Installation & Licensing
Welcome to Autodeskā€™s Installation and Licensing Forums. Share your knowledge, ask questions, and explore popular Download, Installation, and Licensing topics.
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
AUTOCAD ARCHITECTURE 2013 WONT INSTALL. PLEASE HELP!!
6 REPLIES 6
1673 Views, 6 Replies
ERROR LOG BELOW:
2012/12/3:04:18:54    God    GOD-PC    === Setup started on GOD-PC by God ===
2012/12/3:04:18:54    God    GOD-PC    Launch
2012/12/3:04:19:04    God    GOD-PC    === Setup ended ===
2012/12/3:04:18:56    God    GOD-PC    === Setup started on GOD-PC by God ===
2012/12/3:04:18:56    God    GOD-PC    Launch
2012/12/3:04:19:04    God    GOD-PC    PageOpen    LaunchDialog
2012/12/3:04:19:10    God    GOD-PC    === Setup ended ===
2012/12/3:04:21:04    God    GOD-PC    === Setup started on GOD-PC by God ===
2012/12/3:04:21:04    God    GOD-PC    Launch
2012/12/3:04:21:10    God    GOD-PC    === Setup ended ===
2012/12/3:04:21:05    God    GOD-PC    === Setup started on GOD-PC by God ===
2012/12/3:04:21:05    God    GOD-PC    Launch
2012/12/3:04:21:10    God    GOD-PC    PageOpen    LaunchDialog
2012/12/3:04:21:15    God    GOD-PC    PageOpen    LicenseDialog
2012/12/3:04:21:18    God    GOD-PC    PageOpen    ProductInfoDialog
2012/12/3:04:25:58    God    GOD-PC    PageOpen    ProductSelectionDialog2
2012/12/3:04:26:13    God    GOD-PC    PageOpen    FullProgressDialog
2012/12/3:04:26:13    God    GOD-PC    Installing DirectX Runtime: C:\Users\God\Desktop\archicard for architecture\3rdParty\DirectX\DXSETUP.exe /silent
2012/12/3:04:27:00    God    GOD-PC    Install    DirectX Runtime    Succeeded
2012/12/3:04:27:00    God    GOD-PC    Installing AutoCADĀ® Architecture 2013:  TRANSFORMS="C:\Users\God\Desktop\archicard for architecture\x64\en-us\ACA\ACA.mst;C:\Users\God\AppData\Local\Temp\_AIB117.tmp\x64\ACA\ACA-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Users\God\Desktop\archicard for architecture\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/12/3:04:28:55    God    GOD-PC    Install    AutoCADĀ® Architecture 2013    Failed    Installation aborted, Result=1603
2012/12/3:04:28:55    God    GOD-PC    Rollback    DirectX Runtime    Failed    Failure is ignored, Result=1619
6 REPLIES 6
asburyj
It's difficult to tell what is causing your install failure just from this log.Can you let us know if you are using an install media or did you download the installer? Also, do you have any other AutoCAD versions installed on your system?
Jeffry Asbury
in reply to: asburyj
sure. i downloaded autocad architecture 2013 straight from the autodesk website. plus the installation was attempted from the local drive.
 i do have autocad 2013 installed....and it works.
ac global 2013.log attached.
asburyj
Looking at the install log i see the faulting error is related to the ngen create action. To work around this error you will need to uninstall servicepack 1.1 from your AutoCAD and then try the ACA install again.
More details on this error can be found at the below link.
http://upandready.typepad.com/up_and_ready/2012/10/error-ngenexe-and-installing-any-autocad-product....
Jeffry Asbury
thanks so much, sir. worked a treat!!))))):smileyvery-happy:
filip_sovcik
Thank you
It works.Smiley Happy
Administrator Productivity
