Installation & Licensing
autocad electrical error 1603 y 1619
1 REPLY 1
880 Views, 1 Reply
Buenas tardes amigos, soy un estudiante español y no consigo instalar su producto Autocad Electrical en mi pc. Después de haber instalado todos los componentes del paquete no instala el autocad electrical y me da error de framwork. He probado a desinstalar el programa framework pero me sigue negando la instalación. Me podrian dar alguna solución? Gracias y un saludo
2012/11/25:19:08:29 Irraky IRRAKY-PC PageOpen ProductInfoDialog
   2012/11/25:19:08:58 Irraky IRRAKY-PC PageOpen ProductSelectionDialog2
   2012/11/25:19:12:44 Irraky IRRAKY-PC PageOpen FullProgressDialog
  2012/11/25:19:12:45 Irraky IRRAKY-PC Installing .NET Framework Runtime 4.0: C:\autodeskirraky\AutoCAD_Electrical_2013_Spanish_Win_32-64bit_dlm\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q
2012/11/25:19:20:47 Irraky IRRAKY-PC Install .NET Framework Runtime 4.0 Succeeded  2012/11/25:19:20:47 Irraky IRRAKY-PC Installing .NET Framework Runtime 4.0 Language Pack: C:\autodeskirraky\AutoCAD_Electrical_2013_Spanish_Win_32-64bit_dlm\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_1034.exe /q
2012/11/25:19:23:44 Irraky IRRAKY-PC Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=1603
2012/11/25:19:23:44 Irraky IRRAKY-PC Rollback .NET Framework Runtime 4.0 Failed Installation aborted, Result=1619
1 REPLY 1
zalant
Given the error you're getting, I suspect that you might be encountering the problem due to the service pack. The issue is detailed here:
http://upandready.typepad.com/up_and_ready/2012/10/error-ngenexe-and-installing-any-autocad-product....
If it’s that problem, try installing without the SP included (configuration screen during the installation setup).  If that works, try installing the service pack after the installation completes.
Zac Travis
Administrator Productivity
