I have recently installed Autocad R15 on my new Dell Alienware windows 8.1
I use the Annotate command a lot. If I try to trim this annotation Autocad crashes.
Anybody have this problem. I have downloaded Autocad R15 a couple times. Also uninstalled it and
now have re installed from a Usb supplied by Autodesk.
Any help appreciated.
You might try to update your video card driver. What are you running now?
How do I go about that. Sorry this is a new laptop and I'm still trying to get my head around it.
It has a top spec and the best graphics cards.
Yes.
I would recommend this certified driver:
http://www.nvidia.com/download/driverResults.aspx/78877/en-us
When you install it, make sure you check the box for clean installation. It will require two reboots. Be patient.
Good Luck!
I just tried this and still no luck. Clean installation.
Any other ideas?
Thanks.
You are running the latest service pack for 2015?
