Installation & Licensing
Autocad ARS 2009 upgrade to Autocad BSD 2013 network version
3 REPLIES 3
564 Views, 3 Replies
Dear Autocad Expertise,
Recently , we have upgraded the Autocad ARS 2009 network version to Autocad BSD 2013. ARS is obsolete and the replacement is BSD. (Told by reseller).
Here in the license file, I can only see  the product  "85946BDSPRM_2013_0F" under the BSD package "85787BDSPRM_F" . Here I would like to konw if  "85946BDSPRM_2013_0F" already represented the product "85871ACD_2013_0F" ?
In previous ARS 2011 / 2009 , there are a product "85536ACD_2011_0F" /  "57600ACD_2009_0F" . Any Autocad 2011 or 2009 client connected to the server, it will consume this product license.
In the new BSD 2013, if there is a Autocad 2013 client connecting to the server , will it consume 1 lic in the product   "85946BDSPRM_2013_0F"?
Thank you very much in advance.
Raymond Cheung
3 REPLIES 3
TravisNave
AutoCAD 2013 will use a Building Design Suite license per the cascading effect of network licensing.  You can see how all the products cascade in 2013 products via this link:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=18708338&linkID=12305695
Your Subscription 2013 product will allow you to run 2013, 2012, 2011, and 2010.  Your 2009 is retired.  You cannot run more applications than the maximum seats that you own.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Thanks for your reply.
Do you mean Autocad 2013 included in Building Design Suite ? In the FlexNet code , there is no "85871ACD_2013_0F" under "85787BDSPRM_F". Autocad 2013 client will use the lic "85946BDSPRM_2013_0F".
In JTB report, there will show the usage of "85946BDSPRM_2013_0F" only.
TravisNave
Yes.  If the cascade is available for the product it will use the available license in the NLM.  If you have vanilla AutoCAD, it will pull the Building Design Suite Premium license, if available.  The report log will likely only show the license that was pull, regardless of product.  You'd have to ask Jimmy directly on the behavior of his software.
Autodesk Forums:
Administrator Productivity
