Installation & Licensing
AutoCAD 2015 - "Installation was canceled. Some products were not installed."
6 REPLIES 6
3294 Views, 6 Replies
Any one have this problem too ?
6 REPLIES 6
pendean
Find and post the installation log please.
in reply to: pendean
Below is the end of the installation log, please take a look
Install    Autodesk® AutoCAD® P&ID 2015 Product Specific Pack    Failed    Installation aborted, Result=1602
Rollback    Autodesk® AutoCAD® P&ID 2015 Language Pack    Succeeded
Rollback    Autodesk® AutoCAD® P&ID 2015    Succeeded
Rollback    Microsoft WSE 3.0 Runtime    Succeeded
Rollback    DirectX Runtime    Failed    Failure is ignored, Result=1619
Rollback    Microsoft Visual C++ 2012 Redistributable (x64) Update 4    Failed    Failure is ignored, Result=1619
Rollback    Microsoft Visual C++ 2012 Redistributable (x86) Update 4    Failed    Failure is ignored, Result=1619
pendean
Search around here for 1619 errors, many solutions posted.
I don't think 1619 is a problem. But 1602 is. And I can't find any solution in this forum
TravisNave
1602 is one of those odd MSI errors that generally means the user cancelled the install.  Being that this is not usually the case, I typically recommend that you reboot then login as another user with admin rights (or local administrator) and reinstall with that account.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
in reply to: TravisNave
I tried restarting my computer and logging back into my account (Which is the only one on my Windows 8.1 Laptop) And I tried to install yet everything failed.
I'm trying to install Inventor Professional 2015
Errors in the log:
2014/10/9:12:16:53 Owner ADMIN-PC-3 Uninstall {55D9E026-DCB0-46FF-B60A-68B972228CF6} Failed
2014/10/9:12:16:53 Owner ADMIN-PC-3 Uninstall {450063AA-643B-417C-8CF5-405BA3F4EF40} Failed
2014/10/9:12:16:53 Owner ADMIN-PC-3 Uninstall {02A00C13-555A-4B8A-B53B-1D02FFF5EEAF} Failed
2014/10/9:12:16:53 Owner ADMIN-PC-3 Uninstall {106EC844-9F5E-4B72-BB3B-1E47D274A944} Failed
2014/10/9:12:16:53 Owner ADMIN-PC-3 Uninstall {FACF203E-0F4D-489A-B80C-D185253C8FCB} Failed
2014/10/9:12:16:53 Owner ADMIN-PC-3 Uninstall {1A2948E0-9445-42BE-9D01-472952F2657F} Failed
2014/10/9:12:16:53 Owner ADMIN-PC-3 Uninstall {9A346205-EA92-4406-B1AB-50379DA3F057} Failed
2014/10/9:12:16:53 Owner ADMIN-PC-3 Uninstall {C46C3C20-039E-4D7C-869F-9C0C05D65C06} Failed
2014/10/9:12:16:53 Owner ADMIN-PC-3 Uninstall {577D60CB-0D5E-48D1-8850-84098AD34804} Failed
2014/10/9:12:16:53 Owner ADMIN-PC-3 Uninstall {0576A3D0-0000-0409-0000-491C453655D7} Failed
2014/10/9:12:16:53 Owner ADMIN-PC-3 Uninstall {7BDBD5BE-B02E-4FB4-8735-B9AF4FCA838F} Failed
2014/10/9:12:16:53 Owner ADMIN-PC-3 Uninstall {1ECD6EC8-7BB2-4CD5-A384-BAA371BC4D21} Failed
2014/10/9:12:16:53 Owner ADMIN-PC-3 Uninstall {4780F600-0000-0409-0000-114715ACF216} Failed
2014/10/9:12:16:54 Owner ADMIN-PC-3 Installing Autodesk® Design Review 2013:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2015" SETUP_PACKAGECODE={8CB42675-1900-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Internet Explorer 7.0,Microsoft Visual C++ 2010 SP1 Redistributable (x64),Microsoft Visual C++ 2010 SP1 Redistributable (x86),Microsoft Visual C++ 2012 Redistributable (x86),Microsoft Visual C++ 2012 Redistributable (x64),.NET Framework Runtime 4.5 SP1,;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Inventor_2015_English_Win_64bit_R1_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/10/9:12:17:51 Owner ADMIN-PC-3 Install Autodesk® Design Review 2013 Succeeded
2014/10/9:12:17:55 Owner ADMIN-PC-3 Installing Autodesk® Inventor® 2015:  TRANSFORMS="C:\Autodesk\Autodesk_Inventor_2015_English_Win_64bit_R1_dlm\x64\en-us\Inventor\inventor.mst;C:\Users\Owner\AppData\Local\Temp\_AIA361.tmp\x64\inventor\inventor-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Inventor_2015_English_Win_64bit_R1_dlm\" INSTALLDIR="C:\Program Files\Autodesk\Inventor 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/10/9:12:28:59 Owner ADMIN-PC-3 Install Autodesk® Inventor® 2015 Failed Installation aborted, Result=1602
2014/10/9:12:28:59 Owner ADMIN-PC-3 Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/10/9:12:29:02 Owner ADMIN-PC-3 PageOpen InstallCompleteDialog
2014/10/9:12:29:10 Owner ADMIN-PC-3 === Setup ended ===
Administrator Productivity
