I have tried installing Autocad 2015 on my Mac and it tells me filesystem incompatibility yet the system is formatted as required
(Mac OS Extended (Journaled). Mac is running Yosemite 10.10.1. Thanks
Here it is:
Nov 10 21:43:06 Jerrys-MacBook-Pro.local softwareupdate_firstrun_tasks[73]: swscan.apple.com is available: TRUE
Nov 10 21:43:06 Jerrys-MacBook-Pro.local softwareupdated[213]: softwareupdated: Starting with build 10.10.1 (14B17)
Nov 10 21:43:06 Jerrys-MacBook-Pro.local softwareupdated[213]: BackgroundActivity: Activity check-in with Interval 21600
Nov 10 21:43:06 Jerrys-MacBook-Pro.local softwareupdated[213]: Adding client SUUpdateServiceClient pid=73, uid=200, installAuth=NO rights=(), transactions=0 (/System/Library/CoreServices/Software Update.app/Contents/Resources/softwareupdate_firstrun_tasks)
Nov 10 21:43:06 Jerrys-MacBook-Pro.local softwareupdated[213]: Removing client SUUpdateServiceClient pid=73, uid=200, installAuth=NO rights=(), transactions=0 (/System/Library/CoreServices/Software Update.app/Contents/Resources/softwareupdate_firstrun_tasks)
Nov 10 21:43:31 Jerrys-MacBook-Pro.local softwareupdate_notify_agent[342]: Running for LoginDone
Nov 10 21:43:31 Jerrys-MacBook-Pro.local softwareupdate_notify_agent[342]: AssertionMgr: Take com.apple.softwareupdate.NotifyAgentAssertion assertion with type BackgroundTask for pid 342
Nov 10 21:43:31 Jerrys-MacBook-Pro.local softwareupdated[213]: Adding client SUUpdateServiceClient pid=342, uid=501, installAuth=NO rights=(), transactions=0 (/System/Library/CoreServices/Software Update.app/Contents/Resources/softwareupdate_notify_agent)
Nov 10 21:43:31 Jerrys-MacBook-Pro.local softwareupdate_notify_agent[342]: Notifying with params: {
UpdateNotificationsOnly = 1;
Nov 10 21:43:31 Jerrys-MacBook-Pro.local softwareupdate_notify_agent[342]: appstoreupdateagent notified
Nov 10 21:43:31 Jerrys-MacBook-Pro.local softwareupdate_notify_agent[342]: AssertionMgr: Cancel com.apple.softwareupdate.NotifyAgentAssertion assertion for pid 342
Nov 10 21:43:31 Jerrys-MacBook-Pro.local softwareupdated[213]: Removing client SUUpdateServiceClient pid=342, uid=501, installAuth=NO rights=(), transactions=0 (/System/Library/CoreServices/Software Update.app/Contents/Resources/softwareupdate_notify_agent)
Nov 10 21:43:32 Jerrys-MacBook-Pro.local softwareupdated[213]: Adding client SUUpdateServiceClient pid=345, uid=501, installAuth=NO rights=(), transactions=0 (/System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Resources/storeassetd)
Nov 10 21:57:15 Jerrys-MacBook-Pro.local Installer[534]: LSExceptions [0x7fa3ab508ea0] loaded
Nov 10 21:57:15 Jerrys-MacBook-Pro.local Installer[534]: @(#)PROGRAM:Install PROJECT:Install-920
Nov 10 21:57:15 Jerrys-MacBook-Pro.local Installer[534]: @(#)PROGRAM:Installer PROJECT:Installer-815
Nov 10 21:57:15 Jerrys-MacBook-Pro.local Installer[534]: Hardware: MacBookPro9,1 @ 2.30 GHz (x 8), 4096 MB RAM
Nov 10 21:57:15 Jerrys-MacBook-Pro.local Installer[534]: Running OS Build: Mac OS X 10.10.1 (14B17)
Nov 10 21:57:15 Jerrys-MacBook-Pro.local Installer[534]: Env: PATH=/usr/bin:/bin:/usr/sbin:/sbin
Nov 10 21:57:15 Jerrys-MacBook-Pro.local Installer[534]: Env: USER=duenasg
Nov 10 21:57:15 Jerrys-MacBook-Pro.local Installer[534]: Env: COMMAND_MODE=unix2003
Nov 10 21:57:15 Jerrys-MacBook-Pro.local Installer[534]: Env: LOGNAME=duenasg
Nov 10 21:57:15 Jerrys-MacBook-Pro.local Installer[534]: Env: SSH_AUTH_SOCK=/private/tmp/com.apple.launchd.zY9Z4IGFbF/Listeners
Nov 10 21:57:15 Jerrys-MacBook-Pro.local Installer[534]: Env: Apple_PubSub_Socket_Render=/private/tmp/com.apple.launchd.nVCUReQpOH/Render
Nov 10 21:57:15 Jerrys-MacBook-Pro.local Installer[534]: Env: HOME=/Users/duenasg
Nov 10 21:57:15 Jerrys-MacBook-Pro.local Installer[534]: Env: SHELL=/bin/bash
Nov 10 21:57:15 Jerrys-MacBook-Pro.local Installer[534]: Env: TMPDIR=/var/folders/7k/rflp9d250c7gmv1mgwsclbh00000gn/T/
Nov 10 21:57:15 Jerrys-MacBook-Pro.local Installer[534]: Env: __CF_USER_TEXT_ENCODING=0x1F5:0x0:0x0
Nov 10 21:57:15 Jerrys-MacBook-Pro.local Installer[534]: Env: XPC_SERVICE_NAME=com.apple.xpc.launchd.oneshot.0x10000007.Installer
Nov 10 21:57:15 Jerrys-MacBook-Pro.local Installer[534]: Env: EnvAgent_vars=JAVA_HOME PATH
Nov 10 21:57:15 Jerrys-MacBook-Pro.local Installer[534]: Env: PATH=$PATH:$JAVA_HOME/bin/
Nov 10 21:57:15 Jerrys-MacBook-Pro.local Installer[534]: Env: JAVA_HOME=/Library/Java/
Nov 10 21:57:15 Jerrys-MacBook-Pro.local Installer[534]: Env: XPC_FLAGS=0x0
Nov 10 21:57:15 Jerrys-MacBook-Pro.local Installer[534]: Autodesk AutoCAD 2015 for Mac Installation Log
Nov 10 21:57:15 Jerrys-MacBook-Pro.local Installer[534]: Opened from: /Volumes/Autodesk AutoCAD 2015 for Mac Installation/Install Autodesk AutoCAD 2015 for Mac.pkg
Nov 10 21:57:16 Jerrys-MacBook-Pro.local Installer[534]: Product archive /Volumes/Autodesk AutoCAD 2015 for Mac Installation/Install Autodesk AutoCAD 2015 for Mac.pkg trustLevel=202
Nov 10 21:57:20 Jerrys-MacBook-Pro.local Installer[534]: WARNING: The Gestalt selector gestaltSystemVersion is returning 10.9.1 instead of 10.10.1. Use NSProcessInfo's operatingSystemVersion property to get correct system version number.
Call location:
Nov 10 21:57:20 Jerrys-MacBook-Pro.local Installer[534]: 0 CarbonCore 0x00007fff8e7c7dc3 ___Gestalt_SystemVersion_block_invoke + 113
Nov 10 21:57:20 Jerrys-MacBook-Pro.local Installer[534]: 1 libdispatch.dylib 0x00007fff8c1b8c13 _dispatch_client_callout + 8
Nov 10 21:57:20 Jerrys-MacBook-Pro.local Installer[534]: 2 libdispatch.dylib 0x00007fff8c1b8b26 dispatch_once_f + 117
Nov 10 21:57:20 Jerrys-MacBook-Pro.local Installer[534]: 3 CarbonCore 0x00007fff8e7704da _Gestalt_SystemVersion + 987
Nov 10 21:57:20 Jerrys-MacBook-Pro.local Installer[534]: 4 CarbonCore 0x00007fff8e7700c7 Gestalt + 144
Nov 10 21:57:20 Jerrys-MacBook-Pro.local Installer[534]: 5 UICustomizer 0x000000011cb73951 -[UICustomizerPaneAutoCAD2015 mapButtons:] + 101
Nov 10 21:57:20 Jerrys-MacBook-Pro.local Installer[534]: 6 UICustomizer 0x000000011cb7384b -[UICustomizerPaneAutoCAD2015 initializeWindow] + 923
Nov 10 21:57:20 Jerrys-MacBook-Pro.local Installer[534]: JS: Testing existing installations of AutoCAD
Nov 10 21:57:20 Jerrys-MacBook-Pro.local Installer[534]: JS: 0
Nov 10 21:57:20 Jerrys-MacBook-Pro.local Installer[534]: JS: returning true because AutoCAD not Installed
Nov 10 21:57:20 Jerrys-MacBook-Pro.local Installer[534]: JS: Testing hardware compatibility for AutoCAD
Nov 10 21:57:20 Jerrys-MacBook-Pro.local Installer[534]: JS: returning true because Model supported
Nov 10 21:57:20 Jerrys-MacBook-Pro.local Installer[534]: JS: Checking for running instances of AutoCAD
Nov 10 21:57:20 Jerrys-MacBook-Pro.local Installer[534]: JS: returning true because AutoCAD not running
Nov 10 21:57:20 Jerrys-MacBook-Pro.local Installer[534]: JS: Checking for running instances of AdSync
Nov 10 21:57:21 Jerrys-MacBook-Pro.local Installer[534]: JS: 0
Nov 10 21:57:21 Jerrys-MacBook-Pro.local Installer[534]: JS: returning true because AdSync not running
Nov 10 21:57:21 Jerrys-MacBook-Pro.local Installer[534]: JS: Testing graphics card compatibility for AutoCAD
Nov 10 21:57:21 Jerrys-MacBook-Pro.local Installer[534]: JS: returning true because graphics card supported
Nov 10 21:57:21 Jerrys-MacBook-Pro.local Installer[534]: JS: Testing System Drive File System for compatibility with AutoCAD
Nov 10 21:57:25 Jerrys-MacBook-Pro.local Installer[534]: LSExceptions [0x7fa3ab508ea0] unloaded
Nov 10 21:57:25 Jerrys-MacBook-Pro.local Installer[534]: JS: 1
Nov 10 21:57:25 Jerrys-MacBook-Pro.local Installer[534]: JS: Return false because System Drive File System not supported
Nov 10 21:57:25 Jerrys-MacBook-Pro.local Installer[534]: Installation checks failed.
Nov 10 21:57:26 Jerrys-MacBook-Pro.local Installer[534]: Installation check failure. Incompatible File System!. Autodesk AutoCAD 2015 for Mac can only be installed on System drive formatted with Journaled HFS+ (Mac OS Extended Journaled) file system..
