I've been using Microsoft Deployment Toolkit (MDT) for a few years and have only recently run into this issue.
I build a VM completely (applications and Windows profile settings) under the built-in "Administrator" account. While logged in and installing AutoCAD, I set all the support paths (and other Options) to what I want and export that profile to "CADUser.arg"
I then capture that VM as a custom wim file. I create a task sequence to deploy the wim file and I edit the unattend.xml to set the "copyprofile" parameter to "true", thus applying all my settings that I set under the Administrator account to the "Default User" profile so that they apply to anyone that logs into the machine.
Once I deploy the image, I log in (after adding the particular user account to the local "administrators" group in Computer Management), and I open AutoCAD and import the profile ("CADUser.arg"). When I look at the support paths, they are retaining the "C:\Users\Administrator\..." path rather than updating to the currently logged in user path. In the past, this seemed to just work.
What steps am I missing, or what process should I be doing to make sure that the AutoCAD profile (CADUser.arg) that we import is generalized to work for anyone that logs in?
It looks like the registry key "HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R21.0\ACAD-0001:409\RoamableRootFolder" might be the cuplrit and needs to be edited for each new user. I'm just curious how other people are doing their AutoCAD deployments.
Solved by owen66. Go to Solution.
Hello @owen66,
Thank you for returning and contributing to the community with your results. Keep posting!
Natasha
Community Product Support Specialist
Helpful Links:
AutoCAD Videos | AutoCAD Crashes or Freezes | AutoCAD Customer Council | AutoCAD System Requirements | Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
