Is there a cleaner to completely clean a failed installation.
I have follwed online instructions and during the new installation AutoCAD 2013 shows as installed, preventing reinstall.
Any suggestions?
A lot of this today... To Diagnose and Fix installation problems automatically, please see the new Microsoft tool for this here:
http://support.microsoft.com/mats/Program_Install_and_Uninstall
For more information on the Autodesk KB Support article concerning the clean uninstall of Autodesk products, see this link:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617
For all other installation problems consider using the Microsoft Installer Clean Up Utility. For more information on this program, please my forum post here:
http://forums.autodesk.com/t5/Installation-Licensing/Microsoft-Installer-Clean-Up-Utility-for-Add-Re...
The initial procedure that I used was from the Autodesk KB.
I used the new MS celanup tool, it was not able to find any Autodesk/AutoCAD listing and could not un-install. I also downloaded the old one and used it - no luck.
I have deleted every thing on my dirvie that is Autodesk and AutoCAD. I have manually suearched the registry for any entries and have delted them. I have cleaned out all the temp folders that I can find. again no luck.
Any other suggestions?
What is the error that you are getting on install?
When I get to the installation screen, it show ACAD 2013 is already installed.
I need to install 2013, I have no shortcut on the start menu, I have no Autodesk or AutoCAD folders.
For some reason that I can't find, I am not allowed to install AutoCAD 2013. The other items, vault, etc. I am allowed to install.
I am getting an error.
If there is a log somewhere, that I can send you, you will have to guide me to it. I haven't fould any.
And you're telling me that none of the cleanup tools I provided works? Even the MSICUU2? That thing is so violent that Microsoft and Autodesk both removed all support for it and yell at me every time I post it. I have a hard time believing that it didn't work. You can use that program for exercisms!
Sorry, that is what I am telling you.
When it displays the list, both the new clean up and the old one, they display the programs that I have, but no Autodesk products.
I have performed a search looking for any AutoCAD or Autodesk files. I have gone through the registry oooking for any AutoCAD/Autodesk enries, I have deleted any that I have found, I have rebooted before i try a new install. I have also deleted all the files in the Windows/Temp directory.
I am out of Ideas.
That is pretty wild. You might have to drill down the SSIDs of the installed programs for the Control Panel manually. I don't know what else to possibly tell you as to why it thinks it is installed when it isn't. The MSICUU2 works so well, I'm tempted to use it on the White House!
Using it on the white is probably why you are not encouraged to use it.
I am not familiar with the SSIDs in control panel. Can you guide me?
Yeah, try by starting here:
http://support.microsoft.com/kb/314481
