Installation & Licensing
AutoCAD Civil 3D, Microsoft C++ libraries. Error 1935 and Windows 7
4 REPLIES 4
david.lau
7705 Views, 4 Replies
Recently, I had resolved the following issue with an installation of AutoCAD Civil 3D 2011 on Windows 7 (32 bit).  It would not install the Microsoft C++ 2005 and 2008 libraries.   We even tried to install the VCRedist manually by going into the following folder and there was a 1935 error.
  • x86-or-x64\support\VCRedist\2005
  • x86-or-x64\support\VCRedist\2008
The solution was to set the Windows size Registry to unlimited for this component to install.
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control
Key: RegistrySizeLimit
Type: REG_DWORD
Value (Hexidecimal): 0xffffff
or
Value (Decimal):  4294967295
David Lau
4 REPLIES 4
david.lau
in reply to: david.lau
david.lau
The final tip is to download and install the Civil 2011 Update 1 afterwards.  Do not include the update during initial installation in via Configuration Wizard.
http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=9240698
David Lau
Solution works... thanks
yuver000
Good Morning
I have a problem, Its the next.
Microsoft Visual C++ 2005 Redistributable (x86)    Failed    Installation aborted, Result=1619
Its showed in the txt.log
Can you help me please?
Administrator Productivity
