I've tried multiple times, but everytime I download autocad 2015 to install on my laptop the installation completes but all of the programs have failed to download. I have the same issue for 2014 and 2012 versions of autocad. I have seen that re-installing microsoft visual c++ 2012 may solve the problem but unfortunately for me this hasn't worked.
Post your installation log file. If you are having a download issue, try the virtual agent by following the directions here:
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-...
this is the log report that corresponds to the failed download:
2014/10/12:22:54:08 Dionne DIONNE-PC === Setup started on DIONNE-PC by Dionne ===
2014/10/12:22:54:08 Dionne DIONNE-PC Path_Length: 157
2014/10/12:22:54:08 Dionne DIONNE-PC Current Directory C:\Autodesk\AutoCAD_2015_English_Win_32_64bit_R1_wi_en-us
2014/10/12:22:54:08 Dionne DIONNE-PC Launch
2014/10/12:22:54:08 Dionne DIONNE-PC CommandLine /url "http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/AutoCAD_2015_English_Win_32_64bit_R1_wi_en-us_Set... /SN 900-50860799 /PK 001G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/10/12:22:54:08 Dionne DIONNE-PC Current Directory C:\Users\Dionne\AppData\Local\Temp\_AI19CA.tmp
2014/10/12:22:58:47 Dionne DIONNE-PC === Setup ended ===
2014/10/12:22:54:20 Dionne DIONNE-PC === Setup started on DIONNE-PC by Dionne ===
2014/10/12:22:54:20 Dionne DIONNE-PC Path_Length: 157
2014/10/12:22:54:20 Dionne DIONNE-PC Current Directory C:\Users\Dionne\AppData\Local\Temp\_AI19CA.tmp
2014/10/12:22:54:20 Dionne DIONNE-PC Launch
2014/10/12:22:54:23 Dionne DIONNE-PC Download Play SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{E1E3C783-665C-40FD-A988-D99EE720CBE1}/SETUP_x64....
2014/10/12:22:58:46 Dionne DIONNE-PC Download Complete SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{E1E3C783-665C-40FD-A988-D99EE720CBE1}/SETUP_x64....
2014/10/12:22:58:46 Dionne DIONNE-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Dionne\AppData\Local\Temp\_AI19CA.tmp\Setup\AcSetup.dll
2014/10/12:22:58:46 Dionne DIONNE-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/10/12:22:58:47 Dionne DIONNE-PC PageOpen LaunchDialog
2014/10/12:23:01:40 Dionne DIONNE-PC PageOpen LicenseDialog
2014/10/12:23:01:40 Dionne DIONNE-PC PageOpen ProductInfoDialog
2014/10/12:23:01:40 Dionne DIONNE-PC PageOpen ProductSelectionDialog2
2014/10/12:23:01:52 Dionne DIONNE-PC PageOpen FullProgressDialog
2014/10/12:23:01:53 Dionne DIONNE-PC Download Play VCREDIST2012X86UPD4 http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{E1E3C783-665C-40FD-A988-D99EE720CBE1}/VCREDIST20...
2014/10/12:23:02:10 Dionne DIONNE-PC Download Complete VCREDIST2012X86UPD4 http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{E1E3C783-665C-40FD-A988-D99EE720CBE1}/VCREDIST20...
2014/10/12:23:02:10 Dionne DIONNE-PC Installing Microsoft Visual C++ 2012 Redistributable (x86) Update 4: "C:\Autodesk\WI\Autodesk AutoCAD 2015\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\Dionne\AppData\Local\Temp\vcredist_x86_2012_UPD4.log
2014/10/12:23:03:15 Dionne DIONNE-PC Install Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Succeeded
2014/10/12:23:03:15 Dionne DIONNE-PC Download Play VCREDIST2012X64UPD4 http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{E1E3C783-665C-40FD-A988-D99EE720CBE1}/VCREDIST20...
2014/10/12:23:03:32 Dionne DIONNE-PC Download Complete VCREDIST2012X64UPD4 http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{E1E3C783-665C-40FD-A988-D99EE720CBE1}/VCREDIST20...
2014/10/12:23:03:32 Dionne DIONNE-PC Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "C:\Autodesk\WI\Autodesk AutoCAD 2015\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\Dionne\AppData\Local\Temp\vcredist_x64_2012_UPD4.log
2014/10/12:23:03:39 Dionne DIONNE-PC Install Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Succeeded
2014/10/12:23:03:39 Dionne DIONNE-PC Download Play DIRECTX http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{E1E3C783-665C-40FD-A988-D99EE720CBE1}/DIRECTX.ta...
2014/10/12:23:04:23 Dionne DIONNE-PC Download Complete DIRECTX http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{E1E3C783-665C-40FD-A988-D99EE720CBE1}/DIRECTX.ta...
2014/10/12:23:04:23 Dionne DIONNE-PC Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2015\3rdParty\DirectX\DXSETUP.exe" /silent
2014/10/12:23:05:05 Dionne DIONNE-PC Install DirectX Runtime Succeeded
2014/10/12:23:05:05 Dionne DIONNE-PC Download Play CM http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{E1E3C783-665C-40FD-A988-D99EE720CBE1}/CM.tar.lzm...
2014/10/12:23:07:36 Dionne DIONNE-PC Download Complete CM http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{E1E3C783-665C-40FD-A988-D99EE720CBE1}/CM.tar.lzm...
2014/10/12:23:07:36 Dionne DIONNE-PC Installing Autodesk Material Library 2015: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/10/12:23:08:42 Dionne DIONNE-PC Install Autodesk Material Library 2015 Succeeded
2014/10/12:23:08:42 Dionne DIONNE-PC Download Play CMILB http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{E1E3C783-665C-40FD-A988-D99EE720CBE1}/CMILB.tar....
2014/10/12:23:12:26 Dionne DIONNE-PC Download Complete CMILB http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{E1E3C783-665C-40FD-A988-D99EE720CBE1}/CMILB.tar....
2014/10/12:23:12:26 Dionne DIONNE-PC Installing Autodesk Material Library 2015 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/10/12:23:12:58 Dionne DIONNE-PC Install Autodesk Material Library 2015 - Base Image Library Succeeded
2014/10/12:23:12:58 Dionne DIONNE-PC Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\WI\Autodesk AutoCAD 2015\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=".NET Framework Runtime 4.5,Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x86),;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/10/12:23:13:16 Dionne DIONNE-PC Install Autodesk Content Service Succeeded
2014/10/12:23:13:16 Dionne DIONNE-PC Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/10/12:23:13:24 Dionne DIONNE-PC Install Autodesk Content Service Language Pack Succeeded
2014/10/12:23:13:26 Dionne DIONNE-PC Download Play ACAD http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{E1E3C783-665C-40FD-A988-D99EE720CBE1}/ACAD_x64.t...
2014/10/12:23:36:21 Dionne DIONNE-PC Download Complete ACAD http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{E1E3C783-665C-40FD-A988-D99EE720CBE1}/ACAD_x64.t...
2014/10/12:23:36:26 Dionne DIONNE-PC Installing Autodesk® AutoCAD® 2015: TRANSFORMS="C:\Autodesk\WI\Autodesk AutoCAD 2015\x64\en-us\acad\acad.mst;C:\Users\Dionne\AppData\Local\Temp\_AI19CA.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2015" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/10/12:23:44:31 Dionne DIONNE-PC Install Autodesk® AutoCAD® 2015 Succeeded
2014/10/12:23:44:32 Dionne DIONNE-PC Download Play ACAD_en-us http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{E1E3C783-665C-40FD-A988-D99EE720CBE1}/ACAD_x64_e...
2014/10/12:23:49:56 Dionne DIONNE-PC Download Aborted ACAD_en-us http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{E1E3C783-665C-40FD-A988-D99EE720CBE1}/ACAD_x64_e...
2014/10/12:23:49:56 Dionne DIONNE-PC Install AutoCAD® 2015 Language Pack Failed Download Failed, Installation aborted, Result=1603
2014/10/12:23:51:57 Dionne DIONNE-PC Rollback Autodesk® AutoCAD® 2015 Succeeded
2014/10/12:23:52:09 Dionne DIONNE-PC Rollback Autodesk Content Service Language Pack Succeeded
2014/10/12:23:52:20 Dionne DIONNE-PC Rollback Autodesk Content Service Succeeded
2014/10/12:23:52:54 Dionne DIONNE-PC Rollback Autodesk Material Library 2015 - Base Image Library Succeeded
2014/10/12:23:53:45 Dionne DIONNE-PC Rollback Autodesk Material Library 2015 Succeeded
2014/10/12:23:53:45 Dionne DIONNE-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2014/10/12:23:53:46 Dionne DIONNE-PC Rollback Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Failed Failure is ignored, Result=1619
2014/10/12:23:53:46 Dionne DIONNE-PC Rollback Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Failed Failure is ignored, Result=1619
2014/10/12:23:53:50 Dionne DIONNE-PC PageOpen InstallCompleteDialog
2014/10/13:00:00:10 Dionne DIONNE-PC === Setup ended ===
2014/10/13:00:42:22 Dionne DIONNE-PC === Setup started on DIONNE-PC by Dionne ===
2014/10/13:00:42:22 Dionne DIONNE-PC Path_Length: 157
2014/10/13:00:42:22 Dionne DIONNE-PC Current Directory C:\Autodesk\AutoCAD_2015_English_Win_32_64bit_Trial_wi_en-us
2014/10/13:00:42:22 Dionne DIONNE-PC Launch
2014/10/13:00:42:22 Dionne DIONNE-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/ACD/WI/AutoCAD_2015_English_Win_32_64bit_Trial_wi_en-us_Se... /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/10/13:00:42:22 Dionne DIONNE-PC Current Directory C:\Users\Dionne\AppData\Local\Temp\_AI32DE.tmp
2014/10/13:00:44:07 Dionne DIONNE-PC === Setup ended ===
2014/10/13:00:42:26 Dionne DIONNE-PC === Setup started on DIONNE-PC by Dionne ===
2014/10/13:00:42:26 Dionne DIONNE-PC Path_Length: 157
2014/10/13:00:42:26 Dionne DIONNE-PC Current Directory C:\Users\Dionne\AppData\Local\Temp\_AI32DE.tmp
2014/10/13:00:42:26 Dionne DIONNE-PC Launch
2014/10/13:00:42:27 Dionne DIONNE-PC Download Play SETUPMARKER http://trial2.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/SETUPMARKER_...
2014/10/13:00:42:28 Dionne DIONNE-PC Download Complete SETUPMARKER http://trial2.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/SETUPMARKER_...
2014/10/13:00:42:28 Dionne DIONNE-PC Download Play SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/SETUP_x64.ta...
2014/10/13:00:44:07 Dionne DIONNE-PC Download Complete SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/SETUP_x64.ta...
2014/10/13:00:44:07 Dionne DIONNE-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Dionne\AppData\Local\Temp\_AI32DE.tmp\Setup\AcSetup.dll
2014/10/13:00:44:07 Dionne DIONNE-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/10/13:00:44:07 Dionne DIONNE-PC PageOpen LaunchDialog
2014/10/13:00:45:21 Dionne DIONNE-PC PageOpen LicenseDialog
2014/10/13:00:45:21 Dionne DIONNE-PC PageOpen ProductInfoDialog
2014/10/13:00:46:16 Dionne DIONNE-PC PageOpen ProductSelectionDialog2
2014/10/13:00:46:20 Dionne DIONNE-PC PageOpen FullProgressDialog
2014/10/13:00:46:20 Dionne DIONNE-PC Download Play STARTMARKER http://trial2.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/STARTMARKER_...
2014/10/13:00:46:21 Dionne DIONNE-PC Download Complete STARTMARKER http://trial2.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/STARTMARKER_...
2014/10/13:00:46:21 Dionne DIONNE-PC Download Play VCREDIST2012X86UPD4 http://trial2.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/VCREDIST2012...
2014/10/13:00:46:28 Dionne DIONNE-PC Download Complete VCREDIST2012X86UPD4 http://trial2.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/VCREDIST2012...
2014/10/13:00:46:28 Dionne DIONNE-PC Installing Microsoft Visual C++ 2012 Redistributable (x86) Update 4: "C:\Autodesk\WI\Autodesk AutoCAD 2015\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\Dionne\AppData\Local\Temp\vcredist_x86_2012_UPD4.log
2014/10/13:00:46:38 Dionne DIONNE-PC Install Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Succeeded
2014/10/13:00:46:38 Dionne DIONNE-PC Download Play VCREDIST2012X64UPD4 http://trial2.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/VCREDIST2012...
2014/10/13:00:46:46 Dionne DIONNE-PC Download Complete VCREDIST2012X64UPD4 http://trial2.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/VCREDIST2012...
2014/10/13:00:46:46 Dionne DIONNE-PC Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "C:\Autodesk\WI\Autodesk AutoCAD 2015\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\Dionne\AppData\Local\Temp\vcredist_x64_2012_UPD4.log
2014/10/13:00:46:49 Dionne DIONNE-PC Install Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Succeeded
2014/10/13:00:46:49 Dionne DIONNE-PC Download Play DIRECTX http://trial2.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/DIRECTX.tar....
2014/10/13:00:47:02 Dionne DIONNE-PC Download Complete DIRECTX http://trial2.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/DIRECTX.tar....
2014/10/13:00:47:02 Dionne DIONNE-PC Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2015\3rdParty\DirectX\DXSETUP.exe" /silent
2014/10/13:00:47:32 Dionne DIONNE-PC Install DirectX Runtime Succeeded
2014/10/13:00:47:32 Dionne DIONNE-PC Download Play CM http://trial2.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/CM.tar.lzma2
2014/10/13:00:48:23 Dionne DIONNE-PC Download Complete CM http://trial2.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/CM.tar.lzma2
2014/10/13:00:48:23 Dionne DIONNE-PC Installing Autodesk Material Library 2015: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/10/13:00:49:12 Dionne DIONNE-PC Install Autodesk Material Library 2015 Succeeded
2014/10/13:00:49:12 Dionne DIONNE-PC Download Play CMILB http://trial2.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/CMILB.tar.lz...
2014/10/13:00:50:15 Dionne DIONNE-PC Download Complete CMILB http://trial2.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/CMILB.tar.lz...
2014/10/13:00:50:15 Dionne DIONNE-PC Installing Autodesk Material Library 2015 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/10/13:00:50:57 Dionne DIONNE-PC Install Autodesk Material Library 2015 - Base Image Library Succeeded
2014/10/13:00:50:57 Dionne DIONNE-PC Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\WI\Autodesk AutoCAD 2015\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=".NET Framework Runtime 4.5,Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x86),;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/10/13:00:51:18 Dionne DIONNE-PC Install Autodesk Content Service Succeeded
2014/10/13:00:51:18 Dionne DIONNE-PC Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/10/13:00:51:26 Dionne DIONNE-PC Install Autodesk Content Service Language Pack Succeeded
2014/10/13:00:51:27 Dionne DIONNE-PC Download Play ACAD http://trial2.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/ACAD_x64.tar...
2014/10/13:01:01:08 Dionne DIONNE-PC Download Complete ACAD http://trial2.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/ACAD_x64.tar...
2014/10/13:01:01:09 Dionne DIONNE-PC Installing Autodesk® AutoCAD® 2015: TRANSFORMS="C:\Autodesk\WI\Autodesk AutoCAD 2015\x64\en-us\acad\acad.mst;C:\Users\Dionne\AppData\Local\Temp\_AI32DE.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2015" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/10/13:01:08:35 Dionne DIONNE-PC Install Autodesk® AutoCAD® 2015 Succeeded
2014/10/13:01:08:35 Dionne DIONNE-PC Download Play ACAD_en-us http://trial2.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/ACAD_x64_en-...
2014/10/13:01:11:42 Dionne DIONNE-PC Download Aborted ACAD_en-us http://trial2.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/ACAD_x64_en-...
2014/10/13:01:11:42 Dionne DIONNE-PC Install AutoCAD® 2015 Language Pack Failed Download Failed, Installation aborted, Result=1603
2014/10/13:01:13:46 Dionne DIONNE-PC Rollback Autodesk® AutoCAD® 2015 Succeeded
2014/10/13:01:14:29 Dionne DIONNE-PC Rollback Autodesk Content Service Language Pack Succeeded
2014/10/13:01:17:35 Dionne DIONNE-PC Rollback Autodesk Content Service Succeeded
2014/10/13:01:18:22 Dionne DIONNE-PC Rollback Autodesk Material Library 2015 - Base Image Library Succeeded
2014/10/13:01:19:32 Dionne DIONNE-PC Rollback Autodesk Material Library 2015 Succeeded
2014/10/13:01:19:32 Dionne DIONNE-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2014/10/13:01:19:32 Dionne DIONNE-PC Rollback Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Failed Failure is ignored, Result=1619
2014/10/13:01:19:32 Dionne DIONNE-PC Rollback Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Failed Failure is ignored, Result=1619
2014/10/13:01:19:39 Dionne DIONNE-PC PageOpen InstallCompleteDialog
2014/10/13:01:20:14 Dionne DIONNE-PC === Setup ended ===
2014/10/13:01:21:34 Dionne DIONNE-PC === Setup started on DIONNE-PC by Dionne ===
2014/10/13:01:21:34 Dionne DIONNE-PC Path_Length: 157
2014/10/13:01:21:34 Dionne DIONNE-PC Current Directory C:\Autodesk\AutoCAD_2015_English_Win_32_64bit_Trial_wi_en-us
2014/10/13:01:21:34 Dionne DIONNE-PC Launch
2014/10/13:01:21:34 Dionne DIONNE-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/ACD/WI/AutoCAD_2015_English_Win_32_64bit_Trial_wi_en-us_Se... /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/10/13:01:21:34 Dionne DIONNE-PC Current Directory C:\Users\Dionne\AppData\Local\Temp\_AI16DB.tmp
2014/10/13:01:21:43 Dionne DIONNE-PC === Setup ended ===
2014/10/13:01:21:40 Dionne DIONNE-PC === Setup started on DIONNE-PC by Dionne ===
2014/10/13:01:21:40 Dionne DIONNE-PC Path_Length: 157
2014/10/13:01:21:40 Dionne DIONNE-PC Current Directory C:\Users\Dionne\AppData\Local\Temp\_AI16DB.tmp
2014/10/13:01:21:40 Dionne DIONNE-PC Launch
2014/10/13:01:21:41 Dionne DIONNE-PC Download Skipped SETUPMARKER http://trial2.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/SETUPMARKER_...
2014/10/13:01:21:41 Dionne DIONNE-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/SETUP_x64.ta...
2014/10/13:01:21:42 Dionne DIONNE-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Dionne\AppData\Local\Temp\_AI16DB.tmp\Setup\AcSetup.dll
2014/10/13:01:21:42 Dionne DIONNE-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/10/13:01:21:42 Dionne DIONNE-PC PageOpen LaunchDialog
2014/10/13:01:23:09 Dionne DIONNE-PC PageOpen LicenseDialog
2014/10/13:01:23:10 Dionne DIONNE-PC PageOpen ProductInfoDialog
2014/10/13:01:24:29 Dionne DIONNE-PC PageOpen ProductSelectionDialog2
2014/10/13:01:24:32 Dionne DIONNE-PC PageOpen FullProgressDialog
2014/10/13:01:24:32 Dionne DIONNE-PC Download Play STARTMARKER http://trial2.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/STARTMARKER_...
2014/10/13:01:24:33 Dionne DIONNE-PC Download Complete STARTMARKER http://trial2.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/STARTMARKER_...
2014/10/13:01:24:33 Dionne DIONNE-PC Download Skipped VCREDIST2012X86UPD4 http://trial2.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/VCREDIST2012...
2014/10/13:01:24:33 Dionne DIONNE-PC Installing Microsoft Visual C++ 2012 Redistributable (x86) Update 4: "C:\Autodesk\WI\Autodesk AutoCAD 2015\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\Dionne\AppData\Local\Temp\vcredist_x86_2012_UPD4.log
2014/10/13:01:24:37 Dionne DIONNE-PC Install Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Succeeded
2014/10/13:01:24:37 Dionne DIONNE-PC Download Skipped VCREDIST2012X64UPD4 http://trial2.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/VCREDIST2012...
2014/10/13:01:24:37 Dionne DIONNE-PC Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "C:\Autodesk\WI\Autodesk AutoCAD 2015\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\Dionne\AppData\Local\Temp\vcredist_x64_2012_UPD4.log
2014/10/13:01:24:39 Dionne DIONNE-PC Install Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Succeeded
2014/10/13:01:24:39 Dionne DIONNE-PC Download Skipped DIRECTX http://trial2.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/DIRECTX.tar....
2014/10/13:01:24:39 Dionne DIONNE-PC Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2015\3rdParty\DirectX\DXSETUP.exe" /silent
2014/10/13:01:25:10 Dionne DIONNE-PC Install DirectX Runtime Succeeded
2014/10/13:01:25:10 Dionne DIONNE-PC Download Skipped CM http://trial2.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/CM.tar.lzma2
2014/10/13:01:25:10 Dionne DIONNE-PC Installing Autodesk Material Library 2015: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/10/13:01:25:47 Dionne DIONNE-PC Install Autodesk Material Library 2015 Succeeded
2014/10/13:01:25:47 Dionne DIONNE-PC Download Skipped CMILB http://trial2.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/CMILB.tar.lz...
2014/10/13:01:25:47 Dionne DIONNE-PC Installing Autodesk Material Library 2015 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/10/13:01:26:16 Dionne DIONNE-PC Install Autodesk Material Library 2015 - Base Image Library Succeeded
2014/10/13:01:26:19 Dionne DIONNE-PC Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\WI\Autodesk AutoCAD 2015\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=".NET Framework Runtime 4.5,Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x86),;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/10/13:01:26:36 Dionne DIONNE-PC Install Autodesk Content Service Succeeded
2014/10/13:01:26:36 Dionne DIONNE-PC Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/10/13:01:26:43 Dionne DIONNE-PC Install Autodesk Content Service Language Pack Succeeded
2014/10/13:01:26:43 Dionne DIONNE-PC Download Skipped ACAD http://trial2.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/ACAD_x64.tar...
2014/10/13:01:26:44 Dionne DIONNE-PC Installing Autodesk® AutoCAD® 2015: TRANSFORMS="C:\Autodesk\WI\Autodesk AutoCAD 2015\x64\en-us\acad\acad.mst;C:\Users\Dionne\AppData\Local\Temp\_AI16DB.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2015" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/10/13:01:33:05 Dionne DIONNE-PC Download Play CANCELMARKER http://trial2.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/CANCELMARKER...
2014/10/13:01:33:05 Dionne DIONNE-PC Download Complete CANCELMARKER http://trial2.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/CANCELMARKER...
2014/10/13:01:33:05 Dionne DIONNE-PC Install Autodesk® AutoCAD® 2015 Failed Installation aborted, Result=1602
2014/10/13:01:33:11 Dionne DIONNE-PC Rollback Autodesk Content Service Language Pack Succeeded
2014/10/13:01:33:23 Dionne DIONNE-PC Rollback Autodesk Content Service Succeeded
2014/10/13:01:33:54 Dionne DIONNE-PC Rollback Autodesk Material Library 2015 - Base Image Library Succeeded
2014/10/13:01:34:43 Dionne DIONNE-PC Rollback Autodesk Material Library 2015 Succeeded
2014/10/13:01:34:43 Dionne DIONNE-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2014/10/13:01:34:43 Dionne DIONNE-PC Rollback Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Failed Failure is ignored, Result=1619
2014/10/13:01:34:44 Dionne DIONNE-PC Rollback Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Failed Failure is ignored, Result=1619
2014/10/13:01:34:48 Dionne DIONNE-PC PageOpen InstallCompleteDialog
2014/10/13:01:34:57 Dionne DIONNE-PC === Setup ended ===
2014/10/13:20:36:19 Dionne DIONNE-PC === Setup started on DIONNE-PC by Dionne ===
2014/10/13:20:36:19 Dionne DIONNE-PC Path_Length: 157
2014/10/13:20:36:19 Dionne DIONNE-PC Current Directory C:\Autodesk\AutoCAD_2015_English_Win_32_64bit_R1_wi_en-us
2014/10/13:20:36:19 Dionne DIONNE-PC Launch
2014/10/13:20:36:19 Dionne DIONNE-PC CommandLine /url "http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/AutoCAD_2015_English_Win_32_64bit_R1_wi_en-us_Set... /SN 900-50860799 /PK 001G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/10/13:20:36:19 Dionne DIONNE-PC Current Directory C:\Users\Dionne\AppData\Local\Temp\_AI4B44.tmp
2014/10/13:20:36:27 Dionne DIONNE-PC === Setup ended ===
2014/10/13:20:36:23 Dionne DIONNE-PC === Setup started on DIONNE-PC by Dionne ===
2014/10/13:20:36:23 Dionne DIONNE-PC Path_Length: 157
2014/10/13:20:36:23 Dionne DIONNE-PC Current Directory C:\Users\Dionne\AppData\Local\Temp\_AI4B44.tmp
2014/10/13:20:36:23 Dionne DIONNE-PC Launch
2014/10/13:20:36:23 Dionne DIONNE-PC Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{E1E3C783-665C-40FD-A988-D99EE720CBE1}/SETUP_x64....
2014/10/13:20:36:25 Dionne DIONNE-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Dionne\AppData\Local\Temp\_AI4B44.tmp\Setup\AcSetup.dll
2014/10/13:20:36:25 Dionne DIONNE-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/10/13:20:36:25 Dionne DIONNE-PC PageOpen LaunchDialog
2014/10/13:20:36:54 Dionne DIONNE-PC PageOpen LicenseDialog
2014/10/13:20:36:54 Dionne DIONNE-PC PageOpen ProductInfoDialog
2014/10/13:20:36:54 Dionne DIONNE-PC PageOpen ProductSelectionDialog2
2014/10/13:20:39:19 Dionne DIONNE-PC PageOpen FullProgressDialog
2014/10/13:20:39:19 Dionne DIONNE-PC Download Skipped VCREDIST2012X86UPD4 http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{E1E3C783-665C-40FD-A988-D99EE720CBE1}/VCREDIST20...
2014/10/13:20:39:19 Dionne DIONNE-PC Installing Microsoft Visual C++ 2012 Redistributable (x86) Update 4: "C:\Autodesk\WI\Autodesk AutoCAD 2015\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\Dionne\AppData\Local\Temp\vcredist_x86_2012_UPD4.log
2014/10/13:20:39:23 Dionne DIONNE-PC Install Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Succeeded
2014/10/13:20:39:23 Dionne DIONNE-PC Download Skipped VCREDIST2012X64UPD4 http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{E1E3C783-665C-40FD-A988-D99EE720CBE1}/VCREDIST20...
2014/10/13:20:39:23 Dionne DIONNE-PC Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "C:\Autodesk\WI\Autodesk AutoCAD 2015\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\Dionne\AppData\Local\Temp\vcredist_x64_2012_UPD4.log
2014/10/13:20:39:25 Dionne DIONNE-PC Install Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Succeeded
2014/10/13:20:39:25 Dionne DIONNE-PC Download Skipped DIRECTX http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{E1E3C783-665C-40FD-A988-D99EE720CBE1}/DIRECTX.ta...
2014/10/13:20:39:25 Dionne DIONNE-PC Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2015\3rdParty\DirectX\DXSETUP.exe" /silent
2014/10/13:20:39:47 Dionne DIONNE-PC Install DirectX Runtime Succeeded
2014/10/13:20:39:47 Dionne DIONNE-PC Download Skipped CM http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{E1E3C783-665C-40FD-A988-D99EE720CBE1}/CM.tar.lzm...
2014/10/13:20:39:47 Dionne DIONNE-PC Installing Autodesk Material Library 2015: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/10/13:20:40:18 Dionne DIONNE-PC Install Autodesk Material Library 2015 Succeeded
2014/10/13:20:40:18 Dionne DIONNE-PC Download Skipped CMILB http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{E1E3C783-665C-40FD-A988-D99EE720CBE1}/CMILB.tar....
2014/10/13:20:40:18 Dionne DIONNE-PC Installing Autodesk Material Library 2015 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/10/13:20:40:41 Dionne DIONNE-PC Install Autodesk Material Library 2015 - Base Image Library Succeeded
2014/10/13:20:40:42 Dionne DIONNE-PC Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\WI\Autodesk AutoCAD 2015\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=".NET Framework Runtime 4.5,Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x86),;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/10/13:20:40:57 Dionne DIONNE-PC Install Autodesk Content Service Succeeded
2014/10/13:20:40:58 Dionne DIONNE-PC Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/10/13:20:41:05 Dionne DIONNE-PC Install Autodesk Content Service Language Pack Succeeded
2014/10/13:20:41:05 Dionne DIONNE-PC Download Skipped ACAD http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{E1E3C783-665C-40FD-A988-D99EE720CBE1}/ACAD_x64.t...
2014/10/13:20:41:07 Dionne DIONNE-PC Installing Autodesk® AutoCAD® 2015: TRANSFORMS="C:\Autodesk\WI\Autodesk AutoCAD 2015\x64\en-us\acad\acad.mst;C:\Users\Dionne\AppData\Local\Temp\_AI4B44.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2015" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/10/13:20:47:34 Dionne DIONNE-PC Install Autodesk® AutoCAD® 2015 Succeeded
2014/10/13:20:47:35 Dionne DIONNE-PC Download Play ACAD_en-us http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{E1E3C783-665C-40FD-A988-D99EE720CBE1}/ACAD_x64_e...
2014/10/13:20:50:01 Dionne DIONNE-PC Download Aborted ACAD_en-us http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{E1E3C783-665C-40FD-A988-D99EE720CBE1}/ACAD_x64_e...
2014/10/13:20:50:01 Dionne DIONNE-PC Install AutoCAD® 2015 Language Pack Failed Download Failed, Installation aborted, Result=1603
2014/10/13:20:51:33 Dionne DIONNE-PC Rollback Autodesk® AutoCAD® 2015 Succeeded
2014/10/13:20:51:42 Dionne DIONNE-PC Rollback Autodesk Content Service Language Pack Succeeded
2014/10/13:20:51:50 Dionne DIONNE-PC Rollback Autodesk Content Service Succeeded
2014/10/13:20:52:15 Dionne DIONNE-PC Rollback Autodesk Material Library 2015 - Base Image Library Succeeded
2014/10/13:20:52:58 Dionne DIONNE-PC Rollback Autodesk Material Library 2015 Succeeded
2014/10/13:20:52:58 Dionne DIONNE-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2014/10/13:20:52:58 Dionne DIONNE-PC Rollback Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Failed Failure is ignored, Result=1619
2014/10/13:20:52:58 Dionne DIONNE-PC Rollback Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Failed Failure is ignored, Result=1619
2014/10/13:20:53:01 Dionne DIONNE-PC PageOpen InstallCompleteDialog
2014/10/13:21:21:20 Dionne DIONNE-PC === Setup ended ===
2014/10/13:21:21:09 Dionne DIONNE-PC === Setup started on DIONNE-PC by Dionne ===
2014/10/13:21:21:09 Dionne DIONNE-PC Path_Length: 157
2014/10/13:21:21:09 Dionne DIONNE-PC Current Directory C:\Autodesk\AutoCAD_2015_English_Win_32_64bit_R1_wi_en-us
2014/10/13:21:21:09 Dionne DIONNE-PC Launch
2014/10/13:21:21:09 Dionne DIONNE-PC CommandLine /url "http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/AutoCAD_2015_English_Win_32_64bit_R1_wi_en-us_Set... /SN 900-50860799 /PK 001G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/10/13:21:21:09 Dionne DIONNE-PC Another Autodesk install/update is now occurring on this computer. Please wait for that to complete and then click Retry.2014/10/13:21:21:19 Dionne DIONNE-PC Path_Length: 157
2014/10/13:21:21:19 Dionne DIONNE-PC Current Directory C:\Users\Dionne\AppData\Local\Temp\_AI57C0.tmp
2014/10/13:21:21:29 Dionne DIONNE-PC === Setup ended ===
2014/10/13:21:21:24 Dionne DIONNE-PC === Setup started on DIONNE-PC by Dionne ===
2014/10/13:21:21:24 Dionne DIONNE-PC Path_Length: 157
2014/10/13:21:21:24 Dionne DIONNE-PC Current Directory C:\Users\Dionne\AppData\Local\Temp\_AI57C0.tmp
2014/10/13:21:21:24 Dionne DIONNE-PC Launch
2014/10/13:21:21:26 Dionne DIONNE-PC Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{E1E3C783-665C-40FD-A988-D99EE720CBE1}/SETUP_x64....
2014/10/13:21:21:27 Dionne DIONNE-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Dionne\AppData\Local\Temp\_AI57C0.tmp\Setup\AcSetup.dll
2014/10/13:21:21:27 Dionne DIONNE-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/10/13:21:21:28 Dionne DIONNE-PC PageOpen LaunchDialog
2014/10/13:21:21:35 Dionne DIONNE-PC PageOpen LicenseDialog
2014/10/13:21:21:35 Dionne DIONNE-PC PageOpen ProductInfoDialog
2014/10/13:21:21:35 Dionne DIONNE-PC PageOpen ProductSelectionDialog2
2014/10/13:21:21:40 Dionne DIONNE-PC PageOpen FullProgressDialog
2014/10/13:21:21:40 Dionne DIONNE-PC Download Skipped VCREDIST2012X86UPD4 http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{E1E3C783-665C-40FD-A988-D99EE720CBE1}/VCREDIST20...
2014/10/13:21:21:40 Dionne DIONNE-PC Installing Microsoft Visual C++ 2012 Redistributable (x86) Update 4: "C:\Autodesk\WI\Autodesk AutoCAD 2015\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\Dionne\AppData\Local\Temp\vcredist_x86_2012_UPD4.log
2014/10/13:21:21:45 Dionne DIONNE-PC Install Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Succeeded
2014/10/13:21:21:45 Dionne DIONNE-PC Download Skipped VCREDIST2012X64UPD4 http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{E1E3C783-665C-40FD-A988-D99EE720CBE1}/VCREDIST20...
2014/10/13:21:21:45 Dionne DIONNE-PC Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "C:\Autodesk\WI\Autodesk AutoCAD 2015\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\Dionne\AppData\Local\Temp\vcredist_x64_2012_UPD4.log
2014/10/13:21:21:47 Dionne DIONNE-PC Install Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Succeeded
2014/10/13:21:21:47 Dionne DIONNE-PC Download Skipped DIRECTX http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{E1E3C783-665C-40FD-A988-D99EE720CBE1}/DIRECTX.ta...
2014/10/13:21:21:47 Dionne DIONNE-PC Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2015\3rdParty\DirectX\DXSETUP.exe" /silent
2014/10/13:21:22:13 Dionne DIONNE-PC Install DirectX Runtime Succeeded
2014/10/13:21:22:13 Dionne DIONNE-PC Download Skipped CM http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{E1E3C783-665C-40FD-A988-D99EE720CBE1}/CM.tar.lzm...
2014/10/13:21:22:14 Dionne DIONNE-PC Installing Autodesk Material Library 2015: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/10/13:21:22:45 Dionne DIONNE-PC Install Autodesk Material Library 2015 Succeeded
2014/10/13:21:22:45 Dionne DIONNE-PC Download Skipped CMILB http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{E1E3C783-665C-40FD-A988-D99EE720CBE1}/CMILB.tar....
2014/10/13:21:22:46 Dionne DIONNE-PC Installing Autodesk Material Library 2015 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/10/13:21:23:09 Dionne DIONNE-PC Install Autodesk Material Library 2015 - Base Image Library Succeeded
2014/10/13:21:23:12 Dionne DIONNE-PC Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\WI\Autodesk AutoCAD 2015\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=".NET Framework Runtime 4.5,Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x86),;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/10/13:21:23:23 Dionne DIONNE-PC Install Autodesk Content Service Succeeded
2014/10/13:21:23:23 Dionne DIONNE-PC Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/10/13:21:23:30 Dionne DIONNE-PC Install Autodesk Content Service Language Pack Succeeded
2014/10/13:21:23:30 Dionne DIONNE-PC Download Skipped ACAD http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{E1E3C783-665C-40FD-A988-D99EE720CBE1}/ACAD_x64.t...
2014/10/13:21:23:31 Dionne DIONNE-PC Installing Autodesk® AutoCAD® 2015: TRANSFORMS="C:\Autodesk\WI\Autodesk AutoCAD 2015\x64\en-us\acad\acad.mst;C:\Users\Dionne\AppData\Local\Temp\_AI57C0.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2015" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/10/13:21:29:23 Dionne DIONNE-PC Install Autodesk® AutoCAD® 2015 Succeeded
2014/10/13:21:29:24 Dionne DIONNE-PC Download Play ACAD_en-us http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{E1E3C783-665C-40FD-A988-D99EE720CBE1}/ACAD_x64_e...
2014/10/13:21:32:04 Dionne DIONNE-PC Download Aborted ACAD_en-us http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{E1E3C783-665C-40FD-A988-D99EE720CBE1}/ACAD_x64_e...
2014/10/13:21:32:04 Dionne DIONNE-PC Install AutoCAD® 2015 Language Pack Failed Download Failed, Installation aborted, Result=1603
2014/10/13:21:33:57 Dionne DIONNE-PC Rollback Autodesk® AutoCAD® 2015 Succeeded
2014/10/13:21:34:07 Dionne DIONNE-PC Rollback Autodesk Content Service Language Pack Succeeded
2014/10/13:21:34:15 Dionne DIONNE-PC Rollback Autodesk Content Service Succeeded
2014/10/13:21:34:42 Dionne DIONNE-PC Rollback Autodesk Material Library 2015 - Base Image Library Succeeded
2014/10/13:21:35:32 Dionne DIONNE-PC Rollback Autodesk Material Library 2015 Succeeded
2014/10/13:21:35:32 Dionne DIONNE-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2014/10/13:21:35:32 Dionne DIONNE-PC Rollback Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Failed Failure is ignored, Result=1619
2014/10/13:21:35:33 Dionne DIONNE-PC Rollback Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Failed Failure is ignored, Result=1619
2014/10/13:21:35:36 Dionne DIONNE-PC PageOpen InstallCompleteDialog
2014/10/13:21:36:48 Dionne DIONNE-PC === Setup ended ===
2014/10/14:13:32:25 Dionne DIONNE-PC === Setup started on DIONNE-PC by Dionne ===
2014/10/14:13:32:25 Dionne DIONNE-PC Path_Length: 157
2014/10/14:13:32:25 Dionne DIONNE-PC Current Directory C:\Autodesk\AutoCAD_2015_English_Win_32_64bit_R1_wi_en-us
2014/10/14:13:32:25 Dionne DIONNE-PC Launch
2014/10/14:13:32:25 Dionne DIONNE-PC CommandLine /url "http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/AutoCAD_2015_English_Win_32_64bit_R1_wi_en-us_Set... /SN 900-50860799 /PK 001G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/10/14:13:32:25 Dionne DIONNE-PC Current Directory C:\Users\Dionne\AppData\Local\Temp\_AI90AE.tmp
2014/10/14:13:32:34 Dionne DIONNE-PC === Setup ended ===
2014/10/14:13:32:29 Dionne DIONNE-PC === Setup started on DIONNE-PC by Dionne ===
2014/10/14:13:32:29 Dionne DIONNE-PC Path_Length: 157
2014/10/14:13:32:29 Dionne DIONNE-PC Current Directory C:\Users\Dionne\AppData\Local\Temp\_AI90AE.tmp
2014/10/14:13:32:29 Dionne DIONNE-PC Launch
2014/10/14:13:32:30 Dionne DIONNE-PC Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{E1E3C783-665C-40FD-A988-D99EE720CBE1}/SETUP_x64....
2014/10/14:13:32:31 Dionne DIONNE-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Dionne\AppData\Local\Temp\_AI90AE.tmp\Setup\AcSetup.dll
2014/10/14:13:32:31 Dionne DIONNE-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/10/14:13:32:32 Dionne DIONNE-PC PageOpen LaunchDialog
2014/10/14:13:32:42 Dionne DIONNE-PC PageOpen LicenseDialog
2014/10/14:13:32:42 Dionne DIONNE-PC PageOpen ProductInfoDialog
2014/10/14:13:32:42 Dionne DIONNE-PC PageOpen ProductSelectionDialog2
2014/10/14:13:32:48 Dionne DIONNE-PC PageOpen FullProgressDialog
2014/10/14:13:32:49 Dionne DIONNE-PC Download Skipped VCREDIST2012X86UPD4 http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{E1E3C783-665C-40FD-A988-D99EE720CBE1}/VCREDIST20...
2014/10/14:13:32:49 Dionne DIONNE-PC Installing Microsoft Visual C++ 2012 Redistributable (x86) Update 4: "C:\Autodesk\WI\Autodesk AutoCAD 2015\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\Dionne\AppData\Local\Temp\vcredist_x86_2012_UPD4.log
2014/10/14:13:33:42 Dionne DIONNE-PC Install Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Succeeded
2014/10/14:13:33:42 Dionne DIONNE-PC Download Skipped VCREDIST2012X64UPD4 http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{E1E3C783-665C-40FD-A988-D99EE720CBE1}/VCREDIST20...
2014/10/14:13:33:42 Dionne DIONNE-PC Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "C:\Autodesk\WI\Autodesk AutoCAD 2015\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\Dionne\AppData\Local\Temp\vcredist_x64_2012_UPD4.log
2014/10/14:13:34:23 Dionne DIONNE-PC Install Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Succeeded
2014/10/14:13:34:23 Dionne DIONNE-PC Download Skipped DIRECTX http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{E1E3C783-665C-40FD-A988-D99EE720CBE1}/DIRECTX.ta...
2014/10/14:13:34:23 Dionne DIONNE-PC Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2015\3rdParty\DirectX\DXSETUP.exe" /silent
2014/10/14:13:35:18 Dionne DIONNE-PC Install DirectX Runtime Succeeded
2014/10/14:13:35:18 Dionne DIONNE-PC Download Skipped CM http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{E1E3C783-665C-40FD-A988-D99EE720CBE1}/CM.tar.lzm...
2014/10/14:13:35:18 Dionne DIONNE-PC Installing Autodesk Material Library 2015: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/10/14:13:36:01 Dionne DIONNE-PC Install Autodesk Material Library 2015 Succeeded
2014/10/14:13:36:02 Dionne DIONNE-PC Download Skipped CMILB http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{E1E3C783-665C-40FD-A988-D99EE720CBE1}/CMILB.tar....
2014/10/14:13:36:02 Dionne DIONNE-PC Installing Autodesk Material Library 2015 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/10/14:13:36:34 Dionne DIONNE-PC Install Autodesk Material Library 2015 - Base Image Library Succeeded
2014/10/14:13:36:36 Dionne DIONNE-PC Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\WI\Autodesk AutoCAD 2015\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=".NET Framework Runtime 4.5,Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x86),;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/10/14:13:36:51 Dionne DIONNE-PC Install Autodesk Content Service Succeeded
2014/10/14:13:36:51 Dionne DIONNE-PC Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/10/14:13:36:59 Dionne DIONNE-PC Install Autodesk Content Service Language Pack Succeeded
2014/10/14:13:36:59 Dionne DIONNE-PC Download Skipped ACAD http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{E1E3C783-665C-40FD-A988-D99EE720CBE1}/ACAD_x64.t...
2014/10/14:13:37:00 Dionne DIONNE-PC Installing Autodesk® AutoCAD® 2015: TRANSFORMS="C:\Autodesk\WI\Autodesk AutoCAD 2015\x64\en-us\acad\acad.mst;C:\Users\Dionne\AppData\Local\Temp\_AI90AE.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2015" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/10/14:13:45:52 Dionne DIONNE-PC Install Autodesk® AutoCAD® 2015 Succeeded
2014/10/14:13:45:53 Dionne DIONNE-PC Download Play ACAD_en-us http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{E1E3C783-665C-40FD-A988-D99EE720CBE1}/ACAD_x64_e...
2014/10/14:13:48:56 Dionne DIONNE-PC Download Aborted ACAD_en-us http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{E1E3C783-665C-40FD-A988-D99EE720CBE1}/ACAD_x64_e...
2014/10/14:13:48:56 Dionne DIONNE-PC Install AutoCAD® 2015 Language Pack Failed Download Failed, Installation aborted, Result=1603
2014/10/14:13:50:52 Dionne DIONNE-PC Rollback Autodesk® AutoCAD® 2015 Succeeded
2014/10/14:13:51:01 Dionne DIONNE-PC Rollback Autodesk Content Service Language Pack Succeeded
2014/10/14:13:51:09 Dionne DIONNE-PC Rollback Autodesk Content Service Succeeded
2014/10/14:13:51:39 Dionne DIONNE-PC Rollback Autodesk Material Library 2015 - Base Image Library Succeeded
2014/10/14:13:52:21 Dionne DIONNE-PC Rollback Autodesk Material Library 2015 Succeeded
2014/10/14:13:52:22 Dionne DIONNE-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2014/10/14:13:52:22 Dionne DIONNE-PC Rollback Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Failed Failure is ignored, Result=1619
2014/10/14:13:52:22 Dionne DIONNE-PC Rollback Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Failed Failure is ignored, Result=1619
2014/10/14:13:52:25 Dionne DIONNE-PC PageOpen InstallCompleteDialog
2014/10/14:19:18:37 Dionne DIONNE-PC === Setup ended ===
2014/10/14:19:31:59 Dionne DIONNE-PC === Setup started on DIONNE-PC by Dionne ===
2014/10/14:19:31:59 Dionne DIONNE-PC Path_Length: 157
2014/10/14:19:31:59 Dionne DIONNE-PC Current Directory C:\Autodesk\AutoCAD_2015_English_Win_32_64bit_R1_wi_en-us
2014/10/14:19:31:59 Dionne DIONNE-PC Launch
2014/10/14:19:31:59 Dionne DIONNE-PC CommandLine /url "http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/AutoCAD_2015_English_Win_32_64bit_R1_wi_en-us_Set... /SN 900-50860799 /PK 001G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/10/14:19:31:59 Dionne DIONNE-PC Current Directory C:\Users\Dionne\AppData\Local\Temp\_AIC192.tmp
2014/10/14:19:32:09 Dionne DIONNE-PC === Setup ended ===
2014/10/14:19:32:04 Dionne DIONNE-PC === Setup started on DIONNE-PC by Dionne ===
2014/10/14:19:32:04 Dionne DIONNE-PC Path_Length: 157
2014/10/14:19:32:04 Dionne DIONNE-PC Current Directory C:\Users\Dionne\AppData\Local\Temp\_AIC192.tmp
2014/10/14:19:32:04 Dionne DIONNE-PC Launch
2014/10/14:19:32:05 Dionne DIONNE-PC Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{E1E3C783-665C-40FD-A988-D99EE720CBE1}/SETUP_x64....
2014/10/14:19:32:07 Dionne DIONNE-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Dionne\AppData\Local\Temp\_AIC192.tmp\Setup\AcSetup.dll
2014/10/14:19:32:07 Dionne DIONNE-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/10/14:19:32:07 Dionne DIONNE-PC PageOpen LaunchDialog
2014/10/14:19:32:20 Dionne DIONNE-PC PageOpen LicenseDialog
2014/10/14:19:32:20 Dionne DIONNE-PC PageOpen ProductInfoDialog
2014/10/14:19:32:20 Dionne DIONNE-PC PageOpen ProductSelectionDialog2
2014/10/14:19:32:24 Dionne DIONNE-PC PageOpen FullProgressDialog
2014/10/14:19:32:24 Dionne DIONNE-PC Download Skipped VCREDIST2012X86UPD4 http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{E1E3C783-665C-40FD-A988-D99EE720CBE1}/VCREDIST20...
2014/10/14:19:32:24 Dionne DIONNE-PC Installing Microsoft Visual C++ 2012 Redistributable (x86) Update 4: "C:\Autodesk\WI\Autodesk AutoCAD 2015\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\Dionne\AppData\Local\Temp\vcredist_x86_2012_UPD4.log
2014/10/14:19:32:27 Dionne DIONNE-PC Install Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Succeeded
2014/10/14:19:32:27 Dionne DIONNE-PC Download Skipped VCREDIST2012X64UPD4 http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{E1E3C783-665C-40FD-A988-D99EE720CBE1}/VCREDIST20...
2014/10/14:19:32:27 Dionne DIONNE-PC Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "C:\Autodesk\WI\Autodesk AutoCAD 2015\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\Dionne\AppData\Local\Temp\vcredist_x64_2012_UPD4.log
2014/10/14:19:32:29 Dionne DIONNE-PC Install Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Succeeded
2014/10/14:19:32:30 Dionne DIONNE-PC Download Skipped DIRECTX http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{E1E3C783-665C-40FD-A988-D99EE720CBE1}/DIRECTX.ta...
2014/10/14:19:32:30 Dionne DIONNE-PC Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2015\3rdParty\DirectX\DXSETUP.exe" /silent
2014/10/14:19:33:03 Dionne DIONNE-PC Install DirectX Runtime Succeeded
2014/10/14:19:33:03 Dionne DIONNE-PC Download Skipped CM http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{E1E3C783-665C-40FD-A988-D99EE720CBE1}/CM.tar.lzm...
2014/10/14:19:33:03 Dionne DIONNE-PC Installing Autodesk Material Library 2015: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/10/14:19:33:40 Dionne DIONNE-PC Install Autodesk Material Library 2015 Succeeded
2014/10/14:19:33:40 Dionne DIONNE-PC Download Skipped CMILB http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{E1E3C783-665C-40FD-A988-D99EE720CBE1}/CMILB.tar....
2014/10/14:19:33:41 Dionne DIONNE-PC Installing Autodesk Material Library 2015 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/10/14:19:34:12 Dionne DIONNE-PC Install Autodesk Material Library 2015 - Base Image Library Succeeded
2014/10/14:19:34:14 Dionne DIONNE-PC Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\WI\Autodesk AutoCAD 2015\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=".NET Framework Runtime 4.5,Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x86),;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/10/14:19:34:35 Dionne DIONNE-PC Install Autodesk Content Service Succeeded
2014/10/14:19:34:36 Dionne DIONNE-PC Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/10/14:19:34:43 Dionne DIONNE-PC Install Autodesk Content Service Language Pack Succeeded
2014/10/14:19:34:43 Dionne DIONNE-PC Download Skipped ACAD http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{E1E3C783-665C-40FD-A988-D99EE720CBE1}/ACAD_x64.t...
2014/10/14:19:34:44 Dionne DIONNE-PC Installing Autodesk® AutoCAD® 2015: TRANSFORMS="C:\Autodesk\WI\Autodesk AutoCAD 2015\x64\en-us\acad\acad.mst;C:\Users\Dionne\AppData\Local\Temp\_AIC192.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2015" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/10/14:19:44:36 Dionne DIONNE-PC Install Autodesk® AutoCAD® 2015 Succeeded
2014/10/14:19:44:46 Dionne DIONNE-PC Download Play ACAD_en-us http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{E1E3C783-665C-40FD-A988-D99EE720CBE1}/ACAD_x64_e...
2014/10/14:19:48:08 Dionne DIONNE-PC Download Aborted ACAD_en-us http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{E1E3C783-665C-40FD-A988-D99EE720CBE1}/ACAD_x64_e...
2014/10/14:19:48:08 Dionne DIONNE-PC Install AutoCAD® 2015 Language Pack Failed Download Failed, Installation aborted, Result=1603
2014/10/14:19:50:48 Dionne DIONNE-PC Rollback Autodesk® AutoCAD® 2015 Succeeded
2014/10/14:19:50:58 Dionne DIONNE-PC Rollback Autodesk Content Service Language Pack Succeeded
2014/10/14:19:51:08 Dionne DIONNE-PC Rollback Autodesk Content Service Succeeded
2014/10/14:19:51:40 Dionne DIONNE-PC Rollback Autodesk Material Library 2015 - Base Image Library Succeeded
2014/10/14:19:52:34 Dionne DIONNE-PC Rollback Autodesk Material Library 2015 Succeeded
2014/10/14:19:52:34 Dionne DIONNE-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2014/10/14:19:52:34 Dionne DIONNE-PC Rollback Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Failed Failure is ignored, Result=1619
2014/10/14:19:52:34 Dionne DIONNE-PC Rollback Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Failed Failure is ignored, Result=1619
2014/10/14:19:52:40 Dionne DIONNE-PC PageOpen InstallCompleteDialog
2014/10/14:19:53:37 Dionne DIONNE-PC === Setup ended ===
2014/10/14:20:07:05 Dionne DIONNE-PC === Setup started on DIONNE-PC by Dionne ===
2014/10/14:20:07:05 Dionne DIONNE-PC Path_Length: 157
2014/10/14:20:07:05 Dionne DIONNE-PC Current Directory C:\Autodesk\AutoCAD_2015_English_Win_32_64bit_R1_wi_en-us
2014/10/14:20:07:05 Dionne DIONNE-PC Launch
2014/10/14:20:07:05 Dionne DIONNE-PC CommandLine /url "http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/AutoCAD_2015_English_Win_32_64bit_R1_wi_en-us_Set... /SN 900-50860799 /PK 001G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/10/14:20:07:05 Dionne DIONNE-PC Current Directory C:\Users\Dionne\AppData\Local\Temp\_AIE450.tmp
2014/10/14:20:07:13 Dionne DIONNE-PC === Setup ended ===
2014/10/14:20:07:10 Dionne DIONNE-PC === Setup started on DIONNE-PC by Dionne ===
2014/10/14:20:07:10 Dionne DIONNE-PC Path_Length: 157
2014/10/14:20:07:10 Dionne DIONNE-PC Current Directory C:\Users\Dionne\AppData\Local\Temp\_AIE450.tmp
2014/10/14:20:07:10 Dionne DIONNE-PC Launch
2014/10/14:20:07:12 Dionne DIONNE-PC Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{E1E3C783-665C-40FD-A988-D99EE720CBE1}/SETUP_x64....
2014/10/14:20:07:12 Dionne DIONNE-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Dionne\AppData\Local\Temp\_AIE450.tmp\Setup\AcSetup.dll
2014/10/14:20:07:12 Dionne DIONNE-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/10/14:20:07:12 Dionne DIONNE-PC PageOpen LaunchDialog
2014/10/14:20:08:27 Dionne DIONNE-PC PageOpen LicenseDialog
2014/10/14:20:08:27 Dionne DIONNE-PC PageOpen ProductInfoDialog
2014/10/14:20:08:27 Dionne DIONNE-PC PageOpen ProductSelectionDialog2
2014/10/14:20:08:31 Dionne DIONNE-PC PageOpen FullProgressDialog
2014/10/14:20:08:31 Dionne DIONNE-PC Download Skipped VCREDIST2012X86UPD4 http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{E1E3C783-665C-40FD-A988-D99EE720CBE1}/VCREDIST20...
2014/10/14:20:08:31 Dionne DIONNE-PC Installing Microsoft Visual C++ 2012 Redistributable (x86) Update 4: "C:\Autodesk\WI\Autodesk AutoCAD 2015\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\Dionne\AppData\Local\Temp\vcredist_x86_2012_UPD4.log
2014/10/14:20:08:40 Dionne DIONNE-PC Install Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Succeeded
2014/10/14:20:08:40 Dionne DIONNE-PC Download Skipped VCREDIST2012X64UPD4 http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{E1E3C783-665C-40FD-A988-D99EE720CBE1}/VCREDIST20...
2014/10/14:20:08:40 Dionne DIONNE-PC Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "C:\Autodesk\WI\Autodesk AutoCAD 2015\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\Dionne\AppData\Local\Temp\vcredist_x64_2012_UPD4.log
2014/10/14:20:08:47 Dionne DIONNE-PC Install Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Succeeded
2014/10/14:20:08:47 Dionne DIONNE-PC Download Skipped DIRECTX http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{E1E3C783-665C-40FD-A988-D99EE720CBE1}/DIRECTX.ta...
2014/10/14:20:08:47 Dionne DIONNE-PC Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2015\3rdParty\DirectX\DXSETUP.exe" /silent
2014/10/14:20:09:19 Dionne DIONNE-PC Install DirectX Runtime Succeeded
2014/10/14:20:09:19 Dionne DIONNE-PC Download Skipped CM http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{E1E3C783-665C-40FD-A988-D99EE720CBE1}/CM.tar.lzm...
2014/10/14:20:09:20 Dionne DIONNE-PC Installing Autodesk Material Library 2015: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/10/14:20:10:32 Dionne DIONNE-PC Install Autodesk Material Library 2015 Succeeded
2014/10/14:20:10:32 Dionne DIONNE-PC Download Skipped CMILB http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{E1E3C783-665C-40FD-A988-D99EE720CBE1}/CMILB.tar....
2014/10/14:20:10:32 Dionne DIONNE-PC Installing Autodesk Material Library 2015 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/10/14:20:11:07 Dionne DIONNE-PC Install Autodesk Material Library 2015 - Base Image Library Succeeded
2014/10/14:20:11:09 Dionne DIONNE-PC Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\WI\Autodesk AutoCAD 2015\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=".NET Framework Runtime 4.5,Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x86),;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/10/14:20:11:30 Dionne DIONNE-PC Install Autodesk Content Service Succeeded
2014/10/14:20:11:30 Dionne DIONNE-PC Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/10/14:20:11:44 Dionne DIONNE-PC Install Autodesk Content Service Language Pack Succeeded
2014/10/14:20:11:44 Dionne DIONNE-PC Download Skipped ACAD http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{E1E3C783-665C-40FD-A988-D99EE720CBE1}/ACAD_x64.t...
2014/10/14:20:11:45 Dionne DIONNE-PC Installing Autodesk® AutoCAD® 2015: TRANSFORMS="C:\Autodesk\WI\Autodesk AutoCAD 2015\x64\en-us\acad\acad.mst;C:\Users\Dionne\AppData\Local\Temp\_AIE450.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2015" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/10/14:20:20:05 Dionne DIONNE-PC Install Autodesk® AutoCAD® 2015 Succeeded
2014/10/14:20:20:09 Dionne DIONNE-PC Download Play ACAD_en-us http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{E1E3C783-665C-40FD-A988-D99EE720CBE1}/ACAD_x64_e...
2014/10/14:20:23:45 Dionne DIONNE-PC Download Aborted ACAD_en-us http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{E1E3C783-665C-40FD-A988-D99EE720CBE1}/ACAD_x64_e...
2014/10/14:20:23:45 Dionne DIONNE-PC Install AutoCAD® 2015 Language Pack Failed Download Failed, Installation aborted, Result=1603
2014/10/14:20:26:13 Dionne DIONNE-PC Rollback Autodesk® AutoCAD® 2015 Succeeded
2014/10/14:20:26:24 Dionne DIONNE-PC Rollback Autodesk Content Service Language Pack Succeeded
2014/10/14:20:26:41 Dionne DIONNE-PC Rollback Autodesk Content Service Succeeded
2014/10/14:20:27:27 Dionne DIONNE-PC Rollback Autodesk Material Library 2015 - Base Image Library Succeeded
2014/10/14:20:28:21 Dionne DIONNE-PC Rollback Autodesk Material Library 2015 Succeeded
2014/10/14:20:28:22 Dionne DIONNE-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2014/10/14:20:28:22 Dionne DIONNE-PC Rollback Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Failed Failure is ignored, Result=1619
2014/10/14:20:28:22 Dionne DIONNE-PC Rollback Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Failed Failure is ignored, Result=1619
2014/10/14:20:28:30 Dionne DIONNE-PC PageOpen InstallCompleteDialog
2014/10/14:21:06:35 Dionne DIONNE-PC === Setup ended ===
2014/10/16:19:49:19 Dionne DIONNE-PC === Setup started on DIONNE-PC by Dionne ===
2014/10/16:19:49:19 Dionne DIONNE-PC Path_Length: 157
2014/10/16:19:49:19 Dionne DIONNE-PC Current Directory C:\Autodesk\AutoCAD_2015_English_Win_32_64bit_Trial_wi_en-us
2014/10/16:19:49:19 Dionne DIONNE-PC Launch
2014/10/16:19:49:19 Dionne DIONNE-PC CommandLine /url "http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/AutoCAD_2015_English_Win_32_64bit_Trial_wi_en-us_... /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/10/16:19:49:19 Dionne DIONNE-PC Current Directory C:\Users\Dionne\AppData\Local\Temp\_AI108C.tmp
2014/10/16:19:51:07 Dionne DIONNE-PC === Setup ended ===
2014/10/16:19:49:28 Dionne DIONNE-PC === Setup started on DIONNE-PC by Dionne ===
2014/10/16:19:49:28 Dionne DIONNE-PC Path_Length: 157
2014/10/16:19:49:28 Dionne DIONNE-PC Current Directory C:\Users\Dionne\AppData\Local\Temp\_AI108C.tmp
2014/10/16:19:49:28 Dionne DIONNE-PC Launch
2014/10/16:19:49:32 Dionne DIONNE-PC Download Play SETUPMARKER http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/SETUPMARKE...
2014/10/16:19:49:33 Dionne DIONNE-PC Download Complete SETUPMARKER http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/SETUPMARKE...
2014/10/16:19:49:34 Dionne DIONNE-PC Download Play SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/SETUP_x64....
2014/10/16:19:51:06 Dionne DIONNE-PC Download Complete SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/SETUP_x64....
2014/10/16:19:51:06 Dionne DIONNE-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Dionne\AppData\Local\Temp\_AI108C.tmp\Setup\AcSetup.dll
2014/10/16:19:51:06 Dionne DIONNE-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/10/16:19:51:07 Dionne DIONNE-PC PageOpen LaunchDialog
2014/10/16:19:51:18 Dionne DIONNE-PC PageOpen LicenseDialog
2014/10/16:19:51:18 Dionne DIONNE-PC PageOpen ProductInfoDialog
2014/10/16:19:53:55 Dionne DIONNE-PC PageOpen ProductSelectionDialog2
2014/10/16:19:53:57 Dionne DIONNE-PC PageOpen FullProgressDialog
2014/10/16:19:53:58 Dionne DIONNE-PC Download Play STARTMARKER http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/STARTMARKE...
2014/10/16:19:53:58 Dionne DIONNE-PC Download Complete STARTMARKER http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/STARTMARKE...
2014/10/16:19:53:59 Dionne DIONNE-PC Download Play VCREDIST2012X86UPD4 http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/VCREDIST20...
2014/10/16:19:54:03 Dionne DIONNE-PC Download Complete VCREDIST2012X86UPD4 http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/VCREDIST20...
2014/10/16:19:54:03 Dionne DIONNE-PC Installing Microsoft Visual C++ 2012 Redistributable (x86) Update 4: "C:\Autodesk\WI\Autodesk AutoCAD 2015\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\Dionne\AppData\Local\Temp\vcredist_x86_2012_UPD4.log
2014/10/16:19:55:13 Dionne DIONNE-PC Install Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Succeeded
2014/10/16:19:55:14 Dionne DIONNE-PC Download Play VCREDIST2012X64UPD4 http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/VCREDIST20...
2014/10/16:19:55:20 Dionne DIONNE-PC Download Complete VCREDIST2012X64UPD4 http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/VCREDIST20...
2014/10/16:19:55:20 Dionne DIONNE-PC Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "C:\Autodesk\WI\Autodesk AutoCAD 2015\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\Dionne\AppData\Local\Temp\vcredist_x64_2012_UPD4.log
2014/10/16:19:55:56 Dionne DIONNE-PC Install Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Succeeded
2014/10/16:19:55:56 Dionne DIONNE-PC Download Play DIRECTX http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/DIRECTX.ta...
2014/10/16:19:56:10 Dionne DIONNE-PC Download Aborted DIRECTX http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/DIRECTX.ta...
2014/10/16:19:56:10 Dionne DIONNE-PC Install DirectX Runtime Failed Download Failed, Installation aborted, Result=1603
2014/10/16:19:56:10 Dionne DIONNE-PC Download Play CM http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/CM.tar.lzm...
2014/10/16:21:07:16 Dionne DIONNE-PC Download Aborted CM http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/CM.tar.lzm...
2014/10/16:21:07:16 Dionne DIONNE-PC Download User Cancel CM http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/CM.tar.lzm...
2014/10/16:21:07:18 Dionne DIONNE-PC Download Play CANCELMARKER http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/CANCELMARK...
2014/10/16:21:07:27 Dionne DIONNE-PC PageOpen InstallCompleteDialog
2014/10/17:00:14:32 Dionne DIONNE-PC === Setup ended ===
2014/10/17:13:55:26 Dionne DIONNE-PC === Setup started on DIONNE-PC by Dionne ===
2014/10/17:13:55:26 Dionne DIONNE-PC Path_Length: 157
2014/10/17:13:55:26 Dionne DIONNE-PC Current Directory C:\Autodesk\AutoCAD_2015_English_Win_32_64bit_Trial_wi_en-us
2014/10/17:13:55:26 Dionne DIONNE-PC Launch
2014/10/17:13:55:26 Dionne DIONNE-PC CommandLine /url "http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/AutoCAD_2015_English_Win_32_64bit_Trial_wi_en-us_... /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/10/17:13:55:26 Dionne DIONNE-PC Current Directory C:\Users\Dionne\AppData\Local\Temp\_AI7185.tmp
2014/10/17:13:55:39 Dionne DIONNE-PC === Setup ended ===
2014/10/17:13:55:33 Dionne DIONNE-PC === Setup started on DIONNE-PC by Dionne ===
2014/10/17:13:55:33 Dionne DIONNE-PC Path_Length: 157
2014/10/17:13:55:33 Dionne DIONNE-PC Current Directory C:\Users\Dionne\AppData\Local\Temp\_AI7185.tmp
2014/10/17:13:55:33 Dionne DIONNE-PC Launch
2014/10/17:13:55:36 Dionne DIONNE-PC Download Skipped SETUPMARKER http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/SETUPMARKE...
2014/10/17:13:55:36 Dionne DIONNE-PC Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/SETUP_x64....
2014/10/17:13:55:37 Dionne DIONNE-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Dionne\AppData\Local\Temp\_AI7185.tmp\Setup\AcSetup.dll
2014/10/17:13:55:37 Dionne DIONNE-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/10/17:13:55:39 Dionne DIONNE-PC PageOpen LaunchDialog
2014/10/17:13:56:14 Dionne DIONNE-PC PageOpen LicenseDialog
2014/10/17:13:56:14 Dionne DIONNE-PC PageOpen ProductInfoDialog
2014/10/17:13:56:45 Dionne DIONNE-PC PageOpen ProductSelectionDialog2
2014/10/17:13:56:48 Dionne DIONNE-PC PageOpen FullProgressDialog
2014/10/17:13:56:50 Dionne DIONNE-PC Download Play STARTMARKER http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/STARTMARKE...
2014/10/17:13:56:51 Dionne DIONNE-PC Download Complete STARTMARKER http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/STARTMARKE...
2014/10/17:13:56:51 Dionne DIONNE-PC Download Skipped VCREDIST2012X86UPD4 http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/VCREDIST20...
2014/10/17:13:56:51 Dionne DIONNE-PC Installing Microsoft Visual C++ 2012 Redistributable (x86) Update 4: "C:\Autodesk\WI\Autodesk AutoCAD 2015\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\Dionne\AppData\Local\Temp\vcredist_x86_2012_UPD4.log
2014/10/17:13:57:00 Dionne DIONNE-PC Install Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Succeeded
2014/10/17:13:57:01 Dionne DIONNE-PC Download Skipped VCREDIST2012X64UPD4 http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/VCREDIST20...
2014/10/17:13:57:01 Dionne DIONNE-PC Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "C:\Autodesk\WI\Autodesk AutoCAD 2015\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\Dionne\AppData\Local\Temp\vcredist_x64_2012_UPD4.log
2014/10/17:13:57:05 Dionne DIONNE-PC Install Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Succeeded
2014/10/17:13:57:06 Dionne DIONNE-PC Download Play DIRECTX http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/DIRECTX.ta...
2014/10/17:13:57:19 Dionne DIONNE-PC Download Complete DIRECTX http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/DIRECTX.ta...
2014/10/17:13:57:19 Dionne DIONNE-PC Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2015\3rdParty\DirectX\DXSETUP.exe" /silent
2014/10/17:13:57:58 Dionne DIONNE-PC Install DirectX Runtime Succeeded
2014/10/17:13:57:59 Dionne DIONNE-PC Download Play CM http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/CM.tar.lzm...
2014/10/17:13:58:43 Dionne DIONNE-PC Download Complete CM http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/CM.tar.lzm...
2014/10/17:13:58:43 Dionne DIONNE-PC Installing Autodesk Material Library 2015: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/10/17:13:59:54 Dionne DIONNE-PC Install Autodesk Material Library 2015 Succeeded
2014/10/17:13:59:54 Dionne DIONNE-PC Download Play CMILB http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/CMILB.tar....
2014/10/17:14:00:53 Dionne DIONNE-PC Download Complete CMILB http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/CMILB.tar....
2014/10/17:14:00:53 Dionne DIONNE-PC Installing Autodesk Material Library 2015 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/10/17:14:01:33 Dionne DIONNE-PC Install Autodesk Material Library 2015 - Base Image Library Succeeded
2014/10/17:14:01:34 Dionne DIONNE-PC Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\WI\Autodesk AutoCAD 2015\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=".NET Framework Runtime 4.5,Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x86),;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/10/17:14:01:57 Dionne DIONNE-PC Install Autodesk Content Service Succeeded
2014/10/17:14:01:58 Dionne DIONNE-PC Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/10/17:14:02:10 Dionne DIONNE-PC Install Autodesk Content Service Language Pack Succeeded
2014/10/17:14:02:11 Dionne DIONNE-PC Download Play ACAD http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/ACAD_x64.t...
2014/10/17:14:11:27 Dionne DIONNE-PC Download Complete ACAD http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/ACAD_x64.t...
2014/10/17:14:11:30 Dionne DIONNE-PC Installing Autodesk® AutoCAD® 2015: TRANSFORMS="C:\Autodesk\WI\Autodesk AutoCAD 2015\x64\en-us\acad\acad.mst;C:\Users\Dionne\AppData\Local\Temp\_AI7185.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2015" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/10/17:14:20:48 Dionne DIONNE-PC Install Autodesk® AutoCAD® 2015 Succeeded
2014/10/17:14:20:50 Dionne DIONNE-PC Download Play ACAD_en-us http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/ACAD_x64_e...
2014/10/17:14:23:24 Dionne DIONNE-PC Download Aborted ACAD_en-us http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/ACAD_x64_e...
2014/10/17:14:23:24 Dionne DIONNE-PC Install AutoCAD® 2015 Language Pack Failed Download Failed, Installation aborted, Result=1603
2014/10/17:14:25:56 Dionne DIONNE-PC Rollback Autodesk® AutoCAD® 2015 Succeeded
2014/10/17:14:26:10 Dionne DIONNE-PC Rollback Autodesk Content Service Language Pack Succeeded
2014/10/17:14:26:26 Dionne DIONNE-PC Rollback Autodesk Content Service Succeeded
2014/10/17:14:26:58 Dionne DIONNE-PC Rollback Autodesk Material Library 2015 - Base Image Library Succeeded
2014/10/17:14:28:06 Dionne DIONNE-PC Rollback Autodesk Material Library 2015 Succeeded
2014/10/17:14:28:07 Dionne DIONNE-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2014/10/17:14:28:07 Dionne DIONNE-PC Rollback Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Failed Failure is ignored, Result=1619
2014/10/17:14:28:08 Dionne DIONNE-PC Rollback Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Failed Failure is ignored, Result=1619
2014/10/17:14:28:19 Dionne DIONNE-PC PageOpen InstallCompleteDialog
2014/10/17:21:27:07 Dionne DIONNE-PC === Setup ended ===
2014/10/17:21:32:39 Dionne DIONNE-PC === Setup started on DIONNE-PC by Dionne ===
2014/10/17:21:32:39 Dionne DIONNE-PC Path_Length: 157
2014/10/17:21:32:39 Dionne DIONNE-PC Current Directory C:\Autodesk\AutoCAD_2015_English_Win_32_64bit_Trial_wi_en-us
2014/10/17:21:32:39 Dionne DIONNE-PC Launch
2014/10/17:21:32:39 Dionne DIONNE-PC CommandLine /url "http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/AutoCAD_2015_English_Win_32_64bit_Trial_wi_en-us_... /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/10/17:21:32:39 Dionne DIONNE-PC Current Directory C:\Users\Dionne\AppData\Local\Temp\_AI72C.tmp
2014/10/17:21:32:48 Dionne DIONNE-PC === Setup ended ===
2014/10/17:21:32:44 Dionne DIONNE-PC === Setup started on DIONNE-PC by Dionne ===
2014/10/17:21:32:44 Dionne DIONNE-PC Path_Length: 157
2014/10/17:21:32:44 Dionne DIONNE-PC Current Directory C:\Users\Dionne\AppData\Local\Temp\_AI72C.tmp
2014/10/17:21:32:44 Dionne DIONNE-PC Launch
2014/10/17:21:32:45 Dionne DIONNE-PC Download Skipped SETUPMARKER http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/SETUPMARKE...
2014/10/17:21:32:45 Dionne DIONNE-PC Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/SETUP_x64....
2014/10/17:21:32:47 Dionne DIONNE-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Dionne\AppData\Local\Temp\_AI72C.tmp\Setup\AcSetup.dll
2014/10/17:21:32:47 Dionne DIONNE-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/10/17:21:32:48 Dionne DIONNE-PC PageOpen LaunchDialog
2014/10/17:21:33:01 Dionne DIONNE-PC PageOpen LicenseDialog
2014/10/17:21:33:02 Dionne DIONNE-PC PageOpen ProductInfoDialog
2014/10/17:21:33:21 Dionne DIONNE-PC PageOpen ProductSelectionDialog2
2014/10/17:21:33:34 Dionne DIONNE-PC PageOpen FullProgressDialog
2014/10/17:21:33:36 Dionne DIONNE-PC Download Play STARTMARKER http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/STARTMARKE...
2014/10/17:21:33:38 Dionne DIONNE-PC Download Complete STARTMARKER http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/STARTMARKE...
2014/10/17:21:33:38 Dionne DIONNE-PC Download Skipped VCREDIST2012X86UPD4 http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/VCREDIST20...
2014/10/17:21:33:38 Dionne DIONNE-PC Installing Microsoft Visual C++ 2012 Redistributable (x86) Update 4: "C:\Autodesk\WI\Autodesk AutoCAD 2015\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\Dionne\AppData\Local\Temp\vcredist_x86_2012_UPD4.log
2014/10/17:21:35:08 Dionne DIONNE-PC Install Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Succeeded
2014/10/17:21:35:08 Dionne DIONNE-PC Download Skipped VCREDIST2012X64UPD4 http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/VCREDIST20...
2014/10/17:21:35:08 Dionne DIONNE-PC Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "C:\Autodesk\WI\Autodesk AutoCAD 2015\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\Dionne\AppData\Local\Temp\vcredist_x64_2012_UPD4.log
2014/10/17:21:35:57 Dionne DIONNE-PC Install Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Succeeded
2014/10/17:21:35:57 Dionne DIONNE-PC Download Skipped DIRECTX http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/DIRECTX.ta...
2014/10/17:21:35:57 Dionne DIONNE-PC Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2015\3rdParty\DirectX\DXSETUP.exe" /silent
2014/10/17:21:37:15 Dionne DIONNE-PC Install DirectX Runtime Succeeded
2014/10/17:21:37:15 Dionne DIONNE-PC Download Skipped CM http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/CM.tar.lzm...
2014/10/17:21:37:16 Dionne DIONNE-PC Installing Autodesk Material Library 2015: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/10/17:21:38:31 Dionne DIONNE-PC Install Autodesk Material Library 2015 Succeeded
2014/10/17:21:38:32 Dionne DIONNE-PC Download Skipped CMILB http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/CMILB.tar....
2014/10/17:21:38:32 Dionne DIONNE-PC Installing Autodesk Material Library 2015 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/10/17:21:39:10 Dionne DIONNE-PC Install Autodesk Material Library 2015 - Base Image Library Succeeded
2014/10/17:21:39:11 Dionne DIONNE-PC Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\WI\Autodesk AutoCAD 2015\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=".NET Framework Runtime 4.5,Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x86),;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/10/17:21:39:32 Dionne DIONNE-PC Install Autodesk Content Service Succeeded
2014/10/17:21:39:33 Dionne DIONNE-PC Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/10/17:21:39:42 Dionne DIONNE-PC Install Autodesk Content Service Language Pack Succeeded
2014/10/17:21:39:43 Dionne DIONNE-PC Download Skipped ACAD http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/ACAD_x64.t...
2014/10/17:21:39:43 Dionne DIONNE-PC Installing Autodesk® AutoCAD® 2015: TRANSFORMS="C:\Autodesk\WI\Autodesk AutoCAD 2015\x64\en-us\acad\acad.mst;C:\Users\Dionne\AppData\Local\Temp\_AI72C.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2015" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/10/17:21:57:33 Dionne DIONNE-PC Install Autodesk® AutoCAD® 2015 Succeeded
2014/10/17:21:57:37 Dionne DIONNE-PC Download Play ACAD_en-us http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/ACAD_x64_e...
2014/10/17:22:01:38 Dionne DIONNE-PC Download Aborted ACAD_en-us http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/ACAD_x64_e...
2014/10/17:22:01:38 Dionne DIONNE-PC Install AutoCAD® 2015 Language Pack Failed Download Failed, Installation aborted, Result=1603
2014/10/17:22:04:16 Dionne DIONNE-PC Rollback Autodesk® AutoCAD® 2015 Succeeded
2014/10/17:22:04:29 Dionne DIONNE-PC Rollback Autodesk Content Service Language Pack Succeeded
2014/10/17:22:04:44 Dionne DIONNE-PC Rollback Autodesk Content Service Succeeded
2014/10/17:22:05:21 Dionne DIONNE-PC Rollback Autodesk Material Library 2015 - Base Image Library Succeeded
2014/10/17:22:06:25 Dionne DIONNE-PC Rollback Autodesk Material Library 2015 Succeeded
2014/10/17:22:06:25 Dionne DIONNE-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2014/10/17:22:06:26 Dionne DIONNE-PC Rollback Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Failed Failure is ignored, Result=1619
2014/10/17:22:06:26 Dionne DIONNE-PC Rollback Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Failed Failure is ignored, Result=1619
