I am trying to install Architecture 2012 but it fails to install giving the following error.
1: 5 2 adlmPITSetProductionInformation failed. 3: 2
I have checked all the system requirements and all fall well within what is required. I have also disabled all antivirus. I am trying to install as a stand alone licence so i cant even blame the network.
Help
Solved by TravisNave. Go to Solution.
Start here:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?id=13540825&linkID=10382101&siteID=123112
More options can be found here:
For additional information, please consider using Search to assist in your resolution:
Search Autodesk.com
Search Autodesk Discussion Groups
Search Up and Ready Blog
Search Autodesk WikiHelp
