Hello. I changed the system for Windows 8.1 pro 64 bit. I have a student license for AutoCAD 2015 and wanted to install it. When the installation gives me an error. I do not know what to do. Include a screen pops up to what I.
Please try a browser download of the software. If you are using an ENGLISH version, you can grab it from the blog via upandready.typepad.com.
https://screencast.autodesk.com/main/details/be571ea9-fffc-40d6-8338-e0e7a3d82a3b
Delete the C:\Autodesk folder. You can't re-use the installer from Install Now.
http://upandready.typepad.com/up_and_ready/2014/06/tip-cautodesk-folder-and-install-now.html
Thanks for the answer, but your help does not explain the problem. I am Polish and Polish versions of need, even though it installed the "upandready.typepad.com" the English version and I have the same problem (same error). I do not really understand what's going on with the second link. I have no problem with the connection, and the folder "Autodesk" removed the award. I tried all kinds of download / install (install now, download now, browser download) and in any case the situation is the same. The error relates to a file on disk in hidden folders (which probably does not). I searched the internet and can not find an answer. I have no idea what to do. Sooner worked on Windows 7 and there were no problems. Please help, I need AutoCAD to college.
