Installation & Licensing
AutoCAD Civil 3D 2013 Installation Error PLEASE NEED HELP
2 REPLIES 2
jesseyusufu
3025 Views, 2 Replies
I am trying to install an AutoCAD Civil 3D 2013 after i have uninstalled it, but i keep on getting the error below PLEASE HELP AS I HAVE SPEND THE WHOLE NIGHT TRYING
2012/10/26:01:30:01    Jesse    JESSE-PC    === Setup started on JESSE-PC by Jesse ===
2012/10/26:01:30:01    Jesse    JESSE-PC    Launch
2012/10/26:01:34:56    Jesse    JESSE-PC    === Setup ended ===
2012/10/26:01:34:05    Jesse    JESSE-PC    === Setup started on JESSE-PC by Jesse ===
2012/10/26:01:34:05    Jesse    JESSE-PC    Launch
2012/10/26:01:34:58    Jesse    JESSE-PC    PageOpen    LaunchDialog
2012/10/26:01:35:08    Jesse    JESSE-PC    PageOpen    LicenseDialog
2012/10/26:01:35:16    Jesse    JESSE-PC    PageOpen    ProductInfoDialog
2012/10/26:01:35:28    Jesse    JESSE-PC    PageOpen    ProductSelectionDialog2
2012/10/26:01:36:10    Jesse    JESSE-PC    [Error: 1052] The requested control is not valid for this service.
2012/10/26:01:36:10    Jesse    JESSE-PC    === Setup ended ===
2012/10/26:02:09:50    Jesse    JESSE-PC    === Setup started on JESSE-PC by Jesse ===
2012/10/26:02:09:50    Jesse    JESSE-PC    Launch
2012/10/26:02:10:19    Jesse    JESSE-PC    === Setup ended ===
2012/10/26:02:10:12    Jesse    JESSE-PC    === Setup started on JESSE-PC by Jesse ===
2012/10/26:02:10:12    Jesse    JESSE-PC    Launch
2012/10/26:02:10:18    Jesse    JESSE-PC    PageOpen    LaunchDialog
2012/10/26:02:10:22    Jesse    JESSE-PC    PageOpen    LicenseDialog
2012/10/26:02:10:27    Jesse    JESSE-PC    PageOpen    ProductInfoDialog
2012/10/26:02:11:21    Jesse    JESSE-PC    PageOpen    ProductSelectionDialog2
2012/10/26:02:12:04    Jesse    JESSE-PC    PageOpen    FullProgressDialog
2012/10/26:02:12:04    Jesse    JESSE-PC    Installing Autodesk Storm & Sanitary Analysis 2013:   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\autodesk\AutoCAD_Civil3D_2013_English_Win_32bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/26:02:12:17    Jesse    JESSE-PC    Install    Autodesk Storm & Sanitary Analysis 2013    Failed    Installation aborted, Result=1603
2012/10/26:02:12:21    Jesse    JESSE-PC    PageOpen    InstallCompleteDialog
2012/10/26:02:12:28    Jesse    JESSE-PC    === Setup ended ===
2012/10/26:02:28:14    Jesse    JESSE-PC    === Setup started on JESSE-PC by Jesse ===
2012/10/26:02:28:14    Jesse    JESSE-PC    Launch
2012/10/26:02:28:27    Jesse    JESSE-PC    === Setup ended ===
2012/10/26:02:28:21    Jesse    JESSE-PC    === Setup started on JESSE-PC by Jesse ===
2012/10/26:02:28:21    Jesse    JESSE-PC    Launch
2012/10/26:02:28:27    Jesse    JESSE-PC    PageOpen    LaunchDialog
2012/10/26:02:28:35    Jesse    JESSE-PC    PageOpen    LicenseDialog
2012/10/26:02:28:39    Jesse    JESSE-PC    PageOpen    ProductInfoDialog
2012/10/26:02:29:33    Jesse    JESSE-PC    PageOpen    ProductSelectionDialog2
2012/10/26:02:33:57    Jesse    JESSE-PC    PageOpen    FullProgressDialog
2012/10/26:02:33:58    Jesse    JESSE-PC    Installing Autodesk® Design Review 2013:  TRANSFORMS="C:\Users\Jesse\AppData\Local\Temp\_AI565A.tmp\x86\en-us\Components\adr2013\SetupDesignReview2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\autodesk\AutoCAD_Civil3D_2013_English_Win_32bit\" INSTALLDIR="C:\Program Files\Autodesk\Autodesk Design Review 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/26:02:34:48    Jesse    JESSE-PC    Install    Autodesk® Design Review 2013    Failed    Failure is ignored, Result=1603
2012/10/26:02:34:48    Jesse    JESSE-PC    Installing DirectX Runtime: C:\autodesk\AutoCAD_Civil3D_2013_English_Win_32bit\3rdParty\DirectX\DXSETUP.exe /silent
2012/10/26:02:35:33    Jesse    JESSE-PC    Install    DirectX Runtime    Succeeded
2012/10/26:02:35:33    Jesse    JESSE-PC    Installing Microsoft Visual Basic Power Packs 10.0: C:\autodesk\AutoCAD_Civil3D_2013_English_Win_32bit\3rdParty\VBPowerPacks10\VisualBasicPowerPacksSetup.exe /q /l C:\Users\Jesse\AppData\Local\Temp\VisualBasicPowerPacks10Setup.log
2012/10/26:02:35:40    Jesse    JESSE-PC    Install    Microsoft Visual Basic Power Packs 10.0    Succeeded
2012/10/26:02:35:41    Jesse    JESSE-PC    Installing AutoCAD Civil 3D 2013:  TRANSFORMS="C:\autodesk\AutoCAD_Civil3D_2013_English_Win_32bit\x86\en-us\C3D\C3D.mst;C:\Users\Jesse\AppData\Local\Temp\_AI565A.tmp\x86\C3D\C3D-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\autodesk\AutoCAD_Civil3D_2013_English_Win_32bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD Civil 3D 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/26:02:35:41    Jesse    JESSE-PC    Install    AutoCAD Civil 3D 2013    Failed    Installation aborted, Result=1639
2012/10/26:02:35:41    Jesse    JESSE-PC    Rollback    Microsoft Visual Basic Power Packs 10.0    Failed    Failure is ignored, Result=1619
2012/10/26:02:35:41    Jesse    JESSE-PC    Rollback    DirectX Runtime    Failed    Failure is ignored, Result=1619
2012/10/26:02:35:44    Jesse    JESSE-PC    PageOpen    InstallCompleteDialog
2012/10/26:02:36:18    Jesse    JESSE-PC    === Setup ended ===
2012/10/26:02:42:05    Jesse    JESSE-PC    === Setup started on JESSE-PC by Jesse ===
2012/10/26:02:42:05    Jesse    JESSE-PC    Launch
2012/10/26:02:43:17    Jesse    JESSE-PC    === Setup ended ===
2012/10/26:02:42:48    Jesse    JESSE-PC    === Setup started on JESSE-PC by Jesse ===
2012/10/26:02:42:48    Jesse    JESSE-PC    Launch
2012/10/26:02:43:17    Jesse    JESSE-PC    PageOpen    LaunchDialog
2012/10/26:02:43:20    Jesse    JESSE-PC    PageOpen    LicenseDialog
2012/10/26:02:43:24    Jesse    JESSE-PC    PageOpen    ProductInfoDialog
2012/10/26:02:44:27    Jesse    JESSE-PC    PageOpen    ProductSelectionDialog2
2012/10/26:02:44:42    Jesse    JESSE-PC    PageOpen    FullProgressDialog
2012/10/26:02:44:43    Jesse    JESSE-PC    Installing Autodesk® Design Review 2013:  TRANSFORMS="C:\Users\Jesse\AppData\Local\Temp\_AIF8EE.tmp\x86\en-us\Components\adr2013\SetupDesignReview2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\autodesk\AutoCAD_Civil3D_2013_English_Win_32bit\" INSTALLDIR="C:\Program Files\Autodesk\Autodesk Design Review 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/26:02:46:16    Jesse    JESSE-PC    Install    Autodesk® Design Review 2013    Failed    Failure is ignored, Result=1603
2012/10/26:02:46:16    Jesse    JESSE-PC    Installing DirectX Runtime: C:\autodesk\AutoCAD_Civil3D_2013_English_Win_32bit\3rdParty\DirectX\DXSETUP.exe /silent
2012/10/26:02:47:24    Jesse    JESSE-PC    Install    DirectX Runtime    Succeeded
2012/10/26:02:47:24    Jesse    JESSE-PC    Installing Microsoft Visual Basic Power Packs 10.0: C:\autodesk\AutoCAD_Civil3D_2013_English_Win_32bit\3rdParty\VBPowerPacks10\VisualBasicPowerPacksSetup.exe /q /l C:\Users\Jesse\AppData\Local\Temp\VisualBasicPowerPacks10Setup.log
2012/10/26:02:47:33    Jesse    JESSE-PC    Install    Microsoft Visual Basic Power Packs 10.0    Succeeded
2012/10/26:02:47:34    Jesse    JESSE-PC    Installing AutoCAD Civil 3D 2013:  TRANSFORMS="C:\autodesk\AutoCAD_Civil3D_2013_English_Win_32bit\x86\en-us\C3D\C3D.mst;C:\Users\Jesse\AppData\Local\Temp\_AIF8EE.tmp\x86\C3D\C3D-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\autodesk\AutoCAD_Civil3D_2013_English_Win_32bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD Civil 3D 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/26:02:47:35    Jesse    JESSE-PC    Install    AutoCAD Civil 3D 2013    Failed    Installation aborted, Result=1639
2012/10/26:02:47:35    Jesse    JESSE-PC    Rollback    Microsoft Visual Basic Power Packs 10.0    Failed    Failure is ignored, Result=1619
2012/10/26:02:47:35    Jesse    JESSE-PC    Rollback    DirectX Runtime    Failed    Failure is ignored, Result=1619
2012/10/26:02:47:36    Jesse    JESSE-PC    PageOpen    InstallCompleteDialog
2012/10/26:02:47:59    Jesse    JESSE-PC    === Setup ended ===
2012/10/26:03:12:31    Jesse    JESSE-PC    === Setup started on JESSE-PC by Jesse ===
2012/10/26:03:12:31    Jesse    JESSE-PC    Launch
2012/10/26:03:13:06    Jesse    JESSE-PC    === Setup ended ===
2012/10/26:03:12:51    Jesse    JESSE-PC    === Setup started on JESSE-PC by Jesse ===
2012/10/26:03:12:51    Jesse    JESSE-PC    Launch
2012/10/26:03:13:06    Jesse    JESSE-PC    PageOpen    LaunchDialog
2012/10/26:03:13:37    Jesse    JESSE-PC    PageOpen    LicenseDialog
2012/10/26:03:13:42    Jesse    JESSE-PC    PageOpen    ProductInfoDialog
2012/10/26:03:15:12    Jesse    JESSE-PC    PageOpen    ProductSelectionDialog2
2012/10/26:03:16:05    Jesse    JESSE-PC    PageOpen    FullProgressDialog
2012/10/26:03:16:07    Jesse    JESSE-PC    Installing Autodesk® Design Review 2013:  TRANSFORMS="C:\Users\Jesse\AppData\Local\Temp\_AID6FD.tmp\x86\en-us\Components\adr2013\SetupDesignReview2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\autodesk\AutoCAD_Civil3D_2013_English_Win_32bit\" INSTALLDIR="C:\Program Files\Autodesk\Autodesk Design Review 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/26:03:21:43    Jesse    JESSE-PC    Install    Autodesk® Design Review 2013    Failed    Failure is ignored, Result=1603
2012/10/26:03:21:43    Jesse    JESSE-PC    Installing DirectX Runtime: C:\autodesk\AutoCAD_Civil3D_2013_English_Win_32bit\3rdParty\DirectX\DXSETUP.exe /silent
2012/10/26:03:22:42    Jesse    JESSE-PC    Install    DirectX Runtime    Succeeded
2012/10/26:03:22:42    Jesse    JESSE-PC    Installing Microsoft Visual Basic Power Packs 10.0: C:\autodesk\AutoCAD_Civil3D_2013_English_Win_32bit\3rdParty\VBPowerPacks10\VisualBasicPowerPacksSetup.exe /q /l C:\Users\Jesse\AppData\Local\Temp\VisualBasicPowerPacks10Setup.log
2012/10/26:03:22:52    Jesse    JESSE-PC    Install    Microsoft Visual Basic Power Packs 10.0    Succeeded
2012/10/26:03:22:54    Jesse    JESSE-PC    Installing AutoCAD Civil 3D 2013:  TRANSFORMS="C:\autodesk\AutoCAD_Civil3D_2013_English_Win_32bit\x86\en-us\C3D\C3D.mst;C:\Users\Jesse\AppData\Local\Temp\_AID6FD.tmp\x86\C3D\C3D-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\autodesk\AutoCAD_Civil3D_2013_English_Win_32bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD Civil 3D 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/26:03:22:54    Jesse    JESSE-PC    Install    AutoCAD Civil 3D 2013    Failed    Installation aborted, Result=1639
2012/10/26:03:22:55    Jesse    JESSE-PC    Rollback    Microsoft Visual Basic Power Packs 10.0    Failed    Failure is ignored, Result=1619
2012/10/26:03:22:55    Jesse    JESSE-PC    Rollback    DirectX Runtime    Failed    Failure is ignored, Result=1619
2012/10/26:03:23:00    Jesse    JESSE-PC    PageOpen    InstallCompleteDialog
2012/10/26:04:14:22    Jesse    JESSE-PC    === Setup ended ===
2012/10/26:05:40:18    Jesse    JESSE-PC    === Setup started on JESSE-PC by Jesse ===
2012/10/26:05:40:18    Jesse    JESSE-PC    Launch
2012/10/26:05:40:49    Jesse    JESSE-PC    === Setup ended ===
2012/10/26:05:40:40    Jesse    JESSE-PC    === Setup started on JESSE-PC by Jesse ===
2012/10/26:05:40:40    Jesse    JESSE-PC    Launch
2012/10/26:05:40:50    Jesse    JESSE-PC    PageOpen    LaunchDialog
2012/10/26:05:45:18    Jesse    JESSE-PC    PageOpen    LicenseDialog
2012/10/26:05:45:21    Jesse    JESSE-PC    PageOpen    ProductInfoDialog
2012/10/26:05:46:43    Jesse    JESSE-PC    PageOpen    ProductSelectionDialog2
2012/10/26:05:47:01    Jesse    JESSE-PC    PageOpen    FullProgressDialog
2012/10/26:05:47:01    Jesse    JESSE-PC    Installing DirectX Runtime: C:\autodesk\AutoCAD_Civil3D_2013_English_Win_32bit\3rdParty\DirectX\DXSETUP.exe /silent
2012/10/26:05:48:11    Jesse    JESSE-PC    Install    DirectX Runtime    Succeeded
2012/10/26:05:48:11    Jesse    JESSE-PC    Installing Microsoft Visual Basic Power Packs 10.0: C:\autodesk\AutoCAD_Civil3D_2013_English_Win_32bit\3rdParty\VBPowerPacks10\VisualBasicPowerPacksSetup.exe /q /l C:\Users\Jesse\AppData\Local\Temp\VisualBasicPowerPacks10Setup.log
2012/10/26:05:48:19    Jesse    JESSE-PC    Install    Microsoft Visual Basic Power Packs 10.0    Succeeded
2012/10/26:05:48:21    Jesse    JESSE-PC    Installing AutoCAD Civil 3D 2013:  TRANSFORMS="C:\autodesk\AutoCAD_Civil3D_2013_English_Win_32bit\x86\en-us\C3D\C3D.mst;C:\Users\Jesse\AppData\Local\Temp\_AI2129.tmp\x86\C3D\C3D-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\autodesk\AutoCAD_Civil3D_2013_English_Win_32bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD Civil 3D 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/26:05:48:21    Jesse    JESSE-PC    Install    AutoCAD Civil 3D 2013    Failed    Installation aborted, Result=1639
2012/10/26:05:48:21    Jesse    JESSE-PC    Rollback    Microsoft Visual Basic Power Packs 10.0    Failed    Failure is ignored, Result=1619
2012/10/26:05:48:22    Jesse    JESSE-PC    Rollback    DirectX Runtime    Failed    Failure is ignored, Result=1619
2012/10/26:05:48:23    Jesse    JESSE-PC    PageOpen    InstallCompleteDialog
2012/10/26:05:48:41    Jesse    JESSE-PC    === Setup ended ===
2012/10/26:06:06:57    Jesse    JESSE-PC    === Setup started on JESSE-PC by Jesse ===
2012/10/26:06:06:57    Jesse    JESSE-PC    Launch
2012/10/26:06:07:30    Jesse    JESSE-PC    === Setup ended ===
2012/10/26:06:07:22    Jesse    JESSE-PC    === Setup started on JESSE-PC by Jesse ===
2012/10/26:06:07:22    Jesse    JESSE-PC    Launch
2012/10/26:06:07:30    Jesse    JESSE-PC    PageOpen    LaunchDialog
2012/10/26:06:07:41    Jesse    JESSE-PC    PageOpen    LicenseDialog
2012/10/26:06:07:45    Jesse    JESSE-PC    PageOpen    ProductInfoDialog
2012/10/26:06:09:07    Jesse    JESSE-PC    PageOpen    ProductSelectionDialog2
2012/10/26:06:09:41    Jesse    JESSE-PC    PageOpen    FullProgressDialog
2012/10/26:06:09:42    Jesse    JESSE-PC    Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): C:\autodesk\AutoCAD_Civil3D_2013_English_Win_32bit\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q
2012/10/26:06:09:56    Jesse    JESSE-PC    Install    Microsoft Visual C++ 2008 SP1 Redistributable (x86)    Succeeded
2012/10/26:06:09:56    Jesse    JESSE-PC    Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): C:\autodesk\AutoCAD_Civil3D_2013_English_Win_32bit\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe /q /norestart /l C:\Users\Jesse\AppData\Local\Temp\vcredist_x86_2010.log
2012/10/26:06:10:15    Jesse    JESSE-PC    Install    Microsoft Visual C++ 2010 SP1 Redistributable (x86)    Succeeded
2012/10/26:06:10:15    Jesse    JESSE-PC    Installing DirectX Runtime: C:\autodesk\AutoCAD_Civil3D_2013_English_Win_32bit\3rdParty\DirectX\DXSETUP.exe /silent
2012/10/26:06:11:23    Jesse    JESSE-PC    Install    DirectX Runtime    Succeeded
2012/10/26:06:11:23    Jesse    JESSE-PC    Installing Microsoft Visual Basic Power Packs 10.0: C:\autodesk\AutoCAD_Civil3D_2013_English_Win_32bit\3rdParty\VBPowerPacks10\VisualBasicPowerPacksSetup.exe /q /l C:\Users\Jesse\AppData\Local\Temp\VisualBasicPowerPacks10Setup.log
2012/10/26:06:11:39    Jesse    JESSE-PC    Install    Microsoft Visual Basic Power Packs 10.0    Succeeded
2012/10/26:06:11:43    Jesse    JESSE-PC    Installing AutoCAD Civil 3D 2013:  TRANSFORMS="C:\autodesk\AutoCAD_Civil3D_2013_English_Win_32bit\x86\en-us\C3D\C3D.mst;C:\Users\Jesse\AppData\Local\Temp\_AI87A9.tmp\x86\C3D\C3D-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\autodesk\AutoCAD_Civil3D_2013_English_Win_32bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD Civil 3D 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/26:06:11:43    Jesse    JESSE-PC    Install    AutoCAD Civil 3D 2013    Failed    Installation aborted, Result=1639
2012/10/26:06:11:43    Jesse    JESSE-PC    Rollback    Microsoft Visual Basic Power Packs 10.0    Failed    Failure is ignored, Result=1619
2012/10/26:06:11:43    Jesse    JESSE-PC    Rollback    DirectX Runtime    Failed    Failure is ignored, Result=1619
2012/10/26:06:11:44    Jesse    JESSE-PC    Rollback    Microsoft Visual C++ 2010 SP1 Redistributable (x86)    Failed    Installation aborted, Result=1619
2 REPLIES 2
TravisNave
in reply to: jesseyusufu
You shouldn't be getting a 1639 error.  That's an invalid command line argument.  Are you installing this direct from setup?  Or are you trying to push it out with an installation program?
Probably what is happening is that you have some sort of special characters in the name or company name.  Make sure that there are not any quotes or apostrophes or any other special characters listed in your registration information or any other installed pathname.  Just install the program default.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
jesseyusufu
in reply to: TravisNave
I am installing it from a Setup but I have just solved the problem.
I used WINDOWS INSTALL CLEANUP to uninstall all Autodesk softwares and components. After which i installed the afresh copy of AutoCAD Civil 3D 2013. Everything now works fine
Administrator Productivity
