Installation & Licensing
New Member
0 Kudos
Post 1 of 1
AutoCAD Architecture 2013 installation error
130 Views, 0 Replies
03-13-2014 05:18 PM
I tried a couplke different time to install AutoCAD Architecture 2013.  Everything seem to be installing fine then at the end I got it said "AutoCAD Architecture did not install"  and below is the installation log
2014/3/13:06:40:12 David King DAVIDKING-PC === Setup started on DAVIDKING-PC by David King ===
2014/3/13:06:40:12 David King DAVIDKING-PC Launch
2014/3/13:06:40:12 David King DAVIDKING-PC Setup Windows update reboot is pending
2014/3/13:06:40:38 David King DAVIDKING-PC Setup AutoCAD Architecture 2013 Will restart automatically.
2014/3/13:06:40:39 David King DAVIDKING-PC === Setup ended ===
2014/3/13:06:48:35 David King DAVIDKING-PC === Setup started on DAVIDKING-PC by David King ===
2014/3/13:06:48:35 David King DAVIDKING-PC Launch
2014/3/13:06:48:59 David King DAVIDKING-PC === Setup ended ===
2014/3/13:06:48:40 David King DAVIDKING-PC === Setup started on DAVIDKING-PC by David King ===
2014/3/13:06:48:40 David King DAVIDKING-PC Launch
2014/3/13:06:49:00 David King DAVIDKING-PC PageOpen LaunchDialog
2014/3/13:06:52:01 David King DAVIDKING-PC PageOpen LicenseDialog
2014/3/13:06:52:05 David King DAVIDKING-PC PageOpen ProductInfoDialog
2014/3/13:06:52:38 David King DAVIDKING-PC PageOpen ProductSelectionDialog2
2014/3/13:06:52:48 David King DAVIDKING-PC PageOpen FullProgressDialog
2014/3/13:06:52:48 David King DAVIDKING-PC Installing DirectX Runtime: C:\Autodesk\AutoCAD_Architecture_2013_English_Win_32Bit\3rdParty\DirectX\DXSETUP.exe /silent
2014/3/13:06:54:41 David King DAVIDKING-PC Install DirectX Runtime Succeeded
2014/3/13:06:54:41 David King DAVIDKING-PC Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_Architecture_2013_English_Win_32Bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/3/13:06:56:58 David King DAVIDKING-PC Install Autodesk Material Library 2013 Succeeded
2014/3/13:06:56:58 David King DAVIDKING-PC Installing Autodesk Material Library 2013 - Low Resolution: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_Architecture_2013_English_Win_32Bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/3/13:06:58:40 David King DAVIDKING-PC Install Autodesk Material Library 2013 - Low Resolution Succeeded
2014/3/13:06:58:41 David King DAVIDKING-PC Installing AutoCAD® Architecture 2013: TRANSFORMS="C:\Autodesk\AutoCAD_Architecture_2013_English_Win_32Bit\x86\en-us\ACA\ACA.mst;C:\Users\DAVIDK~1\AppData\Local\Temp\_AI5DC8.tmp\x86\ACA\ACA-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_Architecture_2013_English_Win_32Bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/3/13:07:12:08 David King DAVIDKING-PC Install AutoCAD® Architecture 2013 Succeeded
2014/3/13:07:12:10 David King DAVIDKING-PC Installing AutoCAD® Architecture 2013 Language Pack: TRANSFORMS="C:\Users\DAVIDK~1\AppData\Local\Temp\_AI5DC8.tmp\_laEE3A.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us MUIHIDEARP=1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_Architecture_2013_English_Win_32Bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/3/13:07:15:24 David King DAVIDKING-PC Install AutoCAD® Architecture 2013 Language Pack Succeeded
2014/3/13:07:15:24 David King DAVIDKING-PC Installing AutoCAD® Architecture 2013 Product Specific Pack: INSTALLSHORTCUTS=0 ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_Architecture_2013_English_Win_32Bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/3/13:07:35:14 David King DAVIDKING-PC Install AutoCAD® Architecture 2013 Product Specific Pack Succeeded
2014/3/13:07:35:14 David King DAVIDKING-PC Installing Autodesk Cloud sync: ADLANGUAGE=en-US ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_Architecture_2013_English_Win_32Bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/3/13:07:36:11 David King DAVIDKING-PC Install Autodesk Cloud sync Failed Installation aborted, Result=1603
2014/3/13:07:37:59 David King DAVIDKING-PC Rollback AutoCAD® Architecture 2013 Product Specific Pack Succeeded
2014/3/13:07:41:19 David King DAVIDKING-PC Rollback AutoCAD® Architecture 2013 Language Pack Succeeded
2014/3/13:07:53:49 David King DAVIDKING-PC Rollback AutoCAD® Architecture 2013 Succeeded
2014/3/13:07:53:59 David King DAVIDKING-PC Rollback Autodesk Material Library 2013 - Low Resolution Succeeded
2014/3/13:07:56:40 David King DAVIDKING-PC Rollback Autodesk Material Library 2013 Succeeded
2014/3/13:07:56:40 David King DAVIDKING-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2014/3/13:07:56:42 David King DAVIDKING-PC PageOpen InstallCompleteDialog
2014/3/13:08:00:08 David King DAVIDKING-PC === Setup ended ===
2014/3/13:08:01:03 David King DAVIDKING-PC === Setup started on DAVIDKING-PC by David King ===
2014/3/13:08:01:03 David King DAVIDKING-PC Launch
2014/3/13:08:01:42 David King DAVIDKING-PC === Setup ended ===
2014/3/13:08:01:09 David King DAVIDKING-PC === Setup started on DAVIDKING-PC by David King ===
2014/3/13:08:01:09 David King DAVIDKING-PC Launch
2014/3/13:08:01:37 David King DAVIDKING-PC PageOpen LaunchDialog
2014/3/13:08:01:40 David King DAVIDKING-PC PageOpen LicenseDialog
2014/3/13:08:01:44 David King DAVIDKING-PC PageOpen ProductInfoDialog
2014/3/13:08:02:09 David King DAVIDKING-PC PageOpen ProductSelectionDialog2
2014/3/13:08:02:23 David King DAVIDKING-PC PageOpen FullProgressDialog
2014/3/13:08:02:24 David King DAVIDKING-PC Installing DirectX Runtime: C:\Autodesk\AutoCAD_Architecture_2013_English_Win_32Bit\3rdParty\DirectX\DXSETUP.exe /silent
2014/3/13:08:03:44 David King DAVIDKING-PC Install DirectX Runtime Succeeded
2014/3/13:08:03:44 David King DAVIDKING-PC Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_Architecture_2013_English_Win_32Bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/3/13:08:05:48 David King DAVIDKING-PC Install Autodesk Material Library 2013 Failed Installation aborted, Result=1602
2014/3/13:08:05:48 David King DAVIDKING-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2014/3/13:08:05:49 David King DAVIDKING-PC PageOpen InstallCompleteDialog
2014/3/13:08:05:54 David King DAVIDKING-PC === Setup ended ===
2014/3/13:08:07:01 David King DAVIDKING-PC === Setup started on DAVIDKING-PC by David King ===
2014/3/13:08:07:01 David King DAVIDKING-PC Launch
2014/3/13:08:07:24 David King DAVIDKING-PC === Setup ended ===
2014/3/13:08:07:06 David King DAVIDKING-PC === Setup started on DAVIDKING-PC by David King ===
2014/3/13:08:07:06 David King DAVIDKING-PC Launch
2014/3/13:08:07:20 David King DAVIDKING-PC PageOpen LaunchDialog
2014/3/13:08:07:24 David King DAVIDKING-PC PageOpen LicenseDialog
2014/3/13:08:07:29 David King DAVIDKING-PC PageOpen ProductInfoDialog
2014/3/13:08:07:44 David King DAVIDKING-PC PageOpen ProductSelectionDialog2
2014/3/13:08:07:51 David King DAVIDKING-PC PageOpen FullProgressDialog
2014/3/13:08:07:51 David King DAVIDKING-PC Installing DirectX Runtime: C:\Autodesk\AutoCAD_Architecture_2013_English_Win_32Bit\3rdParty\DirectX\DXSETUP.exe /silent
2014/3/13:08:08:36 David King DAVIDKING-PC Install DirectX Runtime Succeeded
2014/3/13:08:08:36 David King DAVIDKING-PC Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_Architecture_2013_English_Win_32Bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/3/13:08:10:29 David King DAVIDKING-PC Install Autodesk Material Library 2013 Succeeded
2014/3/13:08:10:29 David King DAVIDKING-PC Installing Autodesk Material Library 2013 - Low Resolution: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_Architecture_2013_English_Win_32Bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/3/13:08:10:58 David King DAVIDKING-PC Install Autodesk Material Library 2013 - Low Resolution Succeeded
2014/3/13:08:10:59 David King DAVIDKING-PC Installing AutoCAD® Architecture 2013: TRANSFORMS="C:\Autodesk\AutoCAD_Architecture_2013_English_Win_32Bit\x86\en-us\ACA\ACA.mst;C:\Users\DAVIDK~1\AppData\Local\Temp\_AI2D77.tmp\x86\ACA\ACA-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_Architecture_2013_English_Win_32Bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/3/13:08:22:01 David King DAVIDKING-PC Install AutoCAD® Architecture 2013 Succeeded
2014/3/13:08:22:03 David King DAVIDKING-PC Installing AutoCAD® Architecture 2013 Language Pack: TRANSFORMS="C:\Users\DAVIDK~1\AppData\Local\Temp\_AI2D77.tmp\_laE97B.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us MUIHIDEARP=1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_Architecture_2013_English_Win_32Bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/3/13:08:24:28 David King DAVIDKING-PC Install AutoCAD® Architecture 2013 Language Pack Succeeded
2014/3/13:08:24:28 David King DAVIDKING-PC Installing AutoCAD® Architecture 2013 Product Specific Pack: INSTALLSHORTCUTS=0 ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_Architecture_2013_English_Win_32Bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/3/13:08:43:06 David King DAVIDKING-PC Install AutoCAD® Architecture 2013 Product Specific Pack Succeeded
2014/3/13:08:43:06 David King DAVIDKING-PC Installing Autodesk Cloud sync: ADLANGUAGE=en-US ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_Architecture_2013_English_Win_32Bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/3/13:08:43:12 David King DAVIDKING-PC Install Autodesk Cloud sync Failed Installation aborted, Result=1603
2014/3/13:08:44:48 David King DAVIDKING-PC Rollback AutoCAD® Architecture 2013 Product Specific Pack Succeeded
2014/3/13:08:47:46 David King DAVIDKING-PC Rollback AutoCAD® Architecture 2013 Language Pack Succeeded
2014/3/13:08:59:30 David King DAVIDKING-PC Rollback AutoCAD® Architecture 2013 Succeeded
2014/3/13:08:59:42 David King DAVIDKING-PC Rollback Autodesk Material Library 2013 - Low Resolution Succeeded
2014/3/13:09:02:04 David King DAVIDKING-PC Rollback Autodesk Material Library 2013 Succeeded
2014/3/13:09:02:05 David King DAVIDKING-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2014/3/13:09:02:06 David King DAVIDKING-PC PageOpen InstallCompleteDialog
2014/3/13:09:32:02 David King DAVIDKING-PC === Setup ended ===
2014/3/13:09:33:31 David King DAVIDKING-PC === Setup started on DAVIDKING-PC by David King ===
2014/3/13:09:33:31 David King DAVIDKING-PC Launch
2014/3/13:09:34:18 David King DAVIDKING-PC === Setup ended ===
2014/3/13:09:33:39 David King DAVIDKING-PC === Setup started on DAVIDKING-PC by David King ===
2014/3/13:09:33:39 David King DAVIDKING-PC Launch
2014/3/13:09:34:19 David King DAVIDKING-PC PageOpen LaunchDialog
2014/3/13:09:35:40 David King DAVIDKING-PC PageOpen LicenseDialog
2014/3/13:09:35:40 David King DAVIDKING-PC PageOpen ProductSelectionDialog2
2014/3/13:09:36:20 David King DAVIDKING-PC PageOpen LicenseDialog
2014/3/13:09:36:20 David King DAVIDKING-PC PageOpen LaunchDialog
2014/3/13:09:37:41 David King DAVIDKING-PC PageOpen LicenseDialog
2014/3/13:09:37:44 David King DAVIDKING-PC PageOpen ProductInfoDialog
2014/3/13:09:38:20 David King DAVIDKING-PC PageOpen ProductSelectionDialog2
2014/3/13:09:40:19 David King DAVIDKING-PC PageOpen FullProgressDialog
2014/3/13:09:40:19 David King DAVIDKING-PC Installing DirectX Runtime: C:\Autodesk\AutoCAD_Architecture_2013_English_Win_32Bit\3rdParty\DirectX\DXSETUP.exe /silent
2014/3/13:09:41:37 David King DAVIDKING-PC Install DirectX Runtime Succeeded
2014/3/13:09:41:37 David King DAVIDKING-PC Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_Architecture_2013_English_Win_32Bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/3/13:09:42:40 David King DAVIDKING-PC Install Autodesk Material Library 2013 Succeeded
2014/3/13:09:42:40 David King DAVIDKING-PC Installing Autodesk Material Library 2013 - Low Resolution: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_Architecture_2013_English_Win_32Bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
I currently have AutoCAD Architecure 2012 and 2014 installed and working.  I figured 2013 should install no problem. I turned off my antivirus becuase I saw that worked for others.
PLEASE HELP!!!!!!
Post to the Community
New Post
