Installation & Licensing
Autocad Civil 3D 2012 installation problem
7 REPLIES 7
Message 1 of 8
9327 Views, 7 Replies
I have a problem installing Autocad Civil 3D 2012.
When Its installing Civil 3D intself it stops installing and says that an error occured while installing.
This is the setuplog that should contain the error:
Launch
PageOpen	LaunchDialog
PageOpen	LicenseDialog
PageOpen	ProductInfoDialog
PageOpen	ProductSelectionDialog2
PageOpen	FullProgressDialog
Installing Microsoft Visual C++ 2005 Redistributable (x86): C:\Autodesk\AutoCAD_Civil3D_2012_English_Win_64bit\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Djerk\AppData\Local\Temp\vcredist_x86_2005.log"" "
Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded
Installing Autodesk Design Review 2012: TRANSFORMS="C:\Users\Djerk\AppData\Local\Temp\_AI1CC4.tmp\x86\en-US\Components\adr2012\SetupDesignReview2012-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_Civil3D_2012_English_Win_64bit\" INSTALLDIR="C:\Program Files (x86)\Autodesk\Autodesk Design Review 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 Install Autodesk Design Review 2012 Failed Failure is ignored, Result=1603
 Installing DirectX Runtime: C:\Autodesk\AutoCAD_Civil3D_2012_English_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
 Install DirectX Runtime Succeeded
 Installing Microsoft Visual Basic Power Packs 3.0: C:\Autodesk\AutoCAD_Civil3D_2012_English_Win_64bit\3rdParty\VBPowerPacks\VisualBasicPowerPacks3Setup.exe /q /l C:\Users\Djerk\AppData\Local\Temp\VisualBasicPowerPacks3Setup.log
Install Microsoft Visual Basic Power Packs 3.0 Succeeded
Installing AutoCAD Civil 3D 2012: TRANSFORMS="C:\Autodesk\AutoCAD_Civil3D_2012_English_Win_64bit\x64\en-us\C3D\C3D.mst;C:\Users\Djerk\AppData\Local\Temp\_AI1CC4.tmp\x64\C3D\C3D-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_Civil3D_2012_English_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD Civil 3D 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 Install AutoCAD Civil 3D 2012 Failed Installation aborted, Result=1603
 Rollback Microsoft Visual Basic Power Packs 3.0 Failed Failure is ignored, Result=1619
 Rollback DirectX Runtime Failed Failure is ignored, Result=1619
 Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed
Installation aborted, Result=1619
 help please
7 REPLIES 7
Message 2 of 8
david.lau
Can you try the following:
David Lau
Message 3 of 8
in reply to: david.lau
I did al the steps.
But It didn't work I still got the same error Smiley Sad
Message 4 of 8
david.lau
I would try not running the installation in silent mode.  This may also give you some error messages.
David Lau
Message 5 of 8
ngilman
I'm also having install issues, adui18res.dll, 1606.  I've spent the last 1 1/2 days atempting what I've read in the boards here to NO avail!!!
Suggestions??? Help!
Message 6 of 8
david.lau
in reply to: ngilman
Message 7 of 8
ngilman
Thanks for the reply.
 I finally got it to install correctly.  After uninstalling everything (autodesk), I deleted the Autodesk folder from the c:\Program directory, the temp folder, and the 'hkey_local_machine\software\autodesk' instance from Windows 7 registry.  Rebooted and wha-la, a good install.
Hopefully it might help somelse.
Nick
Message 8 of 8
This worked for our SCCM 2007 deployment. All packages were linked with "Run another program first" setting and silent with no interaction.
1.  First step was a reboot package. Resolves layer eight issues.
2.  Second package update reg keys in HKLM for FaroSDK and VisualBasicPowerPacks3Setup and installs both packages, the previous reboot aviods the whole HKCU fiasco.
3. Autocad package install finished with another reboot.
The first two step as done in no time. The average AC install took between 15-35 minutes.
<soapbox> Autodesk needs to really work on making their product easier to depoly in a enterprise enviroment instead of the canned responses they give.</soapbox>
Administrator Productivity
