Installation & Licensing
*Pierson, John
Message 1 of 3 (550 Views)
AutoCAD hangs during open
550 Views, 2 Replies
01-11-2000 03:57 PM
<<< Message <85g0ad$7l819@adesknews2.autodesk.com> was originally posted to 'autodesk.autocad.r14general' on Tue, 11 Jan 2000 13:26:44 -0600.>>>
We recently switched our file server to a NT4.0 (SP5) network. We also use
a netowrk version of AutoCADr14.01. Sometimes while opening an AutoCAD
drawing, AutoCAD will start to open the file, and then hang at about 93%.
The length of the hang varies, but usually lasts at least a minute. The
drawings in question have never done this before the network switch.
Has anyone ever seen a problem like this? If so, how do I go about fixing
it?
TIA
John
*Januszkiewicz, Alex
Message 2 of 3 (550 Views)
Re: AutoCAD hangs during open
01-12-2000 06:44 PM in reply to: *Pierson, John
Something could change in this file since it was last time opened locally.
Check if you move it back from network to local drive you don't get delay at
93%. If you do, the problem now is in the file not in the network.
Alex Januszkiewicz
Intelcad Systems and 911 DWG Recovery Services
http://www.intelcad.com
*Check out our DWF => DWG converter*
**The FASTEST Xref Re-path program on the planet**
* ObjectARX, OpenDWG, WhipTK, MDL *
John Pierson wrote in message <85gg0s$99q17@adesknews2.autodesk.com>...
>it?
>TIA
>John
*Pierson, John
Message 3 of 3 (550 Views)
Re:
01-13-2000 08:29 AM in reply to: *Pierson, John
It does not happen on a regular basis and it does not always happen with the
same files. Several users aren't even accessing the same directory or
xrefs. I can't seem to find any logical reasons for it.
John
"Alex Januszkiewicz" wrote in message
news:85je9d$ge06@adesknews2.autodesk.com...
at
> Alex Januszkiewicz
to
use
fixing
> >it?
> >TIA
> >John
