I faced a problemwith AutoCAD 2015 - 64bit, where after the downloading finish to my PC, then I got message shown me three possiblity of problem asfollow:
1 - the softer did not existe.
2 - refreshing in Auto CD web.
3 - fire wall.
in this arround or meaing the message it cameplease refer to attached .
pleaseadvise what I can to do to get this software.
Note: I a student in Heriot watt universty and I had registered in Autodisck.
Best regards,
Kinan
Solved by TravisNave. Go to Solution.
I would recommend that you try downloading your product using the virtual assistant by following the directions here:
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-...
