Hey
I fixed my computer and deleted AutoCAD 2013, but whene i install it again it says that AutoCAD 2013 already installed
and its not !!
what can i do?
Please help me
Solved by avto. Go to Solution.
Hello and welcome to the forums.
There must be some AutoCAD 2013 related orphaned registry keys from the previous installation attempt.
Please check for the following registry keys and if you find them in registry, export them as .reg files for backup purposes and then delete them from your system registry.
HKEY_CLASSES_ROOT\Installer\Products\7D2F3875100B0000102000060BECB6AB
HKEY_CLASSES_ROOT\Installer\Products\7D2F3875100B9040112000060BECB6AB
HKEY_CLASSES_ROOT\Installer\Products\7D2F3875100B9040122000060BECB6AB
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Products\7D2F3875100B0000102000060BECB6AB
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Products\7D2F3875100B9040112000060BECB6AB
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Products\7D2F3875100B9040122000060BECB6AB
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{5783F2D7-B001-0000-0102-0060B0CE6BBA}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{5783F2D7-B001-0409-1102-0060B0CE6BBA}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{5783F2D7-B001-0409-2102-0060B0CE6BBA}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\AutoCAD 2013 - English
After this if you do not have ACAD 2013 installation media download ACAD 2013 installer from virtual agent.
1.Go to http://www.autodesk.com
2.At the bottom of the page, beneath Help and Support, click Customer Service.
3.Click the Ask button.
4.In the Virtual Agent window, click Downloading and Installation.
5.Click Software Download links.
6.Click "I need to redownload my product."
7.Click AutoCAD Products
8.Select the appropriate product and click the link to download.
To Install AutoCAD 2013 follow steps below:
1.Logon as an Administrator.
2.Empty your TEMP folder. To open the TEMP folder, type %TEMP% in the address bar of Windows Explorer and hit Enter.
3.Disable your Antivirus software.
5.Install AutoCAD 2013.
Please let us know if this helps.
Welcome to the Autodesk User's Community..
If you are saying that its listed as being installed but its not.. Then use Microsoft Fixit to remove it.
Mark Lancaster
& Autodesk Services MarketPlace Provider
is what only for 2013?
DarrenP
