I downloaded the design suite ultimate 2015 trial. I am using the autocad 2015 program which seems to work fine until I have
worked on a drawing ( simple floor plans, elevations ) for a couple hours then all the sudden it slows down and simple commands
take a long time to complete and then the program crashes often at this point. If I write a portion of the drawing to a Wblock , the new wblock file
has the same problem like it is contaminated or something. I have autocad 2014 student version also on my computer and I think I allowed migration
during the design suite installation if that matters. Also I had a previous autocad 2015 trial that expired , however I did a uninstall of that prior to the
design suite installation . Finding the solution seems very complex as so many posts, etc. Please help so I can use the program effectively.
thanks
Matt
You should probably make sure that you have the latest service packs installed, as well as using a certified video card driver. Inventor is pretty intensive.
