en-us http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/ACA...
2013/1/10:20:30:43 Yosef #2 YOSEFSLAPTOP2 Download Complete ACAD_en-us http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/ACA...
2013/1/10:20:30:43 Yosef #2 YOSEFSLAPTOP2 Installing AutoCAD® 2013 Language Pack: TRANSFORMS="C:\Users\YOSEF#~1\AppData\Local\Temp\_AI918A.tmp\_la5024.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us MUIHIDEARP=1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:20:31:24 Yosef #2 YOSEFSLAPTOP2 Install AutoCAD® 2013 Language Pack Succeeded
2013/1/10:20:31:24 Yosef #2 YOSEFSLAPTOP2 Download Skipped ACAD_PSPACK http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/ACA...
2013/1/10:20:31:24 Yosef #2 YOSEFSLAPTOP2 Installing AutoCAD® 2013 Product Specific Pack: INSTALLSHORTCUTS=0 ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:20:32:18 Yosef #2 YOSEFSLAPTOP2 Install AutoCAD® 2013 Product Specific Pack Succeeded
2013/1/10:20:32:18 Yosef #2 YOSEFSLAPTOP2 Download Play VCREDIST2005SP1ATLX86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/VCR...
2013/1/10:20:32:22 Yosef #2 YOSEFSLAPTOP2 Download Complete VCREDIST2005SP1ATLX86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/VCR...
2013/1/10:20:32:22 Yosef #2 YOSEFSLAPTOP2 Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): C:\Autodesk\WI\AutoCAD 2013\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\YOSEF#~1\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/1/10:20:32:23 Yosef #2 YOSEFSLAPTOP2 Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1603
2013/1/10:20:32:35 Yosef #2 YOSEFSLAPTOP2 Rollback AutoCAD® 2013 Product Specific Pack Succeeded
2013/1/10:20:32:53 Yosef #2 YOSEFSLAPTOP2 Rollback AutoCAD® 2013 Language Pack Succeeded
2013/1/10:20:34:11 Yosef #2 YOSEFSLAPTOP2 Rollback AutoCAD® 2013 Succeeded
2013/1/10:20:34:16 Yosef #2 YOSEFSLAPTOP2 Rollback Autodesk Content Service Language Pack Succeeded
2013/1/10:20:34:27 Yosef #2 YOSEFSLAPTOP2 Rollback Autodesk Content Service Succeeded
2013/1/10:20:34:31 Yosef #2 YOSEFSLAPTOP2 Rollback Autodesk Material Library 2013 - Low Resolution Succeeded
2013/1/10:20:35:27 Yosef #2 YOSEFSLAPTOP2 Rollback Autodesk Material Library 2013 Succeeded
2013/1/10:20:35:30 Yosef #2 YOSEFSLAPTOP2 Rollback FaroSDK Succeeded
2013/1/10:20:35:30 Yosef #2 YOSEFSLAPTOP2 Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2013/1/10:20:35:32 Yosef #2 YOSEFSLAPTOP2 PageOpen InstallCompleteDialog
2013/1/10:20:47:06 Yosef #2 YOSEFSLAPTOP2 === Setup ended ===
2013/1/10:21:41:11 Yosef #2 YOSEFSLAPTOP2 === Setup started on YOSEFSLAPTOP2 by Yosef #2 ===
2013/1/10:21:41:11 Yosef #2 YOSEFSLAPTOP2 Launch
2013/1/10:21:41:11 Yosef #2 YOSEFSLAPTOP2 CommandLine /url "http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/AutoCAD_2013_English_Win_32_64bit_wi_en-US..." /SN 900-35927844 /PK 001E1 /student /skipEULA /akamai /auth /sid
2013/1/10:21:41:17 Yosef #2 YOSEFSLAPTOP2 === Setup ended ===
2013/1/10:21:41:12 Yosef #2 YOSEFSLAPTOP2 === Setup started on YOSEFSLAPTOP2 by Yosef #2 ===
2013/1/10:21:41:12 Yosef #2 YOSEFSLAPTOP2 Launch
2013/1/10:21:41:16 Yosef #2 YOSEFSLAPTOP2 Download Skipped SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/SET...
2013/1/10:21:41:17 Yosef #2 YOSEFSLAPTOP2 PageOpen LaunchDialog
2013/1/10:21:41:30 Yosef #2 YOSEFSLAPTOP2 PageOpen LicenseDialog
2013/1/10:21:41:30 Yosef #2 YOSEFSLAPTOP2 PageOpen ProductInfoDialog
2013/1/10:21:41:30 Yosef #2 YOSEFSLAPTOP2 PageOpen ProductSelectionDialog2
2013/1/10:21:41:36 Yosef #2 YOSEFSLAPTOP2 PageOpen FullProgressDialog
2013/1/10:21:41:37 Yosef #2 YOSEFSLAPTOP2 Download Play VCREDIST2010SP1X86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/VCR...
2013/1/10:21:41:47 Yosef #2 YOSEFSLAPTOP2 Download Complete VCREDIST2010SP1X86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/VCR...
2013/1/10:21:41:47 Yosef #2 YOSEFSLAPTOP2 Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): C:\Autodesk\WI\AutoCAD 2013\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe /q /norestart /l C:\Users\YOSEF#~1\AppData\Local\Temp\vcredist_x86_2010.log
2013/1/10:21:41:53 Yosef #2 YOSEFSLAPTOP2 Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded
2013/1/10:21:41:53 Yosef #2 YOSEFSLAPTOP2 Download Play VCREDIST2010SP1X64 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/VCR...
2013/1/10:21:42:03 Yosef #2 YOSEFSLAPTOP2 Download Complete VCREDIST2010SP1X64 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/VCR...
2013/1/10:21:42:03 Yosef #2 YOSEFSLAPTOP2 Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): C:\Autodesk\WI\AutoCAD 2013\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe /q /norestart /l C:\Users\YOSEF#~1\AppData\Local\Temp\vcredist_x64_2010.log
2013/1/10:21:42:09 Yosef #2 YOSEFSLAPTOP2 Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Succeeded
2013/1/10:21:42:09 Yosef #2 YOSEFSLAPTOP2 Download Skipped DIRECTX http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/DIR...
2013/1/10:21:42:09 Yosef #2 YOSEFSLAPTOP2 Installing DirectX Runtime: C:\Autodesk\WI\AutoCAD 2013\3rdParty\DirectX\DXSETUP.exe /silent
2013/1/10:21:42:49 Yosef #2 YOSEFSLAPTOP2 Install DirectX Runtime Succeeded
2013/1/10:21:42:49 Yosef #2 YOSEFSLAPTOP2 Installing FaroSDK: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:21:43:02 Yosef #2 YOSEFSLAPTOP2 Install FaroSDK Succeeded
2013/1/10:21:43:03 Yosef #2 YOSEFSLAPTOP2 Download Skipped CM2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/CM2...
2013/1/10:21:43:03 Yosef #2 YOSEFSLAPTOP2 Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:21:43:52 Yosef #2 YOSEFSLAPTOP2 Install Autodesk Material Library 2013 Succeeded
2013/1/10:21:43:52 Yosef #2 YOSEFSLAPTOP2 Download Skipped CMILB2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/CMI...
2013/1/10:21:43:52 Yosef #2 YOSEFSLAPTOP2 Installing Autodesk Material Library 2013 - Low Resolution: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:21:44:12 Yosef #2 YOSEFSLAPTOP2 Install Autodesk Material Library 2013 - Low Resolution Succeeded
2013/1/10:21:44:12 Yosef #2 YOSEFSLAPTOP2 Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\WI\AutoCAD 2013\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:21:44:24 Yosef #2 YOSEFSLAPTOP2 Install Autodesk Content Service Succeeded
2013/1/10:21:44:24 Yosef #2 YOSEFSLAPTOP2 Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:21:44:33 Yosef #2 YOSEFSLAPTOP2 Install Autodesk Content Service Language Pack Succeeded
2013/1/10:21:44:33 Yosef #2 YOSEFSLAPTOP2 Download Skipped ACAD http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/ACA...
2013/1/10:21:44:34 Yosef #2 YOSEFSLAPTOP2 Installing AutoCAD® 2013: TRANSFORMS="C:\Autodesk\WI\AutoCAD 2013\x64\en-us\acad\acad.mst;C:\Users\YOSEF#~1\AppData\Local\Temp\_AID4F1.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:21:50:52 Yosef #2 YOSEFSLAPTOP2 Install AutoCAD® 2013 Succeeded
2013/1/10:21:50:53 Yosef #2 YOSEFSLAPTOP2 Download Skipped ACAD_en-us http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/ACA...
2013/1/10:21:50:54 Yosef #2 YOSEFSLAPTOP2 Installing AutoCAD® 2013 Language Pack: TRANSFORMS="C:\Users\YOSEF#~1\AppData\Local\Temp\_AID4F1.tmp\_laB569.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us MUIHIDEARP=1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:21:52:01 Yosef #2 YOSEFSLAPTOP2 Install AutoCAD® 2013 Language Pack Succeeded
2013/1/10:21:52:01 Yosef #2 YOSEFSLAPTOP2 Download Skipped ACAD_PSPACK http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/ACA...
2013/1/10:21:52:01 Yosef #2 YOSEFSLAPTOP2 Installing AutoCAD® 2013 Product Specific Pack: INSTALLSHORTCUTS=0 ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:21:52:30 Yosef #2 YOSEFSLAPTOP2 Install AutoCAD® 2013 Product Specific Pack Succeeded
2013/1/10:21:52:30 Yosef #2 YOSEFSLAPTOP2 Installing Autodesk Cloud sync: ADLANGUAGE=en-us ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:21:52:36 Yosef #2 YOSEFSLAPTOP2 Install Autodesk Cloud sync Succeeded
2013/1/10:21:52:36 Yosef #2 YOSEFSLAPTOP2 Download Skipped VCREDIST2005SP1ATLX86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/VCR...
2013/1/10:21:52:36 Yosef #2 YOSEFSLAPTOP2 Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): C:\Autodesk\WI\AutoCAD 2013\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\YOSEF#~1\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/1/10:21:52:42 Yosef #2 YOSEFSLAPTOP2 Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1603
2013/1/10:21:52:42 Yosef #2 YOSEFSLAPTOP2 Rollback Autodesk Cloud sync Failed Failure is ignored, Result=1603
2013/1/10:21:52:53 Yosef #2 YOSEFSLAPTOP2 Rollback AutoCAD® 2013 Product Specific Pack Succeeded
2013/1/10:21:53:07 Yosef #2 YOSEFSLAPTOP2 Rollback AutoCAD® 2013 Language Pack Succeeded
2013/1/10:21:54:25 Yosef #2 YOSEFSLAPTOP2 Rollback AutoCAD® 2013 Succeeded
2013/1/10:21:54:29 Yosef #2 YOSEFSLAPTOP2 Rollback Autodesk Content Service Language Pack Succeeded
2013/1/10:21:54:38 Yosef #2 YOSEFSLAPTOP2 Rollback Autodesk Content Service Succeeded
2013/1/10:21:55:02 Yosef #2 YOSEFSLAPTOP2 Rollback Autodesk Material Library 2013 - Low Resolution Succeeded
2013/1/10:21:55:50 Yosef #2 YOSEFSLAPTOP2 Rollback Autodesk Material Library 2013 Succeeded
2013/1/10:21:55:53 Yosef #2 YOSEFSLAPTOP2 Rollback FaroSDK Succeeded
2013/1/10:21:55:53 Yosef #2 YOSEFSLAPTOP2 Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2013/1/10:21:55:53 Yosef #2 YOSEFSLAPTOP2 Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x64) Failed Installation aborted, Result=1619
2013/1/10:21:55:53 Yosef #2 YOSEFSLAPTOP2 Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1619
2013/1/10:21:55:55 Yosef #2 YOSEFSLAPTOP2 PageOpen InstallCompleteDialog
2013/1/10:21:56:12 Yosef #2 YOSEFSLAPTOP2 === Setup ended ===
2013/1/10:22:28:32 Yosef #2 YOSEFSLAPTOP2 === Setup started on YOSEFSLAPTOP2 by Yosef #2 ===
2013/1/10:22:28:32 Yosef #2 YOSEFSLAPTOP2 Launch
2013/1/10:22:28:32 Yosef #2 YOSEFSLAPTOP2 CommandLine /url "http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/AutoCAD_2013_English_Win_32_64bit_wi_en-US..." /SN 900-35927844 /PK 001E1 /student /skipEULA /akamai /auth /sid
2013/1/10:22:30:13 Yosef #2 YOSEFSLAPTOP2 === Setup ended ===
2013/1/10:22:28:33 Yosef #2 YOSEFSLAPTOP2 === Setup started on YOSEFSLAPTOP2 by Yosef #2 ===
2013/1/10:22:28:33 Yosef #2 YOSEFSLAPTOP2 Launch
2013/1/10:22:28:36 Yosef #2 YOSEFSLAPTOP2 Download Play SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/SET...
2013/1/10:22:30:12 Yosef #2 YOSEFSLAPTOP2 Download Complete SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/SET...
2013/1/10:22:30:13 Yosef #2 YOSEFSLAPTOP2 PageOpen LaunchDialog
2013/1/10:22:30:31 Yosef #2 YOSEFSLAPTOP2 PageOpen LicenseDialog
2013/1/10:22:30:31 Yosef #2 YOSEFSLAPTOP2 PageOpen ProductInfoDialog
2013/1/10:22:30:31 Yosef #2 YOSEFSLAPTOP2 PageOpen ProductSelectionDialog2
2013/1/10:22:30:50 Yosef #2 YOSEFSLAPTOP2 PageOpen FullProgressDialog
2013/1/10:22:30:50 Yosef #2 YOSEFSLAPTOP2 Download Play VCREDIST2008SP1X86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/VCR...
2013/1/10:22:30:57 Yosef #2 YOSEFSLAPTOP2 Download Complete VCREDIST2008SP1X86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/VCR...
2013/1/10:22:30:57 Yosef #2 YOSEFSLAPTOP2 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): C:\Autodesk\WI\AutoCAD 2013\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q
2013/1/10:22:31:01 Yosef #2 YOSEFSLAPTOP2 Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded
2013/1/10:22:31:01 Yosef #2 YOSEFSLAPTOP2 Download Play VCREDIST2008SP1X64 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/VCR...
2013/1/10:22:31:03 Yosef #2 YOSEFSLAPTOP2 Download Complete VCREDIST2008SP1X64 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/VCR...
2013/1/10:22:31:03 Yosef #2 YOSEFSLAPTOP2 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): C:\Autodesk\WI\AutoCAD 2013\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe /q
2013/1/10:22:31:07 Yosef #2 YOSEFSLAPTOP2 Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Succeeded
2013/1/10:22:31:07 Yosef #2 YOSEFSLAPTOP2 Download Play VCREDIST2010SP1X86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/VCR...
2013/1/10:22:31:11 Yosef #2 YOSEFSLAPTOP2 Download Complete VCREDIST2010SP1X86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/VCR...
2013/1/10:22:31:11 Yosef #2 YOSEFSLAPTOP2 Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): C:\Autodesk\WI\AutoCAD 2013\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe /q /norestart /l C:\Users\YOSEF#~1\AppData\Local\Temp\vcredist_x86_2010.log
2013/1/10:22:31:18 Yosef #2 YOSEFSLAPTOP2 Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded
2013/1/10:22:31:18 Yosef #2 YOSEFSLAPTOP2 Download Play VCREDIST2010SP1X64 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/VCR...
2013/1/10:22:31:21 Yosef #2 YOSEFSLAPTOP2 Download Complete VCREDIST2010SP1X64 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/VCR...
2013/1/10:22:31:21 Yosef #2 YOSEFSLAPTOP2 Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): C:\Autodesk\WI\AutoCAD 2013\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe /q /norestart /l C:\Users\YOSEF#~1\AppData\Local\Temp\vcredist_x64_2010.log
2013/1/10:22:31:28 Yosef #2 YOSEFSLAPTOP2 Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Succeeded
2013/1/10:22:31:28 Yosef #2 YOSEFSLAPTOP2 Download Play DIRECTX http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/DIR...
2013/1/10:22:31:44 Yosef #2 YOSEFSLAPTOP2 Download Complete DIRECTX http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/DIR...
2013/1/10:22:31:44 Yosef #2 YOSEFSLAPTOP2 Installing DirectX Runtime: C:\Autodesk\WI\AutoCAD 2013\3rdParty\DirectX\DXSETUP.exe /silent
2013/1/10:22:32:21 Yosef #2 YOSEFSLAPTOP2 Install DirectX Runtime Succeeded
2013/1/10:22:32:21 Yosef #2 YOSEFSLAPTOP2 Installing FaroSDK: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:22:32:35 Yosef #2 YOSEFSLAPTOP2 Install FaroSDK Succeeded
2013/1/10:22:32:35 Yosef #2 YOSEFSLAPTOP2 Download Play CM2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/CM2...
2013/1/10:22:33:23 Yosef #2 YOSEFSLAPTOP2 Download Complete CM2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/CM2...
2013/1/10:22:33:23 Yosef #2 YOSEFSLAPTOP2 Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:22:33:44 Yosef #2 YOSEFSLAPTOP2 Install Autodesk Material Library 2013 Succeeded
2013/1/10:22:33:44 Yosef #2 YOSEFSLAPTOP2 Download Play CMILB2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/CMI...
2013/1/10:22:34:58 Yosef #2 YOSEFSLAPTOP2 Download Complete CMILB2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/CMI...
2013/1/10:22:34:58 Yosef #2 YOSEFSLAPTOP2 Installing Autodesk Material Library 2013 - Low Resolution: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:22:35:13 Yosef #2 YOSEFSLAPTOP2 Install Autodesk Material Library 2013 - Low Resolution Succeeded
2013/1/10:22:35:13 Yosef #2 YOSEFSLAPTOP2 Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\WI\AutoCAD 2013\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:22:35:25 Yosef #2 YOSEFSLAPTOP2 Install Autodesk Content Service Succeeded
2013/1/10:22:35:25 Yosef #2 YOSEFSLAPTOP2 Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:22:35:32 Yosef #2 YOSEFSLAPTOP2 Install Autodesk Content Service Language Pack Succeeded
2013/1/10:22:35:32 Yosef #2 YOSEFSLAPTOP2 Download Play ACAD http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/ACA...
2013/1/10:22:41:06 Yosef #2 YOSEFSLAPTOP2 Download Complete ACAD http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/ACA...
2013/1/10:22:41:08 Yosef #2 YOSEFSLAPTOP2 Installing AutoCAD® 2013: TRANSFORMS="C:\Autodesk\WI\AutoCAD 2013\x64\en-us\acad\acad.mst;C:\Users\YOSEF#~1\AppData\Local\Temp\_AI2E67.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:22:47:36 Yosef #2 YOSEFSLAPTOP2 Install AutoCAD® 2013 Succeeded
2013/1/10:22:47:36 Yosef #2 YOSEFSLAPTOP2 Download Play ACAD_en-us http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/ACA...
2013/1/10:22:48:45 Yosef #2 YOSEFSLAPTOP2 Download Complete ACAD_en-us http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/ACA...
2013/1/10:22:48:46 Yosef #2 YOSEFSLAPTOP2 Installing AutoCAD® 2013 Language Pack: TRANSFORMS="C:\Users\YOSEF#~1\AppData\Local\Temp\_AI2E67.tmp\_laB31F.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us MUIHIDEARP=1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:22:49:25 Yosef #2 YOSEFSLAPTOP2 Install AutoCAD® 2013 Language Pack Succeeded
2013/1/10:22:49:25 Yosef #2 YOSEFSLAPTOP2 Download Skipped ACAD_PSPACK http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/ACA...
2013/1/10:22:49:25 Yosef #2 YOSEFSLAPTOP2 Installing AutoCAD® 2013 Product Specific Pack: INSTALLSHORTCUTS=0 ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:22:50:04 Yosef #2 YOSEFSLAPTOP2 Install AutoCAD® 2013 Product Specific Pack Succeeded
2013/1/10:22:50:04 Yosef #2 YOSEFSLAPTOP2 Installing Autodesk Cloud sync: ADLANGUAGE=en-us ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:22:50:10 Yosef #2 YOSEFSLAPTOP2 Install Autodesk Cloud sync Succeeded
2013/1/10:22:50:10 Yosef #2 YOSEFSLAPTOP2 Download Play VCREDIST2005SP1ATLX86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/VCR...
2013/1/10:22:50:17 Yosef #2 YOSEFSLAPTOP2 Download Complete VCREDIST2005SP1ATLX86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/VCR...
2013/1/10:22:50:17 Yosef #2 YOSEFSLAPTOP2 Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): C:\Autodesk\WI\AutoCAD 2013\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\YOSEF#~1\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/1/10:22:50:20 Yosef #2 YOSEFSLAPTOP2 Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1603
2013/1/10:22:50:20 Yosef #2 YOSEFSLAPTOP2 Rollback Autodesk Cloud sync Failed Failure is ignored, Result=1603
2013/1/10:22:50:31 Yosef #2 YOSEFSLAPTOP2 Rollback AutoCAD® 2013 Product Specific Pack Succeeded
2013/1/10:22:50:45 Yosef #2 YOSEFSLAPTOP2 Rollback AutoCAD® 2013 Language Pack Succeeded
2013/1/10:22:52:08 Yosef #2 YOSEFSLAPTOP2 Rollback AutoCAD® 2013 Succeeded
2013/1/10:22:52:13 Yosef #2 YOSEFSLAPTOP2 Rollback Autodesk Content Service Language Pack Succeeded
2013/1/10:22:52:22 Yosef #2 YOSEFSLAPTOP2 Rollback Autodesk Content Service Succeeded
2013/1/10:22:52:47 Yosef #2 YOSEFSLAPTOP2 Rollback Autodesk Material Library 2013 - Low Resolution Succeeded
2013/1/10:22:53:28 Yosef #2 YOSEFSLAPTOP2 Rollback Autodesk Material Library 2013 Succeeded
2013/1/10:22:53:31 Yosef #2 YOSEFSLAPTOP2 Rollback FaroSDK Succeeded
2013/1/10:22:53:31 Yosef #2 YOSEFSLAPTOP2 Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2013/1/10:22:53:31 Yosef #2 YOSEFSLAPTOP2 Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x64) Failed Installation aborted, Result=1619
2013/1/10:22:53:31 Yosef #2 YOSEFSLAPTOP2 Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1619
2013/1/10:22:53:34 Yosef #2 YOSEFSLAPTOP2 PageOpen InstallCompleteDialog
2013/1/10:22:55:04 Yosef #2 YOSEFSLAPTOP2 === Setup ended ===
2013/1/10:23:13:42 Yosef #2 YOSEFSLAPTOP2 === Setup started on YOSEFSLAPTOP2 by Yosef #2 ===
2013/1/10:23:13:42 Yosef #2 YOSEFSLAPTOP2 Launch
2013/1/10:23:13:42 Yosef #2 YOSEFSLAPTOP2 CommandLine /url "http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/AutoCAD_2013_English_Win_32_64bit_wi_en-US..." /SN 900-35927844 /PK 001E1 /student /skipEULA /akamai /auth /sid
2013/1/10:23:13:46 Yosef #2 YOSEFSLAPTOP2 === Setup ended ===
2013/1/10:23:13:43 Yosef #2 YOSEFSLAPTOP2 === Setup started on YOSEFSLAPTOP2 by Yosef #2 ===
2013/1/10:23:13:43 Yosef #2 YOSEFSLAPTOP2 Launch
2013/1/10:23:13:45 Yosef #2 YOSEFSLAPTOP2 Download Skipped SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/SET...
2013/1/10:23:13:46 Yosef #2 YOSEFSLAPTOP2 PageOpen LaunchDialog
2013/1/10:23:13:58 Yosef #2 YOSEFSLAPTOP2 PageOpen LicenseDialog
2013/1/10:23:13:58 Yosef #2 YOSEFSLAPTOP2 PageOpen ProductInfoDialog
2013/1/10:23:13:58 Yosef #2 YOSEFSLAPTOP2 PageOpen ProductSelectionDialog2
2013/1/10:23:14:05 Yosef #2 YOSEFSLAPTOP2 PageOpen FullProgressDialog
2013/1/10:23:14:06 Yosef #2 YOSEFSLAPTOP2 Download Skipped VCREDIST2008SP1X86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/VCR...
2013/1/10:23:14:06 Yosef #2 YOSEFSLAPTOP2 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): C:\Autodesk\WI\AutoCAD 2013\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q
2013/1/10:23:14:09 Yosef #2 YOSEFSLAPTOP2 Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded
2013/1/10:23:14:09 Yosef #2 YOSEFSLAPTOP2 Download Skipped VCREDIST2008SP1X64 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/VCR...
2013/1/10:23:14:09 Yosef #2 YOSEFSLAPTOP2 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): C:\Autodesk\WI\AutoCAD 2013\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe /q
2013/1/10:23:14:13 Yosef #2 YOSEFSLAPTOP2 Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Succeeded
2013/1/10:23:14:13 Yosef #2 YOSEFSLAPTOP2 Download Skipped VCREDIST2010SP1X86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/VCR...
2013/1/10:23:14:13 Yosef #2 YOSEFSLAPTOP2 Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): C:\Autodesk\WI\AutoCAD 2013\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe /q /norestart /l C:\Users\YOSEF#~1\AppData\Local\Temp\vcredist_x86_2010.log
2013/1/10:23:14:22 Yosef #2 YOSEFSLAPTOP2 Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded
2013/1/10:23:14:22 Yosef #2 YOSEFSLAPTOP2 Download Skipped VCREDIST2010SP1X64 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/VCR...
2013/1/10:23:14:22 Yosef #2 YOSEFSLAPTOP2 Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): C:\Autodesk\WI\AutoCAD 2013\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe /q /norestart /l C:\Users\YOSEF#~1\AppData\Local\Temp\vcredist_x64_2010.log
2013/1/10:23:14:37 Yosef #2 YOSEFSLAPTOP2 Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Succeeded
2013/1/10:23:14:37 Yosef #2 YOSEFSLAPTOP2 Download Skipped DIRECTX http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/DIR...
2013/1/10:23:14:37 Yosef #2 YOSEFSLAPTOP2 Installing DirectX Runtime: C:\Autodesk\WI\AutoCAD 2013\3rdParty\DirectX\DXSETUP.exe /silent
2013/1/10:23:15:12 Yosef #2 YOSEFSLAPTOP2 Install DirectX Runtime Succeeded
2013/1/10:23:15:12 Yosef #2 YOSEFSLAPTOP2 Installing FaroSDK: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:23:15:27 Yosef #2 YOSEFSLAPTOP2 Install FaroSDK Succeeded
2013/1/10:23:15:27 Yosef #2 YOSEFSLAPTOP2 Download Skipped CM2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/CM2...
2013/1/10:23:15:27 Yosef #2 YOSEFSLAPTOP2 Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:23:16:07 Yosef #2 YOSEFSLAPTOP2 Install Autodesk Material Library 2013 Succeeded
2013/1/10:23:16:07 Yosef #2 YOSEFSLAPTOP2 Download Skipped CMILB2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/CMI...
2013/1/10:23:16:07 Yosef #2 YOSEFSLAPTOP2 Installing Autodesk Material Library 2013 - Low Resolution: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:23:16:26 Yosef #2 YOSEFSLAPTOP2 Install Autodesk Material Library 2013 - Low Resolution Succeeded
2013/1/10:23:16:26 Yosef #2 YOSEFSLAPTOP2 Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\WI\AutoCAD 2013\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:23:16:39 Yosef #2 YOSEFSLAPTOP2 Install Autodesk Content Service Succeeded
2013/1/10:23:16:39 Yosef #2 YOSEFSLAPTOP2 Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:23:16:47 Yosef #2 YOSEFSLAPTOP2 Install Autodesk Content Service Language Pack Succeeded
2013/1/10:23:16:47 Yosef #2 YOSEFSLAPTOP2 Download Skipped ACAD http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/ACA...
2013/1/10:23:16:48 Yosef #2 YOSEFSLAPTOP2 Installing AutoCAD® 2013: TRANSFORMS="C:\Autodesk\WI\AutoCAD 2013\x64\en-us\acad\acad.mst;C:\Users\YOSEF#~1\AppData\Local\Temp\_AI89E0.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:23:23:14 Yosef #2 YOSEFSLAPTOP2 Install AutoCAD® 2013 Succeeded
2013/1/10:23:23:14 Yosef #2 YOSEFSLAPTOP2 Download Skipped ACAD_en-us http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/ACA...
2013/1/10:23:23:15 Yosef #2 YOSEFSLAPTOP2 Installing AutoCAD® 2013 Language Pack: TRANSFORMS="C:\Users\YOSEF#~1\AppData\Local\Temp\_AI89E0.tmp\_la43A3.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us MUIHIDEARP=1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:23:24:27 Yosef #2 YOSEFSLAPTOP2 Install AutoCAD® 2013 Language Pack Succeeded
2013/1/10:23:24:27 Yosef #2 YOSEFSLAPTOP2 Download Skipped ACAD_PSPACK http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/ACA...
2013/1/10:23:24:27 Yosef #2 YOSEFSLAPTOP2 Installing AutoCAD® 2013 Product Specific Pack: INSTALLSHORTCUTS=0 ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:23:24:55 Yosef #2 YOSEFSLAPTOP2 Install AutoCAD® 2013 Product Specific Pack Succeeded
2013/1/10:23:24:55 Yosef #2 YOSEFSLAPTOP2 Installing Autodesk Cloud sync: ADLANGUAGE=en-us ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:23:25:01 Yosef #2 YOSEFSLAPTOP2 Install Autodesk Cloud sync Succeeded
2013/1/10:23:25:01 Yosef #2 YOSEFSLAPTOP2 Download Skipped VCREDIST2005SP1ATLX86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/VCR...
2013/1/10:23:25:01 Yosef #2 YOSEFSLAPTOP2 Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): C:\Autodesk\WI\AutoCAD 2013\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\YOSEF#~1\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/1/10:23:25:10 Yosef #2 YOSEFSLAPTOP2 Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1603
2013/1/10:23:25:10 Yosef #2 YOSEFSLAPTOP2 Rollback Autodesk Cloud sync Failed Failure is ignored, Result=1603
2013/1/10:23:25:19 Yosef #2 YOSEFSLAPTOP2 Rollback AutoCAD® 2013 Product Specific Pack Succeeded
2013/1/10:23:25:32 Yosef #2 YOSEFSLAPTOP2 Rollback AutoCAD® 2013 Language Pack Succeeded
2013/1/10:23:26:55 Yosef #2 YOSEFSLAPTOP2 Rollback AutoCAD® 2013 Succeeded
2013/1/10:23:27:00 Yosef #2 YOSEFSLAPTOP2 Rollback Autodesk Content Service Language Pack Succeeded
2013/1/10:23:27:08 Yosef #2 YOSEFSLAPTOP2 Rollback Autodesk Content Service Succeeded
2013/1/10:23:27:34 Yosef #2 YOSEFSLAPTOP2 Rollback Autodesk Material Library 2013 - Low Resolution Succeeded
2013/1/10:23:28:15 Yosef #2 YOSEFSLAPTOP2 Rollback Autodesk Material Library 2013 Succeeded
2013/1/10:23:28:18 Yosef #2 YOSEFSLAPTOP2 Rollback FaroSDK Succeeded
2013/1/10:23:28:18 Yosef #2 YOSEFSLAPTOP2 Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2013/1/10:23:28:18 Yosef #2 YOSEFSLAPTOP2 Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x64) Failed Installation aborted, Result=1619
2013/1/10:23:28:18 Yosef #2 YOSEFSLAPTOP2 Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed
6 REPLIES 6
ymaynie
in reply to: ymaynie
Me again. I promised the Fusion error log, so here it is as well.
Inventor Fusion Failure Log:
2013/1/10:23:28:18 Yosef #2 YOSEFSLAPTOP2 Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1619
DarrenP
look here: http://forums.autodesk.com/t5/forums/searchpage/tab/message?q=error+1619
DarrenP
ymaynie
in reply to: DarrenP
I have looked through the list you sent. I'm not trying to be insulting, but there don't seem to be any solutions, just more people asking similar questions.
DarrenP
the first link offers this solution: http://forums.autodesk.com/t5/Installation-Licensing/Error-1603-and-1619-installing-Revit-Architectu...#
DarrenP
DarrenP
which takes you here: http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/m-p/3...
DarrenP
ymaynie
I did the C++ thing already, multiple times. It still won't download.
Also, I must be dumber than I thought, because I can not figure this out. Anything more specific you could suggest?
Administrator Productivity
