Solved by camilo.lemos. Go to Solution.
Hi special_dani05, welcome to our Community!
Your license's 3-year period starts counting when you first activate the product (input your serial number and product key after the installation). The 3-year period cannot be stopped and resumed later.
Please accept as solution if my post fully resolves your issue, or reply with additional details if the problem persists.
Hi special_dani05,
If you selected the "Install Now" download method and if you are able to run the software automatically (not as a trial version) this means that the product has been activated and your 3-year use period has started.
After installing Autocad I try to start the software and i get a " can not start acad.exe (0xc00000142) ERROR message. Can someone help to correct this. I have uninstalled and reinstalled a couple times with going thourgh the complete uninstall.
Hi @tkwelding,
Please take the following steps to acheive the best download performance:
Please let me know how it goes! Thanks!
The software is installed the problem is when i double click on the icon it gives me an error messaGE unable to start program error (0xc0000142).
Hi @morusalbaf1 and welcome to the Autodesk Community!
Your license will become activated once you download and install your product from the Education Community. If your product has not been activated, you will receive a notification when you open the product prompting you to activate as you'd only be running a trial. If you have any further questions please reply to this post. Thanks!
Hello @anumulaanvesh,
Can you please elaborate as to what issue you are facing when you attempt to download software from the Education Community? If you haven't already, does selecting a different download method work, specifically Browser Download?
hi, i started the installation process but stopped and cancelled it in between..so has my 3 year license activated or not??
Welcome to the Autodesk User's Community..
@jyotibikashm143 wrote:
Hi. After
Do you have an issue or not?
Mark Lancaster
& Autodesk Services MarketPlace Provider
Hello @jyotibikashm143,
Welcome to the Autodesk Community!
If you have a Student license and are still eligible by the time AutoCAD 2019 is released, then you'll need to sign into Education Community and download the 2019 version from there. A new entitlement will be generated, which will be valid for 3 years.
If you are a Commercial user and your subscription is active when AutoCAD 2019 is released, then you'll need to log into your Autodesk Account and download the 2019 from there. That entitlement will be valid until the end of your subscription.
