Installation & Licensing
Active Member
charlesquintonplatt
Message 1 of 11 (1,342 Views)
AutoCAD Architecture 2014 Setup.exe automatically initialising on start-up
1342 Views, 10 Replies
07-06-2013 12:57 PM
I have recently successfully installed a trial-/student-version of the AutoCAD Architecture 2014 software, and the program runs perfectly fine without errors, bugs or glitches (that I have noticed so far). However, every time I log into my computer (Windows 7), the following two windows appear:
>"Please wait while Windows configures AutoCAD Architecture 2014 - English."
>"Run Setup.exe to install AutoCAD Architecture 2014 - English."
This occurs again after clicking 'OK' to the second window, closing both. I can't seem to find any reason why this would happen, in the settings of AutoCAD, or in a list of programs set to start on log-in, or online. I'd really appreciate some help in stopping this.
Thank you,
Charles.
TravisNave
Message 2 of 11 (1,305 Views)
Re: AutoCAD Architecture 2014 Setup.exe automatically initialising on start-up
07-08-2013 08:51 AM in reply to: charlesquintonplatt
Welcome to the peer forum.
Do you have :
1.  Roaming profiles?
2.  Local Admin rights?
Active Member
charlesquintonplatt
Message 3 of 11 (1,300 Views)
07-08-2013 09:12 AM in reply to: TravisNave
Thank you,
Yes, I'm on my own laptop not connected to any network, and have admin rights.
TravisNave
Message 4 of 11 (1,297 Views)
07-08-2013 09:31 AM in reply to: charlesquintonplatt
Do you get it if you right-click and run as Administrator?
Sometimes installing Office or udpates moves your user to Debugger user for some strange reason.  You might double-check that your user is still Administrator.  Weirder things have happened.
It could also still be a user rights issue.  You haven't moved any of your profile folders to a different drive or removable disk, have you?
Active Member
charlesquintonplatt
Message 5 of 11 (1,292 Views)
07-08-2013 12:38 PM in reply to: TravisNave
I apologise if I wasn't clear the first time, but I mean that the two windows for installation appear as soon as I log into my account (the only and administrative account on this computer); the program runs absolutely fine and without problem when logged in, it is just the windows popping up on start-up. The windows for installation appear without me clicking on anything, as though they are set to run on log-in.
TravisNave
Message 6 of 11 (1,286 Views)
07-08-2013 01:35 PM in reply to: charlesquintonplatt
Could be.  Anything in your startup group?  Still thinking it is permissions related.
Active Member
charlesquintonplatt
Message 7 of 11 (1,266 Views)
07-09-2013 01:08 PM in reply to: TravisNave
The only two start-up programs I could see that seemed related to AutoCAD were the Autodesk Sync (AdSync.exe) and AcShellExtension.AcContextMenuHandler (AcShellExtension.dll). Disabling both of these for start-up (to see what happened) yielded nothing, and the boxes still appeared.
I still can't find any permissions-based issues. Any suggestions where options could be in AutoCAD itself, if a solution lay there?
Active Member
charlesquintonplatt
Message 8 of 11 (1,216 Views)
07-20-2013 07:40 AM in reply to: TravisNave
The problem is still occurring, and I can still find no solution - what exactly do you mean by 'permissions'?
New Member
jeigp_21
Message 9 of 11 (793 Views)
02-23-2014 03:21 PM in reply to: TravisNave
perdon ami tambien me pasa lo mismo y yo los movi de carpeta lo pade la unidad C A A LA D y por ende ya no me quiere abrir autocad que solucion tengo porque vuelvo y descargo autocad  para estudiantes y no me da porfavor  gracias.
Product Support
dembkod
Message 10 of 11 (778 Views)
02-24-2014 11:07 AM in reply to: charlesquintonplatt
charlesquintonplatt
Hello. It sounds like you have incorrect permissions on certain user folders. Check to make sure you have full access to these locations.
C:\Users\All Users\Autodesk
C:\Users\<the current user>\AppData\Local\Autodesk
C:\Users\<the current user>\AppData\Roaming\Autodesk
C:\Program Files\Common Files\Autodesk Shared
C:\Program Files\Autodesk
C:\ProgramData\FLEXnet
C:\ProgramData\Autodesk
Past this, I would create a new user account on the machine and test to see if the behavior persists.
Thank you for taking part in our community!
David Dembkoski
