Recently, I had resolved the following issue with an installation of AutoCAD Civil 3D 2011 on Windows 7 (32 bit). It would not install the Microsoft C++ 2005 and 2008 libraries. We even tried to install the VCRedist manually by going into the following folder and there was a 1935 error.
The solution was to set the Windows size Registry to unlimited for this component to install.
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control
Key: RegistrySizeLimit
Type: REG_DWORD
Value (Hexidecimal): 0xffffff
or
Value (Decimal): 4294967295
See also this post:
The final tip is to download and install the Civil 2011 Update 1 afterwards. Do not include the update during initial installation in via Configuration Wizard.
http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=9240698
Good Morning
I have a problem, Its the next.
Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619
Its showed in the txt.log
Can you help me please?
