I am trying to install an AutoCAD Civil 3D 2013 after i have uninstalled it, but i keep on getting the error below PLEASE HELP AS I HAVE SPEND THE WHOLE NIGHT TRYING
2012/10/26:01:30:01 Jesse JESSE-PC === Setup started on JESSE-PC by Jesse ===
2012/10/26:01:30:01 Jesse JESSE-PC Launch
2012/10/26:01:34:56 Jesse JESSE-PC === Setup ended ===
2012/10/26:01:34:05 Jesse JESSE-PC === Setup started on JESSE-PC by Jesse ===
2012/10/26:01:34:05 Jesse JESSE-PC Launch
2012/10/26:01:34:58 Jesse JESSE-PC PageOpen LaunchDialog
2012/10/26:01:35:08 Jesse JESSE-PC PageOpen LicenseDialog
2012/10/26:01:35:16 Jesse JESSE-PC PageOpen ProductInfoDialog
2012/10/26:01:35:28 Jesse JESSE-PC PageOpen ProductSelectionDialog2
2012/10/26:01:36:10 Jesse JESSE-PC [Error: 1052] The requested control is not valid for this service.
2012/10/26:01:36:10 Jesse JESSE-PC === Setup ended ===
2012/10/26:02:09:50 Jesse JESSE-PC === Setup started on JESSE-PC by Jesse ===
2012/10/26:02:09:50 Jesse JESSE-PC Launch
2012/10/26:02:10:19 Jesse JESSE-PC === Setup ended ===
2012/10/26:02:10:12 Jesse JESSE-PC === Setup started on JESSE-PC by Jesse ===
2012/10/26:02:10:12 Jesse JESSE-PC Launch
2012/10/26:02:10:18 Jesse JESSE-PC PageOpen LaunchDialog
2012/10/26:02:10:22 Jesse JESSE-PC PageOpen LicenseDialog
2012/10/26:02:10:27 Jesse JESSE-PC PageOpen ProductInfoDialog
2012/10/26:02:11:21 Jesse JESSE-PC PageOpen ProductSelectionDialog2
2012/10/26:02:12:04 Jesse JESSE-PC PageOpen FullProgressDialog
2012/10/26:02:12:04 Jesse JESSE-PC Installing Autodesk Storm & Sanitary Analysis 2013: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\autodesk\AutoCAD_Civil3D_2013_English_Win_32bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/10/26:02:12:17 Jesse JESSE-PC Install Autodesk Storm & Sanitary Analysis 2013 Failed Installation aborted, Result=1603
2012/10/26:02:12:21 Jesse JESSE-PC PageOpen InstallCompleteDialog
2012/10/26:02:12:28 Jesse JESSE-PC === Setup ended ===
2012/10/26:02:28:14 Jesse JESSE-PC === Setup started on JESSE-PC by Jesse ===
2012/10/26:02:28:14 Jesse JESSE-PC Launch
2012/10/26:02:28:27 Jesse JESSE-PC === Setup ended ===
2012/10/26:02:28:21 Jesse JESSE-PC === Setup started on JESSE-PC by Jesse ===
2012/10/26:02:28:21 Jesse JESSE-PC Launch
2012/10/26:02:28:27 Jesse JESSE-PC PageOpen LaunchDialog
2012/10/26:02:28:35 Jesse JESSE-PC PageOpen LicenseDialog
2012/10/26:02:28:39 Jesse JESSE-PC PageOpen ProductInfoDialog
2012/10/26:02:29:33 Jesse JESSE-PC PageOpen ProductSelectionDialog2
2012/10/26:02:33:57 Jesse JESSE-PC PageOpen FullProgressDialog
2012/10/26:02:33:58 Jesse JESSE-PC Installing Autodesk® Design Review 2013: TRANSFORMS="C:\Users\Jesse\AppData\Local\Temp\_AI565A.tmp\x86\en-us\Components\adr2013\SetupDesignReview2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\autodesk\AutoCAD_Civil3D_2013_English_Win_32bit\" INSTALLDIR="C:\Program Files\Autodesk\Autodesk Design Review 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/10/26:02:34:48 Jesse JESSE-PC Install Autodesk® Design Review 2013 Failed Failure is ignored, Result=1603
2012/10/26:02:34:48 Jesse JESSE-PC Installing DirectX Runtime: C:\autodesk\AutoCAD_Civil3D_2013_English_Win_32bit\3rdParty\DirectX\DXSETUP.exe /silent
2012/10/26:02:35:33 Jesse JESSE-PC Install DirectX Runtime Succeeded
2012/10/26:02:35:33 Jesse JESSE-PC Installing Microsoft Visual Basic Power Packs 10.0: C:\autodesk\AutoCAD_Civil3D_2013_English_Win_32bit\3rdParty\VBPowerPacks10\VisualBasicPowerPacksSetup.exe /q /l C:\Users\Jesse\AppData\Local\Temp\VisualBasicPowerPacks10Setup.log
2012/10/26:02:35:40 Jesse JESSE-PC Install Microsoft Visual Basic Power Packs 10.0 Succeeded
2012/10/26:02:35:41 Jesse JESSE-PC Installing AutoCAD Civil 3D 2013: TRANSFORMS="C:\autodesk\AutoCAD_Civil3D_2013_English_Win_32bit\x86\en-us\C3D\C3D.mst;C:\Users\Jesse\AppData\Local\Temp\_AI565A.tmp\x86\C3D\C3D-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\autodesk\AutoCAD_Civil3D_2013_English_Win_32bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD Civil 3D 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/10/26:02:35:41 Jesse JESSE-PC Install AutoCAD Civil 3D 2013 Failed Installation aborted, Result=1639
2012/10/26:02:35:41 Jesse JESSE-PC Rollback Microsoft Visual Basic Power Packs 10.0 Failed Failure is ignored, Result=1619
2012/10/26:02:35:41 Jesse JESSE-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2012/10/26:02:35:44 Jesse JESSE-PC PageOpen InstallCompleteDialog
2012/10/26:02:36:18 Jesse JESSE-PC === Setup ended ===
2012/10/26:02:42:05 Jesse JESSE-PC === Setup started on JESSE-PC by Jesse ===
2012/10/26:02:42:05 Jesse JESSE-PC Launch
2012/10/26:02:43:17 Jesse JESSE-PC === Setup ended ===
2012/10/26:02:42:48 Jesse JESSE-PC === Setup started on JESSE-PC by Jesse ===
2012/10/26:02:42:48 Jesse JESSE-PC Launch
2012/10/26:02:43:17 Jesse JESSE-PC PageOpen LaunchDialog
2012/10/26:02:43:20 Jesse JESSE-PC PageOpen LicenseDialog
2012/10/26:02:43:24 Jesse JESSE-PC PageOpen ProductInfoDialog
2012/10/26:02:44:27 Jesse JESSE-PC PageOpen ProductSelectionDialog2
2012/10/26:02:44:42 Jesse JESSE-PC PageOpen FullProgressDialog
2012/10/26:02:44:43 Jesse JESSE-PC Installing Autodesk® Design Review 2013: TRANSFORMS="C:\Users\Jesse\AppData\Local\Temp\_AIF8EE.tmp\x86\en-us\Components\adr2013\SetupDesignReview2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\autodesk\AutoCAD_Civil3D_2013_English_Win_32bit\" INSTALLDIR="C:\Program Files\Autodesk\Autodesk Design Review 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/10/26:02:46:16 Jesse JESSE-PC Install Autodesk® Design Review 2013 Failed Failure is ignored, Result=1603
2012/10/26:02:46:16 Jesse JESSE-PC Installing DirectX Runtime: C:\autodesk\AutoCAD_Civil3D_2013_English_Win_32bit\3rdParty\DirectX\DXSETUP.exe /silent
2012/10/26:02:47:24 Jesse JESSE-PC Install DirectX Runtime Succeeded
2012/10/26:02:47:24 Jesse JESSE-PC Installing Microsoft Visual Basic Power Packs 10.0: C:\autodesk\AutoCAD_Civil3D_2013_English_Win_32bit\3rdParty\VBPowerPacks10\VisualBasicPowerPacksSetup.exe /q /l C:\Users\Jesse\AppData\Local\Temp\VisualBasicPowerPacks10Setup.log
2012/10/26:02:47:33 Jesse JESSE-PC Install Microsoft Visual Basic Power Packs 10.0 Succeeded
2012/10/26:02:47:34 Jesse JESSE-PC Installing AutoCAD Civil 3D 2013: TRANSFORMS="C:\autodesk\AutoCAD_Civil3D_2013_English_Win_32bit\x86\en-us\C3D\C3D.mst;C:\Users\Jesse\AppData\Local\Temp\_AIF8EE.tmp\x86\C3D\C3D-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\autodesk\AutoCAD_Civil3D_2013_English_Win_32bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD Civil 3D 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/10/26:02:47:35 Jesse JESSE-PC Install AutoCAD Civil 3D 2013 Failed Installation aborted, Result=1639
2012/10/26:02:47:35 Jesse JESSE-PC Rollback Microsoft Visual Basic Power Packs 10.0 Failed Failure is ignored, Result=1619
2012/10/26:02:47:35 Jesse JESSE-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2012/10/26:02:47:36 Jesse JESSE-PC PageOpen InstallCompleteDialog
2012/10/26:02:47:59 Jesse JESSE-PC === Setup ended ===
2012/10/26:03:12:31 Jesse JESSE-PC === Setup started on JESSE-PC by Jesse ===
2012/10/26:03:12:31 Jesse JESSE-PC Launch
2012/10/26:03:13:06 Jesse JESSE-PC === Setup ended ===
2012/10/26:03:12:51 Jesse JESSE-PC === Setup started on JESSE-PC by Jesse ===
2012/10/26:03:12:51 Jesse JESSE-PC Launch
2012/10/26:03:13:06 Jesse JESSE-PC PageOpen LaunchDialog
2012/10/26:03:13:37 Jesse JESSE-PC PageOpen LicenseDialog
2012/10/26:03:13:42 Jesse JESSE-PC PageOpen ProductInfoDialog
2012/10/26:03:15:12 Jesse JESSE-PC PageOpen ProductSelectionDialog2
2012/10/26:03:16:05 Jesse JESSE-PC PageOpen FullProgressDialog
2012/10/26:03:16:07 Jesse JESSE-PC Installing Autodesk® Design Review 2013: TRANSFORMS="C:\Users\Jesse\AppData\Local\Temp\_AID6FD.tmp\x86\en-us\Components\adr2013\SetupDesignReview2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\autodesk\AutoCAD_Civil3D_2013_English_Win_32bit\" INSTALLDIR="C:\Program Files\Autodesk\Autodesk Design Review 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/10/26:03:21:43 Jesse JESSE-PC Install Autodesk® Design Review 2013 Failed Failure is ignored, Result=1603
2012/10/26:03:21:43 Jesse JESSE-PC Installing DirectX Runtime: C:\autodesk\AutoCAD_Civil3D_2013_English_Win_32bit\3rdParty\DirectX\DXSETUP.exe /silent
2012/10/26:03:22:42 Jesse JESSE-PC Install DirectX Runtime Succeeded
2012/10/26:03:22:42 Jesse JESSE-PC Installing Microsoft Visual Basic Power Packs 10.0: C:\autodesk\AutoCAD_Civil3D_2013_English_Win_32bit\3rdParty\VBPowerPacks10\VisualBasicPowerPacksSetup.exe /q /l C:\Users\Jesse\AppData\Local\Temp\VisualBasicPowerPacks10Setup.log
2012/10/26:03:22:52 Jesse JESSE-PC Install Microsoft Visual Basic Power Packs 10.0 Succeeded
2012/10/26:03:22:54 Jesse JESSE-PC Installing AutoCAD Civil 3D 2013: TRANSFORMS="C:\autodesk\AutoCAD_Civil3D_2013_English_Win_32bit\x86\en-us\C3D\C3D.mst;C:\Users\Jesse\AppData\Local\Temp\_AID6FD.tmp\x86\C3D\C3D-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\autodesk\AutoCAD_Civil3D_2013_English_Win_32bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD Civil 3D 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/10/26:03:22:54 Jesse JESSE-PC Install AutoCAD Civil 3D 2013 Failed Installation aborted, Result=1639
2012/10/26:03:22:55 Jesse JESSE-PC Rollback Microsoft Visual Basic Power Packs 10.0 Failed Failure is ignored, Result=1619
2012/10/26:03:22:55 Jesse JESSE-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2012/10/26:03:23:00 Jesse JESSE-PC PageOpen InstallCompleteDialog
2012/10/26:04:14:22 Jesse JESSE-PC === Setup ended ===
2012/10/26:05:40:18 Jesse JESSE-PC === Setup started on JESSE-PC by Jesse ===
2012/10/26:05:40:18 Jesse JESSE-PC Launch
2012/10/26:05:40:49 Jesse JESSE-PC === Setup ended ===
2012/10/26:05:40:40 Jesse JESSE-PC === Setup started on JESSE-PC by Jesse ===
2012/10/26:05:40:40 Jesse JESSE-PC Launch
2012/10/26:05:40:50 Jesse JESSE-PC PageOpen LaunchDialog
2012/10/26:05:45:18 Jesse JESSE-PC PageOpen LicenseDialog
2012/10/26:05:45:21 Jesse JESSE-PC PageOpen ProductInfoDialog
2012/10/26:05:46:43 Jesse JESSE-PC PageOpen ProductSelectionDialog2
2012/10/26:05:47:01 Jesse JESSE-PC PageOpen FullProgressDialog
2012/10/26:05:47:01 Jesse JESSE-PC Installing DirectX Runtime: C:\autodesk\AutoCAD_Civil3D_2013_English_Win_32bit\3rdParty\DirectX\DXSETUP.exe /silent
2012/10/26:05:48:11 Jesse JESSE-PC Install DirectX Runtime Succeeded
2012/10/26:05:48:11 Jesse JESSE-PC Installing Microsoft Visual Basic Power Packs 10.0: C:\autodesk\AutoCAD_Civil3D_2013_English_Win_32bit\3rdParty\VBPowerPacks10\VisualBasicPowerPacksSetup.exe /q /l C:\Users\Jesse\AppData\Local\Temp\VisualBasicPowerPacks10Setup.log
2012/10/26:05:48:19 Jesse JESSE-PC Install Microsoft Visual Basic Power Packs 10.0 Succeeded
2012/10/26:05:48:21 Jesse JESSE-PC Installing AutoCAD Civil 3D 2013: TRANSFORMS="C:\autodesk\AutoCAD_Civil3D_2013_English_Win_32bit\x86\en-us\C3D\C3D.mst;C:\Users\Jesse\AppData\Local\Temp\_AI2129.tmp\x86\C3D\C3D-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\autodesk\AutoCAD_Civil3D_2013_English_Win_32bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD Civil 3D 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/10/26:05:48:21 Jesse JESSE-PC Install AutoCAD Civil 3D 2013 Failed Installation aborted, Result=1639
2012/10/26:05:48:21 Jesse JESSE-PC Rollback Microsoft Visual Basic Power Packs 10.0 Failed Failure is ignored, Result=1619
2012/10/26:05:48:22 Jesse JESSE-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2012/10/26:05:48:23 Jesse JESSE-PC PageOpen InstallCompleteDialog
2012/10/26:05:48:41 Jesse JESSE-PC === Setup ended ===
2012/10/26:06:06:57 Jesse JESSE-PC === Setup started on JESSE-PC by Jesse ===
2012/10/26:06:06:57 Jesse JESSE-PC Launch
2012/10/26:06:07:30 Jesse JESSE-PC === Setup ended ===
2012/10/26:06:07:22 Jesse JESSE-PC === Setup started on JESSE-PC by Jesse ===
2012/10/26:06:07:22 Jesse JESSE-PC Launch
2012/10/26:06:07:30 Jesse JESSE-PC PageOpen LaunchDialog
2012/10/26:06:07:41 Jesse JESSE-PC PageOpen LicenseDialog
2012/10/26:06:07:45 Jesse JESSE-PC PageOpen ProductInfoDialog
2012/10/26:06:09:07 Jesse JESSE-PC PageOpen ProductSelectionDialog2
2012/10/26:06:09:41 Jesse JESSE-PC PageOpen FullProgressDialog
2012/10/26:06:09:42 Jesse JESSE-PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): C:\autodesk\AutoCAD_Civil3D_2013_English_Win_32bit\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q
2012/10/26:06:09:56 Jesse JESSE-PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded
2012/10/26:06:09:56 Jesse JESSE-PC Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): C:\autodesk\AutoCAD_Civil3D_2013_English_Win_32bit\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe /q /norestart /l C:\Users\Jesse\AppData\Local\Temp\vcredist_x86_2010.log
2012/10/26:06:10:15 Jesse JESSE-PC Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded
2012/10/26:06:10:15 Jesse JESSE-PC Installing DirectX Runtime: C:\autodesk\AutoCAD_Civil3D_2013_English_Win_32bit\3rdParty\DirectX\DXSETUP.exe /silent
2012/10/26:06:11:23 Jesse JESSE-PC Install DirectX Runtime Succeeded
2012/10/26:06:11:23 Jesse JESSE-PC Installing Microsoft Visual Basic Power Packs 10.0: C:\autodesk\AutoCAD_Civil3D_2013_English_Win_32bit\3rdParty\VBPowerPacks10\VisualBasicPowerPacksSetup.exe /q /l C:\Users\Jesse\AppData\Local\Temp\VisualBasicPowerPacks10Setup.log
2012/10/26:06:11:39 Jesse JESSE-PC Install Microsoft Visual Basic Power Packs 10.0 Succeeded
2012/10/26:06:11:43 Jesse JESSE-PC Installing AutoCAD Civil 3D 2013: TRANSFORMS="C:\autodesk\AutoCAD_Civil3D_2013_English_Win_32bit\x86\en-us\C3D\C3D.mst;C:\Users\Jesse\AppData\Local\Temp\_AI87A9.tmp\x86\C3D\C3D-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\autodesk\AutoCAD_Civil3D_2013_English_Win_32bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD Civil 3D 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/10/26:06:11:43 Jesse JESSE-PC Install AutoCAD Civil 3D 2013 Failed Installation aborted, Result=1639
2012/10/26:06:11:43 Jesse JESSE-PC Rollback Microsoft Visual Basic Power Packs 10.0 Failed Failure is ignored, Result=1619
2012/10/26:06:11:43 Jesse JESSE-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2012/10/26:06:11:44 Jesse JESSE-PC Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1619
Solved by jesseyusufu. Go to Solution.
You shouldn't be getting a 1639 error. That's an invalid command line argument. Are you installing this direct from setup? Or are you trying to push it out with an installation program?
Probably what is happening is that you have some sort of special characters in the name or company name. Make sure that there are not any quotes or apostrophes or any other special characters listed in your registration information or any other installed pathname. Just install the program default.
I am installing it from a Setup but I have just solved the problem.
I used WINDOWS INSTALL CLEANUP to uninstall all Autodesk softwares and components. After which i installed the afresh copy of AutoCAD Civil 3D 2013. Everything now works fine
