Installation & Licensing
Autocad - Autodesk Design Review 2012 installation problem
6 REPLIES 6
ryan.smyth12
987 Views, 6 Replies
Hello everyone,
here is the deal.
I had to format my HD, and now I want to resintall Autocad, but I keep on having issues about some temp files from ADR2012.
So i'm trying to instal Autodesk Design Review 2012, but it keeps asking for Microsoft Visual C++ 2010; which I have.
What can I do?
Thanks in advance
6 REPLIES 6
TravisNave
in reply to: ryan.smyth12
Go to your Control Panel and uninstall the version of Visual C++ 2010 Redistributable there.  It may not be a total package version if updated thru Windows Update.  Once uninstalled, reboot and then go to http://support.microsoft.com and download the full package and install it manually.  Then reboot and try your installer again.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
ryan.smyth12
in reply to: TravisNave
Thanks for the answer, but it does not solve my problem, I tried with the X64 and the X86 redist package. (I have a 64bit OS). No luck whatsoever
ryan.smyth12
I am coming back with my problem.
I retried to install autocad 2012, this is what happened:
anybody has a little idea to what I can do?
Thx in advance!
TravisNave
Try clearing your %TEMP% files and start the installer again with local admin rights, UAC off, and anti-virus disabled.
Autodesk Forums:
ryan.smyth12
Nope, it didn't work.
ryan.smyth12
I finally got it.
Was a bit difficult and a lot geeky. but was worth it.
Copied everything, change some registry base and tadam
Thx for the help
Administrator Productivity
