Installation & Licensing
AUTOCAD 2015 FREEZE AT STARTUP
3 REPLIES 3
2231 Views, 3 Replies
hello im working with the army,we get the version of a new autocad 2015 in disk with cdkey on the back of the box.
When I get to the autocad and trying to start it Its just freeze and its crashes and i got this massge :FATAL ERROR-Unhandled e0434352h exception at 75dbb60h
I tried to figure about whats going on,with posts and google and I tried to erase all the stuff thats connects to autocad from computer including Regeistry,
im despered please help. 🙂
3 REPLIES 3
TravisNave
Usually those errors are a problem with the .NET Framework.  .NET Framework issues can be resolved using the .NET Framework Cleanup Tool. More information about this tool can be found at my discussion thread here:
http://forums.autodesk.com/t5/Installation-Licensing/NET-Framework-Cleanup-Tool-for-Unhandled-Except...
Good Luck!
Autodesk Forums:
in reply to: TravisNave
Thank you for replay,Yeah I check that out,I unistall the Net.Framwork
after i unisall i install again and still no luck...:(
TravisNave
Then you probably have a virus, malware, or some other 3rd party program
contributing to the error.
Autodesk Forums:
Administrator Productivity
