I have created a deployment package within SCCM 2012 for AutoCAD 2017, it takes a while to download & verify the contents, but when it finally gets to the installation I get the attached Autodesk Installer Error Report, i can't seem to figure out why....any idea why or where to start investigations?
Dumpdata & SCCM 2012 log files also attached
Solved by Mark.Lancaster. Go to Solution.
The user dump xml file is pointing to a upiconfig.xml error. In the past this was related to having service packs included in your deployment. Do you have any of the service packs/updates for AutoCAD 2017 included? Anyhow I'm only assuming at this point and not 100% sure this is the actual reason why its failing. Also have you run your deployment as a test in a non-silent mode to see if any error message appears?
I will also tag the heavy hitters @Darin.Green and @TravisNave for their input.
Mark Lancaster
& Autodesk Services MarketPlace Provider
Thanks Mark.Lancaster
I do have AutoCAD 2017 SP1 included into the deployment package.
I have not tested in a non-silent mode, i will do that and report back.
I would also reiterate Mark's point that including updates and service packs into a deployment is generally problematic and should normally be avoided if installation fails.
Would you suggest a package for the main deployment, then a 2nd for any SP updates, despite there being a feature to add the SP updates into the package?
@TravisNave and I will tell you.. Just because a service pack or an update is there doesn't mean you need it. Why break something that is working.. But at this point you haven't even installed the application so you don;t know if you need the update or not...
Mark Lancaster
Thanks for the advice...I'm new to packaging & this is my 1st attempt with any Autodesk product!
Hello @ARomain,
Welcome back. Glad to hear that a solution to your issue has been addressed. Did @Mark.Lancaster or @TravisNave answer your questions? Please "Accept As Solution" if a reply has helped resolved the issue or answered your question, to help others in the community.
Thank you for posting!
Natasha
Community Product Support Specialist
Helpful Links:
AutoCAD Videos | AutoCAD Crashes or Freezes | AutoCAD Customer Council | AutoCAD System Requirements | Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
I’ve had troubles packaging AutoCAD 2017 with the SP1 update together so I have managed to create 2 working packages and only 1 AD group for installations:
1 - AutoCAD 2017
2 - AutoCAD 2017 SP1 update
package 2 has a dependency for package 1, however once package 1 has run the machine requires a restart before package 2 will run, following the restart all completes successfully….do you know if there is another way round this?
