i need help with this, can someone help me solve this problem.
i tried installing many times and same error shows over and over....
i have the attachment so you can take a look.
thanks
2012/2/3:21:31:19 Thiago AMBROSIO === Setup started on AMBROSIO by Thiago ===
2012/2/3:21:31:19 Thiago AMBROSIO Launch
2012/2/3:21:32:55 Thiago AMBROSIO === Setup ended ===
2012/2/3:21:32:56 Thiago AMBROSIO PageOpen LaunchDialog
2012/2/3:21:33:40 Thiago AMBROSIO PageOpen LicenseDialog
2012/2/3:21:33:46 Thiago AMBROSIO PageOpen ProductInfoDialog
2012/2/3:21:37:13 Thiago AMBROSIO PageOpen ProductSelectionDialog2
2012/2/3:21:37:24 Thiago AMBROSIO PageOpen FullProgressDialog
2012/2/3:21:37:24 Thiago AMBROSIO Installing .NET Framework Runtime 4.0: C:\Autodesk\AutoCAD_Architecture_2012_English_Win_64Bit\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q
2012/2/3:21:46:16 Thiago AMBROSIO Install .NET Framework Runtime 4.0 Failed Installation aborted, Result=1603
2012/2/3:21:46:19 Thiago AMBROSIO PageOpen InstallCompleteDialog
2012/2/3:21:47:42 Thiago AMBROSIO === Setup ended ===
2012/2/3:22:09:42 Thiago AMBROSIO === Setup started on AMBROSIO by Thiago ===
2012/2/3:22:09:42 Thiago AMBROSIO Launch
2012/2/3:22:11:19 Thiago AMBROSIO === Setup ended ===
2012/2/3:22:09:45 Thiago AMBROSIO === Setup started on AMBROSIO by Thiago ===
2012/2/3:22:09:45 Thiago AMBROSIO Launch
2012/2/3:22:11:21 Thiago AMBROSIO PageOpen LaunchDialog
2012/2/3:22:23:11 Thiago AMBROSIO PageOpen LicenseDialog
2012/2/3:22:23:11 Thiago AMBROSIO PageOpen ProductSelectionDialog2
2012/2/3:22:23:33 Thiago AMBROSIO PageOpen LicenseDialog
2012/2/3:22:23:33 Thiago AMBROSIO PageOpen LaunchDialog
2012/2/3:22:23:59 Thiago AMBROSIO PageOpen BeginDeploymentDialog
2012/2/3:22:24:18 Thiago AMBROSIO PageOpen LaunchDialog
2012/2/3:22:24:29 Thiago AMBROSIO PageOpen LicenseDialog
2012/2/3:22:24:34 Thiago AMBROSIO PageOpen ProductInfoDialog
2012/2/3:22:25:25 Thiago AMBROSIO PageOpen ProductSelectionDialog2
2012/2/3:22:26:54 Thiago AMBROSIO PageOpen FullProgressDialog
2012/2/3:22:26:55 Thiago AMBROSIO Installing .NET Framework Runtime 4.0: C:\Autodesk\AutoCAD_Architecture_2012_English_Win_64Bit\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q
2012/2/3:22:38:10 Thiago AMBROSIO Install .NET Framework Runtime 4.0 Failed Installation aborted, Result=1603
2012/2/3:22:38:12 Thiago AMBROSIO PageOpen InstallCompleteDialog
2012/2/4:01:01:34 Thiago AMBROSIO === Setup ended ===
2012/2/4:13:19:58 Thiago AMBROSIO === Setup started on AMBROSIO by Thiago ===
2012/2/4:13:19:58 Thiago AMBROSIO Launch
2012/2/4:13:21:48 Thiago AMBROSIO === Setup ended ===
2012/2/4:13:20:03 Thiago AMBROSIO === Setup started on AMBROSIO by Thiago ===
2012/2/4:13:20:03 Thiago AMBROSIO Launch
2012/2/4:13:21:50 Thiago AMBROSIO PageOpen LaunchDialog
2012/2/4:17:05:01 Thiago AMBROSIO PageOpen LicenseDialog
2012/2/4:17:05:17 Thiago AMBROSIO PageOpen ProductInfoDialog
2012/2/4:17:05:21 Thiago AMBROSIO PageOpen ProductSelectionDialog2
2012/2/4:17:05:29 Thiago AMBROSIO PageOpen FullProgressDialog
2012/2/4:17:05:29 Thiago AMBROSIO Installing .NET Framework Runtime 4.0: C:\Autodesk\AutoCAD_Architecture_2012_English_Win_64Bit\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q
2012/2/4:17:14:44 Thiago AMBROSIO Install .NET Framework Runtime 4.0 Failed Installation aborted, Result=1603
2012/2/4:17:14:47 Thiago AMBROSIO PageOpen InstallCompleteDialog
2012/2/4:17:15:48 Thiago AMBROSIO === Setup ended ===
2012/2/4:18:47:03 Thiago AMBROSIO === Setup started on AMBROSIO by Thiago ===
2012/2/4:18:47:03 Thiago AMBROSIO Launch
2012/2/4:18:47:55 Thiago AMBROSIO === Setup ended ===
2012/2/4:18:47:06 Thiago AMBROSIO === Setup started on AMBROSIO by Thiago ===
2012/2/4:18:47:06 Thiago AMBROSIO Launch
2012/2/4:18:48:02 Thiago AMBROSIO PageOpen LaunchDialog
2012/2/4:18:50:54 Thiago AMBROSIO You are attempting to use a 32-bit installer on a 64-bit operating system.
Please exit and use the 64-bit installer available from your installation media or from Autodesk.com.2012/2/4:18:51:17 Thiago AMBROSIO === Setup ended ===
2012/2/5:02:15:32 Thiago AMBROSIO === Setup started on AMBROSIO by Thiago ===
2012/2/5:02:15:32 Thiago AMBROSIO Launch
2012/2/5:02:17:53 Thiago AMBROSIO === Setup ended ===
2012/2/5:02:15:33 Thiago AMBROSIO === Setup started on AMBROSIO by Thiago ===
2012/2/5:02:15:33 Thiago AMBROSIO Launch
2012/2/5:02:17:57 Thiago AMBROSIO PageOpen LaunchDialog
2012/2/5:03:04:18 Thiago AMBROSIO PageOpen LicenseDialog
2012/2/5:03:04:24 Thiago AMBROSIO PageOpen ProductInfoDialog
2012/2/5:03:04:35 Thiago AMBROSIO PageOpen ProductSelectionDialog2
2012/2/5:03:04:42 Thiago AMBROSIO PageOpen FullProgressDialog
2012/2/5:03:04:43 Thiago AMBROSIO Installing .NET Framework Runtime 4.0: C:\Autodesk\AutoCAD_Architecture_2012_English_Win_64Bit\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q
2012/2/5:03:20:54 Thiago AMBROSIO Install .NET Framework Runtime 4.0 Failed Installation aborted, Result=1603
Per our PM message offline, please let me know if the .NET Framework cleanup tool and reinstall of AutoCAD solved your issue.
Per our continued PM string, your PIT issue can be resolved by deleting your ProductInformation.pit file per this link:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13540825&linkID=9241177
