Installation & Licensing
Member
celldelapriest
Message 1 of 7 (1,310 Views)
AUTOCAD ARCHITECTURE 2013 WONT INSTALL. PLEASE HELP!!
1310 Views, 6 Replies
12-02-2012 04:43 PM
ERROR LOG BELOW:
2012/12/3:04:18:54    God    GOD-PC    === Setup started on GOD-PC by God ===
2012/12/3:04:18:54    God    GOD-PC    Launch
2012/12/3:04:19:04    God    GOD-PC    === Setup ended ===
2012/12/3:04:18:56    God    GOD-PC    === Setup started on GOD-PC by God ===
2012/12/3:04:18:56    God    GOD-PC    Launch
2012/12/3:04:19:04    God    GOD-PC    PageOpen    LaunchDialog
2012/12/3:04:19:10    God    GOD-PC    === Setup ended ===
2012/12/3:04:21:04    God    GOD-PC    === Setup started on GOD-PC by God ===
2012/12/3:04:21:04    God    GOD-PC    Launch
2012/12/3:04:21:10    God    GOD-PC    === Setup ended ===
2012/12/3:04:21:05    God    GOD-PC    === Setup started on GOD-PC by God ===
2012/12/3:04:21:05    God    GOD-PC    Launch
2012/12/3:04:21:10    God    GOD-PC    PageOpen    LaunchDialog
2012/12/3:04:21:15    God    GOD-PC    PageOpen    LicenseDialog
2012/12/3:04:21:18    God    GOD-PC    PageOpen    ProductInfoDialog
2012/12/3:04:25:58    God    GOD-PC    PageOpen    ProductSelectionDialog2
2012/12/3:04:26:13    God    GOD-PC    PageOpen    FullProgressDialog
2012/12/3:04:26:13    God    GOD-PC    Installing DirectX Runtime: C:\Users\God\Desktop\archicard for architecture\3rdParty\DirectX\DXSETUP.exe /silent
2012/12/3:04:27:00    God    GOD-PC    Install    DirectX Runtime    Succeeded
2012/12/3:04:27:00    God    GOD-PC    Installing AutoCAD® Architecture 2013:  TRANSFORMS="C:\Users\God\Desktop\archicard for architecture\x64\en-us\ACA\ACA.mst;C:\Users\God\AppData\Local\Temp\_AIB117.tmp\x64\ACA\ACA-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Users\God\Desktop\archicard for architecture\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/12/3:04:28:55    God    GOD-PC    Install    AutoCAD® Architecture 2013    Failed    Installation aborted, Result=1603
2012/12/3:04:28:55    God    GOD-PC    Rollback    DirectX Runtime    Failed    Failure is ignored, Result=1619
Looking at the install log i see the faulting error is related to the ngen create action. To work around this error you will need to uninstall servicepack 1.1 from your AutoCAD and then try the ACA install again.
More details on this error can be found at the below link.
http://upandready.typepad.com/up_and_ready/2012/10/error-ngenexe-and-installing-any-autocad-product.html
Product Support
asburyj
Message 2 of 7 (1,285 Views)
Re: AUTOCAD ARCHITECTURE 2013 WONT INSTALL. PLEASE HELP!!
12-03-2012 03:44 PM in reply to: celldelapriest
It's difficult to tell what is causing your install failure just from this log.Can you let us know if you are using an install media or did you download the installer? Also, do you have any other AutoCAD versions installed on your system?
Jeffry Asbury
Member
celldelapriest
Message 3 of 7 (1,271 Views)
12-04-2012 12:52 AM in reply to: asburyj
sure. i downloaded autocad architecture 2013 straight from the autodesk website. plus the installation was attempted from the local drive.
 i do have autocad 2013 installed....and it works.
Member
celldelapriest
Message 4 of 7 (1,247 Views)
12-04-2012 11:59 AM in reply to: asburyj
ac global 2013.log attached.
Product Support
asburyj
Message 5 of 7 (1,243 Views)
12-04-2012 01:06 PM in reply to: celldelapriest
http://upandready.typepad.com/up_and_ready/2012/10/error-ngenexe-and-installing-any-autocad-product....
Jeffry Asbury
Member
celldelapriest
Message 6 of 7 (1,237 Views)
12-04-2012 01:37 PM in reply to: asburyj
thanks so much, sir. worked a treat!!))))):smileyvery-happy:
New Member
filip.sovcik
Message 7 of 7 (638 Views)
04-06-2013 03:57 PM in reply to: celldelapriest
Thank you
It works.:smileyhappy:
