Installation & Licensing
Product Support
david.lau
Message 1 of 5 (6,081 Views)
AutoCAD Civil 3D, Microsoft C++ libraries. Error 1935 and Windows 7
6081 Views, 4 Replies
12-06-2010 11:58 AM
Recently, I had resolved the following issue with an installation of AutoCAD Civil 3D 2011 on Windows 7 (32 bit).  It would not install the Microsoft C++ 2005 and 2008 libraries.   We even tried to install the VCRedist manually by going into the following folder and there was a 1935 error.
  • x86-or-x64\support\VCRedist\2005
  • x86-or-x64\support\VCRedist\2008
The solution was to set the Windows size Registry to unlimited for this component to install.
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control
Key: RegistrySizeLimit
Type: REG_DWORD
Value (Hexidecimal): 0xffffff
or
Value (Decimal):  4294967295
David Lau
Product Support
david.lau
Message 2 of 5 (6,075 Views)
Re: AutoCAD Civil 3D, Microsoft C++ libraries. Error 1935 and Windows 7
12-06-2010 12:01 PM in reply to: david.lau
Product Support
david.lau
Message 3 of 5 (6,064 Views)
12-06-2010 01:14 PM in reply to: david.lau
The final tip is to download and install the Civil 2011 Update 1 afterwards.  Do not include the update during initial installation in via Configuration Wizard.
http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=9240698
David Lau
New Member
ahmadreza27051972
Message 4 of 5 (1,186 Views)
06-04-2013 05:27 AM in reply to: david.lau
Solution works... thanks
New Member
yuver000
Message 5 of 5 (291 Views)
Microsoft Visual C++ 2005 Redistributable (x86) Failed, Result=1619
06-28-2014 07:57 AM in reply to: ahmadreza27051972
Good Morning
I have a problem, Its the next.
Microsoft Visual C++ 2005 Redistributable (x86)    Failed    Installation aborted, Result=1619
Its showed in the txt.log
Can you help me please?
