i have aproblem with autocad electrical 2012 x-64 in setup
the error message is :::
CRC failed in x64\Acade\Program Files\Autodesk\Root\AcPublish.arx
The file "???" header is corrupt
I downloaded it in 6 hours and it's too long time for downloading it agian
i hope to get help from experts here
thank you
Edited by
Discussion_Admin
Please try
I found The solution .it's in copying process
i copied the source file in flash memory and the i copied it again to another computer
the copying process seems tobe not correct so some files are missed or damaged
i deleted the coppied one from flash memory
and i copy the source file from the main computer to flashmemory again
it seems tobe work
Thank's
