I have a network installation and I thought the install had gone well. When I went to the deploy folder from a client comptuer I received an error. The error read "cannot access device or file specified. ...AutoCad2011/adminimage/support/FaroSDK/faro_ls.msi"
Is there a way to get the folder without starting the install all over again?
Any guidance would be appreciated.
JG
Solved by hashim.mundol. Go to Solution.
it could be due to various reason. whole path is longer that 260 characters , there is a network permissions/communication issue or deployment process didn't complete successfully.
you have to restart the installation process if it fails, there is retry option. Sorry 😞
