Installation & Licensing
AutoCAD Civil 3D 2014 install errors
17 REPLIES 17
Message 1 of 18
vcoleman
4023 Views, 17 Replies
<->I have tried for a week to install civil 3d 2014.  When I deploy I receive 1722 error.  My log file says: Autodesk Civil 3d 2014 product specific pak failed installation aborted, result=1603.  Also Microsoft Visual Basic Power Packs 10.0 Failure is ignored, result=1619.  Also DirectX Runtime Failed Failur is ignored, result=1619.  Any ideas.
My OS is Window 7.  I am currently using version civil 3d 2011.
I have tried deployment from CD and also download.  I also tried to install on my computer.  I get the same errors no matter how I try to install this program.
Any ideas
17 REPLIES 17
Message 2 of 18
c-not-k
in reply to: vcoleman
I have the same problem, although I'm trying to install Infrastructure Design Premium 2014. It fails on the Civil 3D 2014 install.
I've uninstalled all the C++ and VB programs, as well as uninstalled my anti-virus client (McAfee). This is on a HP Z400 running Windows 7-64. This box used to have (and run without problem) Civil 3D 2012, which I uninstalled prior to attempting to install ID.
-Marc
Message 3 of 18
TravisNave
in reply to: c-not-k
Post your installation log file.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Message 4 of 18
c-not-k
in reply to: TravisNave
See attached. (I hope. I don't see an attachment, even though I selected it.)
Interestingly, I just successfully installed Infrastructure Design 2013 on the same computer!
-Marc
Message 5 of 18
TravisNave
Try it again.  It didn't attach.
Autodesk Forums:
Message 6 of 18
c-not-k
Once again...
-Marc
Message 7 of 18
c-not-k
I don't see it this time, either. I'll change the extension from LOG to TXT and see if that helps...
-Marc
Message 8 of 18
c-not-k
Sorry 'bout the length, but here it is inline...
2013/8/7:14:59:16 md1lanadmin MD1-1201 === Setup started on MD1-1201 by md1lanadmin ===
2013/8/7:14:59:16 md1lanadmin MD1-1201 Path_Length: 155
2013/8/7:14:59:16 md1lanadmin MD1-1201 Current Directory \\md1dc3\mis\Install\ID\2014\Img
2013/8/7:14:59:16 md1lanadmin MD1-1201 Launch
2013/8/7:14:59:16 md1lanadmin MD1-1201 CommandLine /qb /I \\md1dc3\mis\Install\ID\2014\Img\ID2014.ini /language en-us
2013/8/7:14:59:16 md1lanadmin MD1-1201 Current Directory C:\Temp\_AID97.tmp
2013/8/7:14:59:42 md1lanadmin MD1-1201 === Setup ended ===
2013/8/7:14:59:19 md1lanadmin MD1-1201 === Setup started on MD1-1201 by md1lanadmin ===
2013/8/7:14:59:19 md1lanadmin MD1-1201 Path_Length: 155
2013/8/7:14:59:19 md1lanadmin MD1-1201 Current Directory C:\Temp\_AID97.tmp
2013/8/7:14:59:19 md1lanadmin MD1-1201 Launch
2013/8/7:14:59:20 md1lanadmin MD1-1201 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Temp\_AID97.tmp\Setup\AcSetup.dll
2013/8/7:14:59:20 md1lanadmin MD1-1201 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/8/7:14:59:41 md1lanadmin MD1-1201 Install CustomCallback Info Invoking custom callback for details: [IM] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Temp\_AID97.tmp\Setup\IMSetupUi.dll
2013/8/7:14:59:41 md1lanadmin MD1-1201 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/8/7:14:59:42 md1lanadmin MD1-1201 Installing Microsoft Visual C++ 2005 Redistributable (x86): "\\md1dc3\mis\Install\ID\2014\Img\3rdParty\x86\VCRedist\2005\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Temp\vcredist_x86_2005.log"" "
2013/8/7:14:59:46 md1lanadmin MD1-1201 Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded
2013/8/7:14:59:47 md1lanadmin MD1-1201 Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x86):   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® Infrastructure Design Suite Premium 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="\\md1dc3\mis\Install\ID\2014\Img\" ADLM_EULA_COUNTRY=US FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Temp\_AID97.tmp\Media.mst"
 2013/8/7:14:59:49 md1lanadmin MD1-1201 Install Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded
2013/8/7:14:59:49 md1lanadmin MD1-1201 Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x86):   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® Infrastructure Design Suite Premium 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="\\md1dc3\mis\Install\ID\2014\Img\" ADLM_EULA_COUNTRY=US FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Temp\_AID97.tmp\Media.mst"
 2013/8/7:14:59:53 md1lanadmin MD1-1201 Install Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded
2013/8/7:14:59:54 md1lanadmin MD1-1201 Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x86):   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® Infrastructure Design Suite Premium 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="\\md1dc3\mis\Install\ID\2014\Img\" ADLM_EULA_COUNTRY=US FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Temp\_AID97.tmp\Media.mst"
 2013/8/7:14:59:57 md1lanadmin MD1-1201 Install Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded
2013/8/7:14:59:57 md1lanadmin MD1-1201 Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86):   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® Infrastructure Design Suite Premium 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="\\md1dc3\mis\Install\ID\2014\Img\" ADLM_EULA_COUNTRY=US FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Temp\_AID97.tmp\Media.mst"
 2013/8/7:14:59:59 md1lanadmin MD1-1201 Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded
2013/8/7:14:59:59 md1lanadmin MD1-1201 Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x64):   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® Infrastructure Design Suite Premium 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="\\md1dc3\mis\Install\ID\2014\Img\" ADLM_EULA_COUNTRY=US FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Temp\_AID97.tmp\Media.mst"
 2013/8/7:15:00:01 md1lanadmin MD1-1201 Install Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded
2013/8/7:15:00:01 md1lanadmin MD1-1201 Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x64):   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® Infrastructure Design Suite Premium 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="\\md1dc3\mis\Install\ID\2014\Img\" ADLM_EULA_COUNTRY=US FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Temp\_AID97.tmp\Media.mst"
 2013/8/7:15:00:06 md1lanadmin MD1-1201 Install Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded
2013/8/7:15:00:06 md1lanadmin MD1-1201 Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x64):   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® Infrastructure Design Suite Premium 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="\\md1dc3\mis\Install\ID\2014\Img\" ADLM_EULA_COUNTRY=US FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Temp\_AID97.tmp\Media.mst"
 2013/8/7:15:00:09 md1lanadmin MD1-1201 Install Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded
2013/8/7:15:00:09 md1lanadmin MD1-1201 Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64):   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® Infrastructure Design Suite Premium 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="\\md1dc3\mis\Install\ID\2014\Img\" ADLM_EULA_COUNTRY=US FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Temp\_AID97.tmp\Media.mst"
 2013/8/7:15:00:12 md1lanadmin MD1-1201 Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded
2013/8/7:15:00:12 md1lanadmin MD1-1201 Installing DirectX Runtime: "\\md1dc3\mis\Install\ID\2014\Img\3rdParty\DirectX\DXSETUP.exe" /silent
2013/8/7:15:01:45 md1lanadmin MD1-1201 Install DirectX Runtime Succeeded
2013/8/7:15:01:45 md1lanadmin MD1-1201 Installing FARO LS 5.1.0.30630:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® Infrastructure Design Suite Premium 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="\\md1dc3\mis\Install\ID\2014\Img\" ADLM_EULA_COUNTRY=US FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/8/7:15:01:52 md1lanadmin MD1-1201 Install FARO LS 5.1.0.30630 Succeeded
2013/8/7:15:01:52 md1lanadmin MD1-1201 Installing Autodesk® Revit® Structure 2014:  TRANSFORMS="\\md1dc3\mis\Install\ID\2014\Img\x64\en-us\RST2014\RST2014.mst;\\md1dc3\mis\Install\ID\2014\Img\x64\..." ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® Infrastructure Design Suite Premium 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=",Internet Explorer 7,SSE2 Support Check,Microsoft Visual C++ 2008 SP1 Redistributable (x64),Microsoft Visual C++ 2008 SP1 Redistributable (x64) 9.0.30729.6161,Microsoft Visual C++ 2005 Redistributable (x86),Microsoft Visual C++ 2005 Redistributable (x64),Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2008 SP1 Redistributable (x86) 9.0.30729.6161,Microsoft Visual C++ 2010 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x64),{04B34E21-5BEE-3D2B-8D3D-E3E80D253F64},{B42E259C-E4D4-37F1-A1B2-EB9C4FC5A04D},{14866AAD-1F23-39AC-A62B-7091ED1ADE64},{4B90093A-5D9C-3956-8ABB-95848BE6EFAD},{C3A57BB3-9AA6-3F6F-9395-6C062BDD5FC4},{6DA2B636-698A-3294-BF4A-B5E11B238CDD},{F6F09DD8-F39B-3A16-ADB9-C9E6B56903F9},{8CCEA24C-51AE-3B71-9092-7D0C44DDA2DF},Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86),Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64),.NET Framework Runtime 3.5 SP1,.NET Framework Runtime 4.5,.NET Framework Runtime 4.5 Language pack,DirectX Runtime,{8A470330-70B2-49AD-86AF-79885EF9898A},;{11672AB2-3D48-4D38-9123-719E5FF93333},{644F9B19-A462-499C-BF4D-300ABC2A28B1},{51BF3210-B825-4092-8E0D-66D689916E02},{5C29CC1F-218F-4C30-948A-11066CAC59FB},;;" ADSK_SOURCE_ROOT="\\md1dc3\mis\Install\ID\2014\Img\" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/8/7:15:06:32 md1lanadmin MD1-1201 Install Autodesk® Revit® Structure 2014 Succeeded
2013/8/7:15:06:33 md1lanadmin MD1-1201 Installing Autodesk® Revit® Structure 2014 Language Pack:  TRANSFORMS="C:\Temp\_AID97.tmp\_laB887.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® Infrastructure Design Suite Premium 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;" MUIHIDEARP=1 ADSK_SOURCE_ROOT="\\md1dc3\mis\Install\ID\2014\Img\" ADLM_EULA_COUNTRY=US INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/8/7:15:06:42 md1lanadmin MD1-1201 Install Autodesk® Revit® Structure 2014 Language Pack Succeeded
2013/8/7:15:06:43 md1lanadmin MD1-1201 Installing Autodesk Material Library 2014:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® Infrastructure Design Suite Premium 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="\\md1dc3\mis\Install\ID\2014\Img\" ADLM_EULA_COUNTRY=US FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Temp\_AID97.tmp\Media.mst"
 2013/8/7:15:06:56 md1lanadmin MD1-1201 Install Autodesk Material Library 2014 Succeeded
2013/8/7:15:06:56 md1lanadmin MD1-1201 Installing Autodesk Material Library 2014 - Base Image Library:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® Infrastructure Design Suite Premium 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="\\md1dc3\mis\Install\ID\2014\Img\" ADLM_EULA_COUNTRY=US FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Temp\_AID97.tmp\Media.mst"
 2013/8/7:15:07:05 md1lanadmin MD1-1201 Install Autodesk Material Library 2014 - Base Image Library Succeeded
2013/8/7:15:07:06 md1lanadmin MD1-1201 Installing Autodesk Material Library 2014 - Low Image Library:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® Infrastructure Design Suite Premium 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x86),{644F9B19-A462-499C-BF4D-300ABC2A28B1},;;;" ADSK_SOURCE_ROOT="\\md1dc3\mis\Install\ID\2014\Img\" ADLM_EULA_COUNTRY=US FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Temp\_AID97.tmp\Media.mst"
 2013/8/7:15:07:22 md1lanadmin MD1-1201 Install Autodesk Material Library 2014 - Low Image Library Succeeded
2013/8/7:15:07:23 md1lanadmin MD1-1201 Installing FARO LS 5.1.0.30630 (64bit):   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® Infrastructure Design Suite Premium 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="\\md1dc3\mis\Install\ID\2014\Img\" ADLM_EULA_COUNTRY=US FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/8/7:15:07:23 md1lanadmin MD1-1201 Install FARO LS 5.1.0.30630 (64bit) Succeeded
2013/8/7:15:07:24 md1lanadmin MD1-1201 Installing Autodesk Content Service:  INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS=\\md1dc3\mis\Install\ID\2014\Img\x64\en-us\Tools\snap\ContentService.mst;C:\Temp\_AID97.tmp\Media.mst ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® Infrastructure Design Suite Premium 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x86),.NET Framework Runtime 4.0,;;;" ADSK_SOURCE_ROOT="\\md1dc3\mis\Install\ID\2014\Img\" ADLM_EULA_COUNTRY=US FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/8/7:15:07:34 md1lanadmin MD1-1201 Install Autodesk Content Service Failed Failure is ignored, Result=1603
2013/8/7:15:07:34 md1lanadmin MD1-1201 Installing Microsoft SQL Server Native Client 11.0:  IACCEPTSQLNCLILICENSETERMS=YES ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® Infrastructure Design Suite Premium 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="\\md1dc3\mis\Install\ID\2014\Img\" ADLM_EULA_COUNTRY=US FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Temp\_AID97.tmp\Media.mst"
 2013/8/7:15:07:38 md1lanadmin MD1-1201 Install Microsoft SQL Server Native Client 11.0 Succeeded
2013/8/7:15:07:38 md1lanadmin MD1-1201 Installing Autodesk® AutoCAD® Map 3D 2014:  TRANSFORMS="\\md1dc3\mis\Install\ID\2014\Img\x64\en-us\acadmap\acadmap.mst;\\md1dc3\mis\Install\ID\2014\Img\x64\..." MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® Infrastructure Design Suite Premium 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=".NET Framework Runtime 4.5,.NET Framework Runtime 4.5 Language pack,Block Vista version Check,SSE2 Support Check,.NET Framework Runtime 3.5 SP1,.NET Framework Runtime 4.0,.NET Framework Runtime 4.0 Language Pack,.NET Framework Runtime 4.0 KB2468871,Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2008 SP1 Redistributable (x64),Microsoft Visual C++ 2010 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x64),DirectX Runtime,{8A470330-70B2-49AD-86AF-79885EF9898A},{FF59CB23-1800-4047-B40C-E20AE7051491},Microsoft Windows Media Format 9.5 Series Runtime,{644F9B19-A462-499C-BF4D-300ABC2A28B1},{51BF3210-B825-4092-8E0D-66D689916E02},{62F029AB-85F2-0000-866A-9FC0DD99DDBC},{49D665A2-4C2A-476E-9AB8-FCC425F526FC},{2180B33F-3225-423E-BBC1-7798CFD3CD1F},;{5783F2D7-D002-0409-2102-0060B0CE6BBA},{52B28CAD-F49D-47BA-9FFE-29C2E85F0D0B},{644E9589-F73A-49A4-AC61-A953B9DE5669},;{C070121A-C8C5-4D52-9A7D-D240631BD433},{F732FEDA-7713-4428-934B-EF83B8DD65D0},{5783F2D7-D031-0409-0102-0060B0CE6BBA},;" ADSK_SOURCE_ROOT="\\md1dc3\mis\Install\ID\2014\Img\" INSTALLDIR="C:\Program Files\Autodesk\Autodesk AutoCAD Map 3D 2014\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/8/7:15:11:15 md1lanadmin MD1-1201 Install Autodesk® AutoCAD® Map 3D 2014 Succeeded
2013/8/7:15:11:16 md1lanadmin MD1-1201 Installing Autodesk® AutoCAD® Map 3D 2014 Language Pack:  TRANSFORMS="C:\Temp\_AID97.tmp\_la755.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® Infrastructure Design Suite Premium 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="\\md1dc3\mis\Install\ID\2014\Img\" ADLM_EULA_COUNTRY=US INSTALLDIR="C:\Program Files\Autodesk\Autodesk AutoCAD Map 3D 2014\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/8/7:15:13:35 md1lanadmin MD1-1201 Install Autodesk® AutoCAD® Map 3D 2014 Language Pack Succeeded
2013/8/7:15:13:35 md1lanadmin MD1-1201 Installing Autodesk® AutoCAD® Map 3D 2014 Product Specific Pack:  INSTALLSHORTCUTS=0 TRANSFORMS="C:\Temp\_AID97.tmp\_la755.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® Infrastructure Design Suite Premium 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="\\md1dc3\mis\Install\ID\2014\Img\" ADLM_EULA_COUNTRY=US INSTALLDIR="C:\Program Files\Autodesk\Autodesk AutoCAD Map 3D 2014\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/8/7:15:13:44 md1lanadmin MD1-1201 Install Autodesk® AutoCAD® Map 3D 2014 Product Specific Pack Succeeded
2013/8/7:15:13:44 md1lanadmin MD1-1201 Installing Microsoft Visual Basic Power Packs 10.0: "\\md1dc3\mis\Install\ID\2014\Img\3rdParty\VBPowerPacks10\VisualBasicPowerPacksSetup.exe" /q /l C:\Temp\VisualBasicPowerPacks10Setup.log
2013/8/7:15:13:48 md1lanadmin MD1-1201 Install Microsoft Visual Basic Power Packs 10.0 Succeeded
2013/8/7:15:13:48 md1lanadmin MD1-1201 Installing Autodesk AutoCAD® Civil 3D® 2014:  TRANSFORMS="\\md1dc3\mis\Install\ID\2014\Img\x64\en-us\C3D\C3D.mst;\\md1dc3\mis\Install\ID\2014\Img\x64\C3D\C3D-..." MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® Infrastructure Design Suite Premium 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=".NET Framework Runtime 4.5,.NET Framework Runtime 4.5 Language pack,Block Vista version Check,SSE2 Support Check,.NET Framework Runtime 3.5 SP1,.NET Framework Runtime 4.0,.NET Framework Runtime 4.0 Language Pack,.NET Framework Runtime 4.0 KB2468871,Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2008 SP1 Redistributable (x64),Microsoft Visual C++ 2010 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x64),DirectX Runtime,{8A470330-70B2-49AD-86AF-79885EF9898A},{FF59CB23-1800-4047-B40C-E20AE7051491},Microsoft Windows Media Format 9.5 Series Runtime,{644F9B19-A462-499C-BF4D-300ABC2A28B1},{51BF3210-B825-4092-8E0D-66D689916E02},{62F029AB-85F2-0000-866A-9FC0DD99DDBC},{3A9FC03D-C685-4831-94CF-4EDFD3749497},{D4AD39AD-091E-4D33-BB2B-59F6FCB8ADC3},Microsoft Visual Basic Power Packs 10.0,;{5783F2D7-D000-0409-2102-0060B0CE6BBA},{52B28CAD-F49D-47BA-9FFE-29C2E85F0D0B},{644E9589-F73A-49A4-AC61-A953B9DE5669},Autodesk AutoCAD® Civil 3D® 2014 64 bit Object Enabler,;Autodesk Geotechnical Module,{6BBA09C8-6B20-4115-B917-C09D8337AE09},{C070121A-C8C5-4D52-9A7D-D240631BD433},{F732FEDA-7713-4428-934B-EF83B8DD65D0},{5783F2D7-D031-0409-0102-0060B0CE6BBA},;" ADSK_SOURCE_ROOT="\\md1dc3\mis\Install\ID\2014\Img\" INSTALLDIR="C:\Program Files\Autodesk\Autodesk AutoCAD Civil 3D 2014\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/8/7:15:17:11 md1lanadmin MD1-1201 Install Autodesk AutoCAD® Civil 3D® 2014 Failed Installation aborted, Result=1603
2013/8/7:15:17:11 md1lanadmin MD1-1201 Rollback Microsoft Visual Basic Power Packs 10.0 Failed Failure is ignored, Result=1619
2013/8/7:15:17:16 md1lanadmin MD1-1201 Rollback Autodesk® AutoCAD® Map 3D 2014 Product Specific Pack Failed Installation aborted, Result=1603
2013/8/7:15:17:43 md1lanadmin MD1-1201 Rollback Autodesk® AutoCAD® Map 3D 2014 Language Pack Succeeded
2013/8/7:15:18:16 md1lanadmin MD1-1201 Rollback Autodesk® AutoCAD® Map 3D 2014 Succeeded
2013/8/7:15:18:18 md1lanadmin MD1-1201 Rollback Microsoft SQL Server Native Client 11.0 Succeeded
2013/8/7:15:18:20 md1lanadmin MD1-1201 Rollback FARO LS 5.1.0.30630 (64bit) Succeeded
2013/8/7:15:18:26 md1lanadmin MD1-1201 Rollback Autodesk Material Library 2014 - Low Image Library Succeeded
2013/8/7:15:18:32 md1lanadmin MD1-1201 Rollback Autodesk Material Library 2014 - Base Image Library Succeeded
2013/8/7:15:18:42 md1lanadmin MD1-1201 Rollback Autodesk Material Library 2014 Succeeded
2013/8/7:15:18:44 md1lanadmin MD1-1201 Rollback Autodesk® Revit® Structure 2014 Language Pack Succeeded
2013/8/7:15:19:39 md1lanadmin MD1-1201 Rollback Autodesk® Revit® Structure 2014 Succeeded
2013/8/7:15:19:39 md1lanadmin MD1-1201 Rollback FARO LS 5.1.0.30630 Failed Failure is ignored, Result=1605
2013/8/7:15:19:39 md1lanadmin MD1-1201 Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2013/8/7:15:19:41 md1lanadmin MD1-1201 Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded
2013/8/7:15:19:42 md1lanadmin MD1-1201 Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded
2013/8/7:15:19:44 md1lanadmin MD1-1201 Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded
2013/8/7:15:19:45 md1lanadmin MD1-1201 Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded
2013/8/7:15:19:46 md1lanadmin MD1-1201 Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded
2013/8/7:15:19:48 md1lanadmin MD1-1201 Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded
2013/8/7:15:19:50 md1lanadmin MD1-1201 Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded
2013/8/7:15:19:51 md1lanadmin MD1-1201 Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded
2013/8/7:15:19:51 md1lanadmin MD1-1201 Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619
2013/8/7:15:20:05 md1lanadmin MD1-1201 === Setup ended ===
-Marc
Message 9 of 18
vcoleman
I never did get 2014 or 2013 installed hopefully you will get help and I can learned from that
Message 10 of 18
TravisNave
The only thing I can think of is that your deployment UNC path is too deep.  You should really consider just sharing the last folder you have pathed and make it \\servername\share.
Also, do not include any service packs in the deployment, and do not use Silent Mode (uncheck the box.)
See if that helps.
Autodesk Forums:
Message 11 of 18
c-not-k
I'll give those suggestions a try and report back.
Thanks.
-Marc
Message 12 of 18
ARC0112358
Any progress on this?   I am having the same EXACT problem...   same log file messages.  How aggravating...
Message 13 of 18
TravisNave
in reply to: ARC0112358
Post your log files.
Autodesk Forums:
Message 14 of 18
c-not-k
Well, I failed to use the scientific method. I changed several things at once and got it to install.
I...
  • created a new share on the server just for this program.
  • created a new image without the patches installed inline.
  • didn't install (or uninstalled) the Anti-virus software.
My path to all my previous builds is "servername\(6 characters)\mis\install\application folder"
I don't think that's the problem, but I'll have to create another image to prove it. I'll try to do that next week and post back.
-Marc
Message 15 of 18
c-not-k
Well I just built another ID 2014 deployment. It was identical to the first one I created (including the folder location) EXCEPT for the slipstreamed service packs, which were not included this time. It installed perfectly.
My test computer did not have its anti-virus software disabled or uninstalled.
I created a batch file to apply the patches after the installation.
  -Marc
-Marc
Message 16 of 18
TravisNave
Thanks for the update.  Having installed AutoCAD in a support role since at least version 2004, I have always recommended avoiding adding service packs to a deployment.  It's a decade of destruction.  Smiley Very Happy
Seems to still be holding true.
Glad you got it all worked out.
Autodesk Forums:
Message 17 of 18
c-not-k
Note-to-self, for sure. Strange, my 2013 build has the service packs slipstreamed without an issue. Same server, path, even workstation.
If this made sense I'd be doing something else for a living!
-Marc
Message 18 of 18
TravisNave
Very true!  If this stuff was easy, I wouldn't have a job.  Sometimes I wonder if this is by design.  And here I thought self-preservation was a governmental idea...  Smiley Very Happy
Autodesk Forums:
Administrator Productivity
