Does anyone know how to download it when it says I have it downloaded already and need a language pack, after deleting/uninstaloing all programs. I tried downloading the langauge pack and it failed too saying I dont have the program downloaded ! so annoying , please help
Have you tried downloading the AA Language Pack from here... http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=21306590&linkID=9240658
Install AA 2014 again and then try installing the language pack or add it to your Deployment Image.
Duncan
It worked this time however when i open the program it says error and something about Problem loading AcBrandRes.dll resource file
Have installed building design suite premium and Infrastructure design suite premium. 2016 on a separate external harddrive that I selected for the install proces to point to. When I go and execute autocad map or navisworks it says.....problem loading acbrandres.dll resource file.
When I execute Map3d or plain autocad it also problem loading acbrandres.dll resource file. If I execute autcad Architecture or 3d max it runs fine. I have no room on my C:drive what is the problem?. Thank You
