Installation & Licensing
New Member
oasisdesigns
Message 1 of 3 (203 Views)
Autocad Architecture 2013 fails to install from installation CD
203 Views, 2 Replies
12-07-2012 12:17 PM
Installation fails when it gets to Content Service with installer error code 2738.  I previously had a successful installation on this machine where the software would run but I couldn't access the content libraries.  The dialogue box would come up with nothing there.  I tried uninstalling everything, including folders and registry keys, but now re-install doesn't work.  I've attached the install log.  Any help would be greatly appreciated!
f_bastos_pinto
Message 2 of 3 (184 Views)
Re: Autocad Architecture 2013 fails to install from installation CD
12-07-2012 02:43 PM in reply to: oasisdesigns
Did you run CC cleaner? That is happening because you had the version previously installed.
I also see that you dont have admin rights on your system, at least reading the log.
Can you fix that?
philip.s
Message 3 of 3 (177 Views)
12-07-2012 03:11 PM in reply to: f_bastos_pinto
Hello Christine,
I believe Frederico is spot on in that you may have remnants of the previous install preventing a new one from completing. There are a couple other "non-supported" clean uninstall processes listed here, along with our "supported" method.
Philip Schmelzer
