Installation & Licensing
AutoCAD Architecture 2013 Windows 7 64bit
1 REPLY 1
psills
798 Views, 1 Reply
When trying to create a deployment image I am configuring the location of the content to a network drive, however the software will not see any of my network drives. Through windows explorer I can see all the drive mappings with no problems but when I try to change the mapping for the styles or content and use shared or local and select the button to set the location it only displays my local drives only. This also happens with other Autodesk 2013 products as well. Is there a registry hack I can use to fix this?
1 REPLY 1
david.lau
in reply to: psills
Can you provide some detail on what is being changed in the deployment?  Can you provide some screen shots of customizations?
David Lau
Administrator Productivity
