Hi I tried to install a student version of revit 2015. It was not completly installed so I decided to uninstall and install again. I followed all steps in Autodesk website to un-install but still I can not install something over it. Says Revit 2015 is installed.
even deleted all registery. However, did not have the product key.
Solved by ukdxb012. Go to Solution.
Hi @Anonymous ,
Welcome to the Community. Have you tried out using the MS Fixit Tool yet to do a clean uninstall of the previous failed installation of Revit?
Program lists as already installed
Kindly try out the solution provided there and let us know how it goes.
If you are trying to perform a clean installation of Revit, but a previous corrupted installation of Revit appears to be installed, please follow these steps on the following link...
Please be mindful of the instructions though as they state keys for older Revit versions.
I believe the keyname is 0A4B643700510150000007C5D0680240
Good luck!
